Write to EMMC BPI-R4
Hello every one
I would like to ask for help for install debian11 image to EMMC on BPI-R4
I follow the link below https://docs.banana-pi.org/en/BPI-R4/GettingStarted_BPI-R4#_how_to_burn_image_to_onboard_emmc
I am using openwrt for running NAND and from NAND I execute the commands for dd
All goes well but after reboot and switch from NAND to EMMC , system hult
can any one help with this, because I already develop debian11 as firewall in sdcard and I need to install on EMMC as commercial use
Please note from uboot and copy to emmc it works So I need other way of uboot like dd for example, the reason is debian11 image size is about 7.5G and NAND about 128M only so cannot copy to NAND first because of NAND size limit
Thanks
System halt indicates that bootrom does not find bl2 (needs to be on boot0 partition) or partition conf is not set to use boot0 as bootpartition (mmc partconf in uboot).
Why debian 11? There is already debian 13. Debian 11 is EOL since August 2024.
I also responded on this, but it is an old post, which somehow moved up again.
Ah,ok,did not looked on how old it is,but now there is an answer when someone finds this thread :stuck_out_tongue:
