Banana Pi BPI-R2 Open Source smart router
Banana PI BPI-R2 is a highly integrated multimedia network router;it can be used for high wireless performance, home entertainment,home automation and so on.
BPI-R2 harehare:
BPI-R2 integrate a Quad-code ARM Cortex-A7 MPcore operating up to 1.3GHz, The Router also includes a variety of peripherals, including HDMI TX, MIPI DSI, PCIe2.0, USB2.0 OTG, USB3.0 Port, SATA port,5 Gbps Port Gigabit Ethernet port, 802.11a/b/g/n wifi & BT4.1 onboard, also support 802.11ac/n WLAN connection thru mini PCI-e port
BPI-R2 can run with Android5.1 smoothly, it also can run OpenWRT,Debian,linux,Ubuntu linux, Raspbian and others OS. The size of Banana Pi BPI-R2 same as BPI-R1, it can easily run with the game it support 1080P high definition video output, the GPIO compatible with Raspberry Pi 3
More specs follow below.
- MediaTek MT7623N, Quad-code ARM Cortex-A7
- Mali 450 MP4 GPU
- 2G DDR3 SDRAM
- Mini PCIE interface.
- support SATA interface (option support 2 stat)
- MicroSD slot supports up to 256GB expansion
- 8G eMMC flash (option 16/32/64G)
- MIPI display interface support
- 5 10/100/1000 Mb Ethernet port
- (2) USB 3.0 and (1) USB 2.0 otg port
- 1080P high-definition video playback
- HDMI port and multi-channel audio output
- WIFI&Bluetooth 4.1 with 802.11B/G/N onboard
- Built-in 3.7V Lithium Battery Charging Circuit
- support POE (option)
BPI-R2 Hardware interface:
BPI-R2 BPI wiki page:
http://wiki.banana-pi.org/Banana_Pi_BPI-R2
BPI-R2 wiki by frank :
http://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:start
R2 V1.1 hardware schematic diagram
MTK 7623N datasheet for development board programming guide
google drive download link
Banana pi BPI-R2 source code open on github
easy to buy sample ;
Herbal Aloe Concentrate
Banana pi BPI-R2 Premium Aluminum Enclosure
Banana Pi BPI-R2 Arcylic case
