XGS-PON ONU Stick Transceiver for BPI-R4/BPI-R4 Pro
Product Features
  • Single Fiber XGS-PON ONU Transceiver
  • 1270nm burst-mode 9.953 Gb/s transmitter with DFB laser
  • 1577nm continuous-mode 9.953Gb/s APD-TIA receiver
  • SFP+ package with SC UPC receptacle connector
  • Digital diagnostic monitoring (DDM)with internal calibration
  • 0 to 70°C operating case temperature
  • +3.3V separated power supply, low power dissipation
  • Compliant with SFF-8431/SFF-8472/ GR-468
  • MIL-STD-883 compliant
  • FCC Part 15 Class B/EN55022 Class B (CISPR 22B)/ VCCI Class B compliant
  • Class I laser safety standard IEC-60825 compliant
  • RoHS-6 compliance
Software Features
  • Compliant with ITU-T G.988 OMCI Management
  • Support 4K MAC entries
  • Support IGMPv3/MLDv2 and 512 IP multicast address entries
  • Support advanced data features such as VLAN tag manipulation, classification and filtering
  • Support“Plug-and-play”via auto-discovery and Configuration
  • Support Rogue ONU Detecting
  • Data transferring at wire-speed for all packet size
  • Support Jumbo frames up to 9840 Bytes
General Description
The XGS-PON ONU stick transceiver is an Optical Network Terminal (ONT) with Small Form-factor Pluggable (SFP+) packaging. The XGS-PON ONU stick integrates a bi-directional (max 10Gbit/s) optical transceiver function and 2nd layer function. By being plugged into the customer premise equipment (CPE) with standard SFP port directly, the XGS-PON ONU stick provides multi-protocol link to the CPE without requiring separate power Supply.
The transmitter designed for single mode fiber and operates at wavelength of 1270nm. The transmitter uses a DFB laser diode and fully compliant with IEC-60825 and CDRH class 1 eye safety. It contains APC functions, a temperature compensation circuit to ensure compliance with ITU-T G.9807 requirements at operating temperature.
The receiver section uses a hermetic packaged APD-TIA (APD with trans-impedance amplifier) and a limiting amplifier. The APD converts optical power into electrical current and the current is transformed to voltage by the trans-impedance amplifier. The differential signals are produced by the limiting amplifier. The APD-TIA is AC coupled to the limiting amplifier through a low pass filter.
The XGS-PON ONU stick supports a sophisticated ONT management system, including alarms, provisioning, DHCP and IGMP functions for a stand-alone IPTV solution at the ONT. It can be managed from the OLT using G.988 OMCI.
taobao shop: https://item.taobao.com/item.htm?ft=t&id=1010609068015
BPI shop: XGS-PON ONU Stick Transceiver for BPI-R4 Pro
SINOVOIP aliexpress shop: https://www.aliexpress.com/item/1005010719954314.html
BIPAI aliexpress shop: https://pl.aliexpress.com/item/1005010720260460.html?gatewayAdapt=glo2pol
can you share details related to the SOC running on it and maybe attach a tech sheet please?
What OS is it running?
regards
update:
Doc is private, can’t access
Good evening @sinovoip bpi team leader
Could you please grant me access to the document?
Thank you very much
sorry ,please try again
Good morning, thank you very much, @Sinovoip BPI Team Leader.
I’ll buy it soon so I have a backup and can check how it works. Mine has an OpenWRT installer, version WAS-110, which allows me to install two different partition images and boot from either one.
All the information is in my repository: GitHub - brudalevante/8311-was-110-firmware-builder
Regards, and thanks for the document.
Does it support “old” GPON (2.5G) gpon networks?
Could be possible get this XGSPON SFP+ stick with SC APC connector?
Good afternoon. It obviously uses a fiber optic cable, and I advise you to buy the one I’m telling you about. The quality of the WAS-110
wass-110 H-COM SPP425H-GAB4 A-01
is worlds apart from the Banana Pi R4 they sell. I had to return mine; it didn’t even last a minute and completely fell apart when I removed the fiber optic cable. With the one I’m recommending, that won’t happen, I can guarantee it. Plus, with the patch I’ve applied (as shown in my images), it recognizes them immediately and works perfectly.
It also supports XG-GPON and XGS-PON,
My latest images also include the patch so the Banana Pi R4 works perfectly, but the quality—I’m not talking about the software, but the way it’s assembled; the connections are very low quality.
Best regards
