Banana pi BPI-R2 Premium Aluminum Enclosure
(bpi team) #1
two hard drives inside: so ,your NAS ???
more about BPI-R2
(Maciek Szelągowski) #2
more info please: does it take any hard drives?
(Daniel) #3
Hello :slight_smile:
Where and when will the enclosure be available?
Thanks in advance and best regards, temp0r
(bpi team) #4
will ready this month .,
(Daniel) #5
Sounds good, thanks a lot!
(bpi team) #6
yes you can place your hard driver inside. :slight_smile:
(Frank W.) #7
estimated price? holes for gpio? Count of holes for wifi-antennas? please more pictures also from inside
(bpi team) #8
OK, will update soon , just tooling finished and sample ready .:slight_smile:
(Thomas Linke) #9
That looks extremely nice! Can we access the switches on the rear side? How about some some brackets for 19" rackmount? Would’t that be nice too?
(Frank W.) #10
where to get such angulated (90°) sata power-cables? you use the fan-port for 2nd sata-power, right (not powered by default)? the 4 pin-header is empty… is there enough space to top for dupont-cables on gpio/debug-uart and holes in case to get them out?
(bpi team) #11
#12
Wow, neat! Do you perhaps have an update when this will be available on aliexpress or other channels?
(bpi team) #13
yes, will instock soon .:slight_smile: , and will can buy sample from aliexpress soon.
(Tony) #14
When will it be available?
#15
Is it possable to add a fan on the top?
(bpi team) #16
Banana Pi BPI-R2 Arcylic case
(Thomas Linke) #17
Hi Frank-W,
just like you I stumbled across the powering a second disk with the power-outlet named “FAN”. On Sunday, I gave it a try, risqued an old HDD, and you know what? It worked! :slight_smile:
Still I don’t actually know what that four-pin power connector is supposed to be. Hmmmm … could it be that it has 2x GND plus 1x 5 Volts an 1x 12 Volts for a serious 3.5" Harddisk oder CDROM’s. Imagine that!!!
If that’s true, I’m going to put an SCSI-Controller into the pci-e Port and boot from Tape :smiley:
(Frank W.) #18
the 4-pin-connector: http://www.fw-web.de/dokuwiki/lib/exe/fetch.php?media=bpi-r2:sata_power.jpg
Which os/kernel do you use with the fan-connector? I have no output-voltage in my test (did not try a hdd on it yet)
(Thomas Linke) #19
I used the standard Ubuntu image. When I put my meter on the pins I didn’t measure anything. So I had a cognac and decided to take the risk. And when I started the R2, the harddisks also started. Lucky me, didn’t burn the house :smiley:
Didn’t know the image you showed me, so indeed, this looks like a power-outlet for a 3.5" drive :wink: I do not need that right now, but it’s good to know.
(Frank W.) #20
i assume the output is a PWM-signal (for stepping down/up the fan) = alternating current. I’m not sure if it can be used securily for a hard-disk which may requires a stable direct current…
the image is taken/modified by me (measured the output using a multimeter), was only linked on german part of my Wiki, now also the english-page of “hardware” available
