Write nand from linux error
I haven’t really used nand before, so I thought, give it a try, writing to nand from linux.
[root@bpir3 ~]# cat /boot/dtbos/nand-enable.dts
/dts-v1/;
/plugin/;
&spi0 {
  #address-cells = <1>;
  #size-cells = <0>;
  spi_nand: flash@0 {
    compatible = "spi-nand";
    reg = <0>;
    spi-max-frequency = <10000000>;
    spi-tx-buswidth = <4>;
    spi-rx-buswidth = <4>;
    partitions {
      compatible = "fixed-partitions";
      #size-cells = <1>;
      partition@0 {
        label = "bl2";
        reg = <0x0 0x200000>;
//      read-only;
      partition@200000 {
        label = "ubi";
        reg = <0x200000 0x7a80000>;
[root@bpir3 ~]# cat /proc/mtd
dev:    size   erasesize  name
mtd0: 07a80000 00020000 "ubi"
mtd1: 00200000 00020000 "bl2"
[root@bpir3 ~]# uname -a
Linux bpir3 6.14.7-bpi #15 SMP PREEMPT Mon May 19 04:07:16 UTC 2025 aarch64 GNU/Linux
Somehow they are in reverse order, but I see no problem there…
[root@bpir3 ~]# dmesg | grep spi
[    2.942816] spi-nand spi0.0: Winbond SPI NAND was found.
[    2.948171] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[    2.962687] 2 fixed-partitions partitions found on MTD device spi0.0
[    2.969152] Creating 2 MTD partitions on "spi0.0":
[root@bpir3 ~]# dmesg | grep -i nand
[    1.693575] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    6.816889] mtdblock: MTD device 'ubi' is NAND, please consider using UBI block devices instead.
[    9.299055] mtdblock: MTD device 'bl2' is NAND, please consider using UBI block devices instead.
[   15.520377] mtdblock: MTD device 'ubi' is NAND, please consider using UBI block devices instead.
[   15.556748] mtdblock: MTD device 'bl2' is NAND, please consider using UBI block devices instead.
[root@bpir3 ~]# dmesg | grep mtd
[    6.527979] mtdblock: MTD device 'ubi' is NAND, please consider using UBI block devices instead.
[    9.009387] mtdblock: MTD device 'bl2' is NAND, please consider using UBI block devices instead.
[    9.264195] I/O error, dev mtdblock1, sector 1008 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[    9.275279] I/O error, dev mtdblock1, sector 1008 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[    9.284142] Buffer I/O error on dev mtdblock1, logical block 126, async page read
[   15.159296] mtdblock: MTD device 'ubi' is NAND, please consider using UBI block devices instead.
[   15.183431] mtdblock: MTD device 'bl2' is NAND, please consider using UBI block devices instead.
Whoops
[root@bpir3 ~]# dd if=/openwrt-23.05.2-mediatek-filogic-bananapi_bpi-r3-snand-preloader.bin of=/dev/mtdblock1
[  134.322219] mtdblock: MTD device 'bl2' is NAND, please consider using UBI block devices instead.
[  134.333230] I/O error, dev mtdblock1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
dd: writing to '/dev/mtdblock1': Input/output error
1+0 records in
0+0 records out
0 bytes copied, 0.0109003 s, 0.0 kB/s
But:
[root@bpir3 ~]# nandwrite -p /dev/mtd1 /openwrt-23.05.2-mediatek-filogic-bananapi_bpi-r3-snand-preloader.bin
Writing data to block 0 at offset 0x0
Writing data to block 1 at offset 0x20000
Bad block at 20000, 1 block(s) will be skipped
Writing data to block 2 at offset 0x40000
Bad block at 40000, 1 block(s) will be skipped
Writing data to block 3 at offset 0x60000
But this did not succeed, bootrom sees nothing valid on nand.
I’ve even put u-boot in the bootchain (without it was at one time a problem with emmc), but it is still the same.
EDIT:
I have build u-boot myself, but it seems MTD configs options are not present in the bpi-r3 default config. Therefore, u-boot is not touching the spi-nand hardware anyway. I’ll change the PKGBUILD for R3 and add all MTD options to try it again with u-boot in the chain. Then I can also try the mtd command from u-boot and see if this works.
Looking at the devicetree’s of the R3 in u-boot and in linux, I noticed a small difference, that might explain the situation, but I have yet to test and check this out.
UBOOT:
	spi_flash_pins: spi0-pins-func-1 {
		mux {
			function = "flash";
			groups = "spi0", "spi0_wp_hold";
		conf-pu {
			pins = "SPI2_CS", "SPI2_HOLD", "SPI2_WP";
			drive-strength = <MTK_DRIVE_8mA>;
			bias-pull-up = <MTK_PUPD_SET_R1R0_00>;
		conf-pd {
			pins = "SPI2_CLK", "SPI2_MOSI", "SPI2_MISO";
			bias-pull-down = <MTK_PUPD_SET_R1R0_00>;
LINUX:
	spi_flash_pins: spi-flash-pins {
		mux {
			function = "spi";
So, this seems to me that in u-boot some pins are being configured with milliamps and pull-ups/pull-downs. I suspect the following:
If this is somehow skipped, because u-boot is not used, or u-boot is not using the spi-nand, then the pins are never configured correctly, so this may be why in linux I’m having trouble.
This is all an assumption from an early investigation, I still need to try-out and test. I do not have that much time for it coming weeks, so it may take quite some time before I can confirm.
I’ve noticed while upstreaming r4 that this property should be spi-rx-bus-width,same for tx. But not yet tested writing from linux,only from uboot where i did not get errors.
Thanks, indeed, that is (also) a problem. Searching on github mainline linux, spi-rx-buswidth only finds the R3 and spi-rx-bus-width finds all other hardware…
I think if the pins need configuration, linux should not depend on u-boot, so the dts in llinux may need to add that. Anyway, I still need to confirm this one time…
I applied both fixes, but still i/o errors.
/dts-v1/;
/plugin/;
#define MTK_PUPD_SET_R1R0_00 100
&spi_flash_pins {
    conf-pu {
      drive-strength = <8>;
    conf-pd {
&spi0 {
  #size-cells = <0>;
  spi_nand: flash@0 {
    reg = <0>;
    spi-tx-bus-width = <4>;
    spi-rx-bus-width = <4>;
    partitions {
      #size-cells = <1>;
      partition@0 {
        label = "bl2";
//      read-only;
      partition@200000 {
        label = "ubi";
So my NAND was in bad shape, bad blocks, also the very first block. But that was fixed within uboot with mtd erase.dontskipbad, erasing the entire nand. Then I was able to write a file to the nand within u-boot. This got rid of the i/o errors in linux.
But:
Trying to write in linux, it does not always work. I boot u-boot with distro_boot, which does not access the nand. So when booting, even with u-boot in the chain, I write a file in linux, but then reading it back, there is a difference.
Then I reboot, interrupt u-boot and enter the command mtd list and continue boot with run bootcmd. Now when I write to nand and read it back, there is no difference.
So u-boot is still doing something when the mtd list command is called, that ‘fixes’ writing to mtdblock1 from linux
[root@bpir3 ~]# stat /openwrt-23.05.2-mediatek-filogic-bananapi_bpi-r3-snand-preloader.bin
  File: /openwrt-23.05.2-mediatek-filogic-bananapi_bpi-r3-snand-preloader.bin
  Size: 205560          Blocks: 408        IO Block: 4096   regular file
Device: 179,3   Inode: 266736      Links: 1
Access: (0644/-rw-r--r--)  Uid: (    0/    root)   Gid: (    0/    root)
Access: 2025-05-20 11:53:14.000000000 +0200
Modify: 2025-05-20 11:52:54.000000000 +0200
Change: 2025-05-20 11:53:14.109532325 +0200
 Birth: -
[root@bpir3 ~]# dd of=/dev/mtdblock1 if=/openwrt-23.05.2-mediatek-filogic-bananapi_bpi-r3-snand-preloader.bin
[  571.736433] mtdblock: MTD device 'bl2' is NAND, please consider using UBI block devices instead.
401+1 records in
401+1 records out
205560 bytes (206 kB, 201 KiB) copied, 0.398897 s, 515 kB/s
[root@bpir3 ~]# dd if=/dev/mtdblock1 of=/dump.bin ; truncate --size=205560 /dump.bin
[  596.849029] mtdblock: MTD device 'bl2' is NAND, please consider using UBI block devices instead.
4096+0 records in
4096+0 records out
2097152 bytes (2.1 MB, 2.0 MiB) copied, 2.44648 s, 857 kB/s
[root@bpir3 ~]# diff /dump.bin /openwrt-23.05.2-mediatek-filogic-bananapi_bpi-r3-snand-preloader.bin
Binary files /dump.bin and /openwrt-23.05.2-mediatek-filogic-bananapi_bpi-r3-
snand-preloader.bin differ
But if I do the same with mtd list run from u-boot, then I do not have a difference in the binary files.
Maybe @hackpascal has an idea? As we are planning moving linux dts to of_upstream (still on my list,but first we need mt7988 linux dts) the nand access in linux should not depend on settings done by uboot
Currently I only stick to the linux kernel from openwrt (more precisely, 6.6). With u-boot from mtk-openwrt configured with xxxx_spim_nand_rfb_defconfig, all works fine.
Please note that in u-boot pinconf will be applied only if the device itself is being probed. That is, pinconf will be applied at the first time spi-nand driver initializes it.
The default config in mtk-openwrt/u-boot will have environment configured in ubi and the spi-nand will be initialized during u-boot booting.
I don’t know the exact config of the u-boot @ericwoud is using. Maybe it’s being configured without environment, or from other devices like emmc? If so, spi-nand will not be initialized during u-boot stage and all pinconfs will thus not be applied.
I use linux-rolling-stable (6.14.7) and the latest u-boot stable 2025.04. R3 sd defconfig.
The thing is, it should not matter what u-boot does or does not do. The linux driver should function correctly no matter what u-boot does. That is the linux kernel philosophy. But now it does not always do so.
When I boot with or without the mtd list command, so with or without pinctrl config of the spi-nand, I see no difference (I already added the missing pinctrl dts nodes to the linux devicetree)
cat /sys/kernel/debug/pinctrl/1001f000.pinctrl-pinctrl_moore/pinconf-pins
Is the same in both cases.
Also
cat /sys/kernel/debug/clk/clk_summary
Is the same.
So perhaps there is a hardware register not being initialized in the linux driver, or something like that?
Have you compared spi settings? Speed,buswidth,…
These debugfs entries could help to show if pins are really right and mapped to device(-driver):
# cat /sys/kernel/debug/gpio
# cat /sys/kernel/debug/pinctrl/pinctrl-handles
If i understand correctly,nand is always detected,but write fails at some point,right?
Thanks, I will check that.
Without mtd list in u-boot, the linux kernel does nor write correctly to nand. Reading seems no problem, as I can verify a preveously written file ok.
I’ll look deeper in to it, when I can.
EDIT:
/sys/kernel/debug/gpio only shows pins set to gpio, pinconf-pins shows all pins. Anyway, both commands there is no difference.
I just checked again, booting without mtd list I can read the nand ok. Only writing is trouble.
It seems an addressing issue: always bytes xxx000 - to xxx7ff are written ok, and xxx800 - xxxfff are written as 0xff. Mostly then, also the start is wrong…
Read back ok:
0000000 5053 4e49 4e41 2144 0001 0000 0010 0000
0000010 0800 0000 0040 0000 0040 000c 0000 3020
0000020 0001 0000 00ff 0000 0000 0000 0000 0000
0000030 0000 0000 0000 0000 0000 0000 0000 0000
0000040 0000 0000 0000 0000 0000 0000 0000 5e9a
0000050 ffff ffff ffff ffff ffff ffff ffff ffff
0000060 ffff ffff ffff ffff ffff ffff ffff ffff
0000070 ffff ffff ffff ffff ffff ffff ffff ffff
0000080 ffff ffff ffff ffff ffff ffff ffff ffff
0000090 ffff ffff ffff ffff ffff ffff ffff ffff
00000a0 ffff ffff ffff ffff ffff ffff ffff ffff
00000b0 ffff ffff ffff ffff ffff ffff ffff ffff
00000c0 ffff ffff ffff ffff ffff ffff ffff ffff
00000d0 ffff ffff ffff ffff ffff ffff ffff ffff
00000e0 ffff ffff ffff ffff ffff ffff ffff ffff
00000f0 ffff ffff ffff ffff ffff ffff ffff ffff
0000100 ffff ffff ffff ffff ffff ffff ffff ffff
0000110 ffff ffff ffff ffff ffff ffff ffff ffff
0000120 ffff ffff ffff ffff ffff ffff ffff ffff
0000130 ffff ffff ffff ffff ffff ffff ffff ffff
0000140 ffff ffff ffff ffff ffff ffff ffff ffff
0000150 ffff ffff ffff ffff ffff ffff ffff ffff
0000160 ffff ffff ffff ffff ffff ffff ffff ffff
0000170 ffff ffff ffff ffff ffff ffff ffff ffff
0000180 ffff ffff ffff ffff ffff ffff ffff ffff
0000190 ffff ffff ffff ffff ffff ffff ffff ffff
00001a0 ffff ffff ffff ffff ffff ffff ffff ffff
00001b0 ffff ffff ffff ffff ffff ffff ffff ffff
00001c0 ffff ffff ffff ffff ffff ffff ffff ffff
00001d0 ffff ffff ffff ffff ffff ffff ffff ffff
00001e0 ffff ffff ffff ffff ffff ffff ffff ffff
00001f0 ffff ffff ffff ffff ffff ffff ffff ffff
0000200 ffff ffff ffff ffff ffff ffff ffff ffff
0000210 ffff ffff ffff ffff ffff ffff ffff ffff
0000220 ffff ffff ffff ffff ffff ffff ffff ffff
0000230 ffff ffff ffff ffff ffff ffff ffff ffff
0000240 ffff ffff ffff ffff ffff ffff ffff ffff
0000250 ffff ffff ffff ffff ffff ffff ffff ffff
0000260 ffff ffff ffff ffff ffff ffff ffff ffff
0000270 ffff ffff ffff ffff ffff ffff ffff ffff
0000280 ffff ffff ffff ffff ffff ffff ffff ffff
0000290 ffff ffff ffff ffff ffff ffff ffff ffff
00002a0 ffff ffff ffff ffff ffff ffff ffff ffff
00002b0 ffff ffff ffff ffff ffff ffff ffff ffff
00002c0 ffff ffff ffff ffff ffff ffff ffff ffff
00002d0 ffff ffff ffff ffff ffff ffff ffff ffff
00002e0 ffff ffff ffff ffff ffff ffff ffff ffff
00002f0 ffff ffff ffff ffff ffff ffff ffff ffff
0000300 ffff ffff ffff ffff ffff ffff ffff ffff
0000310 ffff ffff ffff ffff ffff ffff ffff ffff
0000320 ffff ffff ffff ffff ffff ffff ffff ffff
0000330 ffff ffff ffff ffff ffff ffff ffff ffff
0000340 ffff ffff ffff ffff ffff ffff ffff ffff
0000350 ffff ffff ffff ffff ffff ffff ffff ffff
0000360 ffff ffff ffff ffff ffff ffff ffff ffff
0000370 ffff ffff ffff ffff ffff ffff ffff ffff
0000380 ffff ffff ffff ffff ffff ffff ffff ffff
0000390 ffff ffff ffff ffff ffff ffff ffff ffff
00003a0 ffff ffff ffff ffff ffff ffff ffff ffff
00003b0 ffff ffff ffff ffff ffff ffff ffff ffff
00003c0 ffff ffff ffff ffff ffff ffff ffff ffff
00003d0 ffff ffff ffff ffff ffff ffff ffff ffff
00003e0 ffff ffff ffff ffff ffff ffff ffff ffff
00003f0 ffff ffff ffff ffff ffff ffff ffff ffff
0000400 ffff ffff ffff ffff ffff ffff ffff ffff
0000410 ffff ffff ffff ffff ffff ffff ffff ffff
0000420 ffff ffff ffff ffff ffff ffff ffff ffff
0000430 ffff ffff ffff ffff ffff ffff ffff ffff
0000440 ffff ffff ffff ffff ffff ffff ffff ffff
0000450 ffff ffff ffff ffff ffff ffff ffff ffff
0000460 ffff ffff ffff ffff ffff ffff ffff ffff
0000470 ffff ffff ffff ffff ffff ffff ffff ffff
0000480 ffff ffff ffff ffff ffff ffff ffff ffff
0000490 ffff ffff ffff ffff ffff ffff ffff ffff
00004a0 ffff ffff ffff ffff ffff ffff ffff ffff
00004b0 ffff ffff ffff ffff ffff ffff ffff ffff
00004c0 ffff ffff ffff ffff ffff ffff ffff ffff
00004d0 ffff ffff ffff ffff ffff ffff ffff ffff
00004e0 ffff ffff ffff ffff ffff ffff ffff ffff
00004f0 ffff ffff ffff ffff ffff ffff ffff ffff
0000500 ffff ffff ffff ffff ffff ffff ffff ffff
0000510 ffff ffff ffff ffff ffff ffff ffff ffff
0000520 ffff ffff ffff ffff ffff ffff ffff ffff
0000530 ffff ffff ffff ffff ffff ffff ffff ffff
0000540 ffff ffff ffff ffff ffff ffff ffff ffff
0000550 ffff ffff ffff ffff ffff ffff ffff ffff
0000560 ffff ffff ffff ffff ffff ffff ffff ffff
0000570 ffff ffff ffff ffff ffff ffff ffff ffff
0000580 ffff ffff ffff ffff ffff ffff ffff ffff
0000590 ffff ffff ffff ffff ffff ffff ffff ffff
00005a0 ffff ffff ffff ffff ffff ffff ffff ffff
00005b0 ffff ffff ffff ffff ffff ffff ffff ffff
00005c0 ffff ffff ffff ffff ffff ffff ffff ffff
00005d0 ffff ffff ffff ffff ffff ffff ffff ffff
00005e0 ffff ffff ffff ffff ffff ffff ffff ffff
00005f0 ffff ffff ffff ffff ffff ffff ffff ffff
0000600 ffff ffff ffff ffff ffff ffff ffff ffff
0000610 ffff ffff ffff ffff ffff ffff ffff ffff
0000620 ffff ffff ffff ffff ffff ffff ffff ffff
0000630 ffff ffff ffff ffff ffff ffff ffff ffff
0000640 ffff ffff ffff ffff ffff ffff ffff ffff
0000650 ffff ffff ffff ffff ffff ffff ffff ffff
0000660 ffff ffff ffff ffff ffff ffff ffff ffff
0000670 ffff ffff ffff ffff ffff ffff ffff ffff
0000680 ffff ffff ffff ffff ffff ffff ffff ffff
0000690 ffff ffff ffff ffff ffff ffff ffff ffff
00006a0 ffff ffff ffff ffff ffff ffff ffff ffff
00006b0 ffff ffff ffff ffff ffff ffff ffff ffff
00006c0 ffff ffff ffff ffff ffff ffff ffff ffff
00006d0 ffff ffff ffff ffff ffff ffff ffff ffff
00006e0 ffff ffff ffff ffff ffff ffff ffff ffff
00006f0 ffff ffff ffff ffff ffff ffff ffff ffff
0000700 ffff ffff ffff ffff ffff ffff ffff ffff
0000710 ffff ffff ffff ffff ffff ffff ffff ffff
0000720 ffff ffff ffff ffff ffff ffff ffff ffff
0000730 ffff ffff ffff ffff ffff ffff ffff ffff
0000740 ffff ffff ffff ffff ffff ffff ffff ffff
0000750 ffff ffff ffff ffff ffff ffff ffff ffff
0000760 ffff ffff ffff ffff ffff ffff ffff ffff
0000770 ffff ffff ffff ffff ffff ffff ffff ffff
0000780 ffff ffff ffff ffff ffff ffff ffff ffff
0000790 ffff ffff ffff ffff ffff ffff ffff ffff
00007a0 ffff ffff ffff ffff ffff ffff ffff ffff
00007b0 ffff ffff ffff ffff ffff ffff ffff ffff
00007c0 ffff ffff ffff ffff ffff ffff ffff ffff
00007d0 ffff ffff ffff ffff ffff ffff ffff ffff
00007e0 ffff ffff ffff ffff ffff ffff ffff ffff
00007f0 ffff ffff ffff ffff ffff ffff ffff ffff
0000800 4d4d 014d 0038 0000 4946 454c 495f 464e
0000810 004f 0000 0001 0000 0001 0102 0d00 0020
0000820 1af8 0003 22f8 0003 0300 0000 0020 0000
0000830 0300 0000 0001 0000 4d4d 014d 000c 0001
0000840 0001 0000 4d4d 034d 0064 0007 1190 0000
0000850 0000 0000 0000 0000 0000 0000 0000 0000
0000860 0000 0000 0000 0000 0000 0000 0000 0000
0000870 0000 0000 0000 0000 0000 0000 0000 0000
0000880 0000 0000 0000 0000 0000 0000 0000 0000
0000890 0000 0000 0000 0000 6400 0000 1388 0000
00008a0 0000 0000 0000 0000 4d4d 014d 0214 0003
00008b0 0000 0000 0000 0000 0000 0000 0000 0000
00008c0 0000 0000 0000 0000 0000 0000 0000 0000
00008d0 0000 0000 0000 0000 0000 0000 0000 0000
00008e0 0000 0000 0000 0000 0000 0000 0000 0000
00008f0 0000 0000 0000 0000 0000 0000 0000 0000
0000900 0000 0000 0000 0000 0000 0000 0000 0000
0000910 0000 0000 0000 0000 0000 0000 0000 0000
0000920 0000 0000 0000 0000 0000 0000 0000 0000
0000930 0000 0000 0000 0000 0000 0000 0000 0000
0000940 0000 0000 0000 0000 0000 0000 0000 0000
0000950 0000 0000 0000 0000 0000 0000 0000 0000
0000960 0000 0000 0000 0000 0000 0000 0000 0000
0000970 0000 0000 0000 0000 0000 0000 0000 0000
0000980 0000 0000 0000 0000 0000 0000 0000 0000
0000990 0000 0000 0000 0000 0000 0000 0000 0000
00009a0 0000 0000 0000 0000 0000 0000 0000 0000
00009b0 0000 0000 0000 0000 0000 0000 0000 0000
00009c0 0000 0000 0000 0000 0000 0000 0000 0000
00009d0 0000 0000 0000 0000 0000 0000 0000 0000
00009e0 0000 0000 0000 0000 0000 0000 0000 0000
00009f0 0000 0000 0000 0000 0000 0000 0000 0000
0000a00 0000 0000 0000 0000 0000 0000 0000 0000
0000a10 0000 0000 0000 0000 0000 0000 0000 0000
0000a20 0000 0000 0000 0000 0000 0000 0000 0000
0000a30 0000 0000 0000 0000 0000 0000 0000 0000
0000a40 0000 0000 0000 0000 0000 0000 0000 0000
0000a50 0000 0000 0000 0000 0000 0000 0000 0000
0000a60 0000 0000 0000 0000 0000 0000 0000 0000
0000a70 0000 0000 0000 0000 0000 0000 0000 0000
0000a80 0000 0000 0000 0000 0000 0000 0000 0000
0000a90 0000 0000 0000 0000 0000 0000 0000 0000
0000aa0 0000 0000 0000 0000 0000 0000 0000 0000
0000ab0 0000 0000 0000 0000 0000 0000 4d4d 014d
0000ac0 0014 0002 0000 0000 0010 0000 0080 0000
0000ad0 4d4d 014d 0030 0008 0003 0000 0000 0000
0000ae0 0000 0000 0000 0000 0000 0000 0000 0000
0000af0 0000 0000 0000 0000 0000 0000 0000 0000
0000b00 03f4 aa00 03f5 aa01 03f6 aa02 03f7 aa03
0000b10 0600 d281 18a0 f2a6 1000 d51e 3fdf d503
0000b20 3f00 1018 c000 d51e 3fdf d503 006e 9400
0000b30 0141 d282 1000 d53e 0000 aa01 1000 d51e
0000b40 3fdf d503 4700 d280 1100 d51e 0000 d290
0000b50 0020 f2a2 0501 d538 ac21 d368 0041 b400
0000b60 0000 b26d 1320 d51e 44ff d503 0000 d2a8
0000b70 0501 d538 1c21 d344 0041 b400 0000 b26c
0000b80 1140 d51e 14f5 9400 0060 3500 00e4 9400
0000b90 0106 9400 0f21 9400 0180 b000 0000 9100
0000ba0 01a1 b000 0021 9100 0021 cb00 0119 9400
0000bb0 0180 d000 0000 9120 01a1 9000 0021 911d
0000bc0 0021 cb00 0121 9400 01a0 b000 0000 9100
0000bd0 01a1 b000 0021 9100 0021 cb00 011b 9400
0000be0 40bf d500 0066 9400 03e0 aa14 03e1 aa15
0000bf0 03e2 aa16 03e3 aa17 01a7 9400 01ab 9400
0000c00 0159 9400 03f4 aa00 0153 9400 871f d50e
0000c10 18c7 9400 8680 a940 4020 d51e 4001 d51e
0000c20 9e86 a944 9684 a943 8e82 a942 8680 a941
0000c30 03e0 d69f 379f d503 3fdf d503 03f1 aa1e
0000c40 0007 9400 00a0 b400 f001 d539 f821 9271
0000c50 0021 b27d f001 d519 0220 d65f 0041 d280
0000c60 003d 1400 03f1 aa1e 0006 9400 0080 b400
0000c70 f201 d539 0021 b268 f201 d519 0220 d65f
0000c80 0061 d280 0034 1400 03f1 aa1e 0006 9400
0000c90 0080 b400 f201 d539 0021 b254 f201 d519
0000ca0 0220 d65f 0061 d280 0030 1400 03f3 aa1e
0000cb0 0025 9400 03f2 aa00 03e0 aa12 ffe0 97ff
0000cc0 03e0 aa12 ffe8 97ff 03e0 aa12 ffef 97ff
0000cd0 f220 d539 0000 b27a f220 d519 3fdf d503
0000ce0 0260 d65f 03f3 aa1e 011e 9400 0006 9400
0000cf0 0402 f940 03fe aa13 0042 b400 0040 d61f
0000d00 03c0 d65f 0002 d538 fe03 d29f e003 f2bf
0000d10 0042 0a03 f0e5 1017 0000 d280 eea4 1017
0000d20 009f eb05 00e0 5400 0481 f844 0021 0a03
0000d30 003f 6b02 ff61 54ff 0080 d101 03c0 d65f
0000d40 03c0 d65f 0001 d538 5c20 d350 0c20 b340
0000d50 03c0 d65f 0022 d280 0003 d280 001f eb01
0000d60 9040 9a83 03c0 d65f 0022 d280 0003 d280
0000d70 001f eb01 2040 9a83 03c0 d65f 0180 d000
0000d80 0000 9120 001f 9100 03c0 d65f 0580 b400
0000d90 0561 3400 0542 3400 041f b900 0064 5280
0000da0 1004 b900 00e4 5280 0804 b900 007f 6b1f
0000db0 00a1 5400 4003 5298 0023 72a0 005f 6b03
0000dc0 016d 5400 0063 5280 2403 b900 0423 5100
0000dd0 5c44 5318 0063 0b04 0863 1ac4 7c62 1b02
0000de0 0421 0b42 0821 1ac2 0006 1400 241f b900
0000df0 0c21 0b02 6c42 531c 0823 1ac2 0021 5280
0000e00 1062 5280 0c02 b900 1c62 1200 0002 b900
0000e10 3c63 5308 0403 b900 0062 5280 0c02 b900
0000e20 0423 5100 2803 b900 0821 5100 7c21 1301
0000e30 2c01 b900 0020 5280 03c0 d65f 03e0 2a1f
0000e40 03c0 d65f 1401 b940 0061 3600 0000 b940
0000e50 03c0 d65f 0000 1280 03c0 d65f 281f 7100
0000e60 00e1 5400 1422 b940 0442 121b 805f 7101
0000e70 ffa1 54ff 01a2 5280 0022 b900 1422 b940
0000e80 0442 121b 805f 7101 ffa1 54ff 0020 b900
0000e90 03c0 d65f 1401 b940 0421 121b 803f 7101
0000ea0 ffa1 54ff 03e0 2a1f 03c0 d65f 1400 f940
0000eb0 ffe5 17ff 1421 f940 ffe9 17ff 1400 f940
0000ec0 fff5 17ff 03e7 aa1e 03e6 aa04 0266 b400
0000ed0 14c0 f900 0061 3400 ffad 97ff 01e0 b400
0000ee0 03e0 aa06 03fe aa07 0001 9000 d021 910e
0000ef0 0801 f900 0001 9000 b021 910e 0c01 f900
0000f00 0001 9000 f021 910e 1001 f900 00a1 d280
0000f10 0401 f900 17b0 1400 00e0 d65f 0000 1400
0000f20 0000 d284 2000 f2a2 4001 d28b 4c41 f2a0
0000f30 4002 d298 0022 f2a0 0023 d280 ff94 17ff
0000f40 0001 d284 2001 f2a2 ffc5 17ff 0000 d284
0000f50 2000 f2a2 ffd0 17ff 03e3 aa1e 1480 3840
0000f60 0060 b400 fff7 97ff fffd 17ff 0060 d65f
0000f70 0805 d280 03e3 aa1e 10a5 d100 2480 9ac5
0000f80 0c00 9240 281f f100 0043 5400 9c00 9100
0000f90 c000 9100 ffeb 97ff ff05 b5ff 0060 d65f
0000fa0 0140 d280 ffe7 17ff 03e6 aa1e ffdd 97ff
0000fb0 0100 b400 2b44 7014 ffe8 97ff 03e4 aa06
0000fc0 1084 d100 ffeb 97ff fff6 97ff ffe0 97ff
0000fd0 03fe aa06 0064 1400 01a1 b400 0023 d53b
0000fe0 4c63 d350 0082 d280 2042 9ac3 0001 8b01
0000ff0 0443 d100 0000 8a23 7e20 d50b 0000 8b02
0001000 001f eb01 ffa3 54ff 3f9f d503 03c0 d65f
0001010 01a1 b400 0023 d53b 4c63 d350 0082 d280
0001020 2042 9ac3 0001 8b01 0443 d100 0000 8a23
0001030 7620 d508 0000 8b02 001f eb01 ffa3 54ff
0001040 3f9f d503 03c0 d65f 0002 8b01 0030 1400
0001050 0002 8b01 00e3 d53b 0c63 d340 0085 d280
0001060 20a3 9ac3 003f eb03 0523 5400 0461 d100
0001070 001f ea01 0260 5400 0004 aa01 0484 9100
0001080 0464 b400 009f eb02 0428 5400 0c1f f240
0001090 00e0 5400 0c05 b240 04a5 9100 0385 b400
00010a0 141f 3800 001f eb05 ffc1 54ff 001f eb04
00010b0 0082 5400 7c1f a881 001f eb04 ffc3 54ff
00010c0 0044 8a21 001f eb04 00a2 5400 7420 d50b
00010d0 0000 8b03 001f eb04 ffa3 54ff ec44 927c
00010e0 001f eb04 0082 5400 7c1f a881 001f eb04
00010f0 ffc3 54ff 001f eb02 0080 5400 141f 3800
0001100 001f eb02 ffc1 54ff 03c0 d65f 0c1f f240
0001110 fe60 54ff 0c04 b240 0484 9100 fec4 b4ff
0001120 009f eb02 fe82 54ff 141f 3800 001f eb04
0001130 ffc1 54ff ffea 17ff 00a1 d280 1000 d53e
0001140 0000 8a21 1000 d51e 3fdf d503 3f9f d503
0001150 03c0 d65f 00a1 d282 fff9 17ff 03c0 d65f
0001160 03c0 d65f 207f d503 ffff 17ff 0600 d2a0
0001170 1040 d518 03c0 d65f 0000 5280 03c0 d65f
0001180 7bfd a9bd 03fd 9100 53f3 a901 13f5 f900
0001190 0d9f 9400 0413 f940 0015 5280 0213 b500
00011a0 0d9c 9400 03f3 aa00 0400 f940 0800 f940
00011b0 0c01 f940 0041 b500 0c13 f900 0d96 9400
00011c0 ffee 97ff 03f4 2a00 05a0 3400 03e1 2a00
00011d0 0140 9000 6400 9109 000d 1400 0660 f940
00011e0 0400 b940 0060 3610 0175 3400 0035 5280
00011f0 0260 b940 0d6d 9400 03f4 2a00 0100 3400
0001200 03e1 2a00 0140 9000 4c00 9107 16c2 9400
0001210 000f 1400 0d8d 9400 fff5 17ff 0661 f940
0001220 0260 b940 0422 b940 0162 3708 1678 9400
0001230 03f4 2a00 0100 3400 0261 b940 03e2 2a00
0001240 0140 9000 0800 9108 16b3 9400 03e0 2a14
0001250 1738 9400 0260 b940 0d5f 9400 03f4 2a00
0001260 00a0 3400 03e1 2a00 0140 9000 a400 9108
0001270 ffe7 17ff 0a73 f940 ffc9 17ff 0660 f940
0001280 53f3 a941 0800 f940 13f5 f940 7bfd a8c3
0001290 03c0 d65f 7bfd a9bf 03fd 9100 0d60 9400
00012a0 7bfd a8c1 132c 1400 7bfd a9be 0141 9000
00012b0 c021 9105 03fd 9100 0bf3 f900 0153 9000
00012c0 3e73 910a 03e0 aa13 1693 9400 03e0 aa13
00012d0 0141 9000 d421 9106 168f 9400 ffa4 97ff
00012e0 0d2d 9400 ffa7 97ff 03f3 aa00 0140 9000
00012f0 6400 910a 1688 9400 03e0 aa13 1685 9400
0001300 16f6 9400 03e0 aa13 0bf3 f940 7bfd a8c2
0001310 fe3d 17ff 7bfd a9be 03fd 9100 0bf3 f900
0001320 03f3 aa02 1702 5280 7c21 9ba2 ff2b 97ff
0001330 03e0 aa13 0201 d280 0bf3 f940 7bfd a8c2
0001340 ff26 17ff 0180 b000 0182 d000 0042 9120
0001350 4001 b946 0180 b000 5c00 f940 ffee 17ff
0001360 0181 b000 1703 d280 4024 b946 0181 b000
0001370 5c22 f940 0001 d280 e042 d102 009f 6b01
0001380 0068 5400 0000 1280 0007 1400 0c26 9b03
0001390 0425 9100 6846 b866 00df 6b00 0061 5400
00013a0 03e0 2a01 03c0 d65f 03e1 aa05 fff4 17ff
00013b0 7bfd a9bf 03fd 9100 ffea 97ff 00e0 37f8
00013c0 0181 b000 1702 5280 5c21 f940 0400 9b22
00013d0 7bfd a8c1 03c0 d65f 0000 d280 fffd 17ff
00013e0 0180 b000 4004 b946 0344 3400 0180 b000
00013f0 0183 d000 4085 d280 5c01 f940 4060 9120
0001400 0205 f2a0 0865 f904 0022 9102 2021 9100
0001410 0003 5280 0402 f900 8025 b85f 0463 1100
0001420 0045 b900 0441 f900 009f 6b03 00c9 5400
0001430 c025 9104 e021 9102 0845 f900 03e2 aa05
0001440 fff6 17ff 0080 5400 e021 9102 fff3 17ff
0001450 0000 d280 03c0 d65f 0180 b000 400a b946
0001460 064a 3400 7bfd a9bf 0180 b000 0303 d2c0
0001470 03fd 9100 5c0b f940 0000 5280 03e1 aa0b
0001480 1022 f940 0442 925d 005f eb03 0421 5400
0001490 0182 d000 6021 9102 0441 f904 0187 d000
00014a0 40a1 d280 0201 f2a0 0008 d280 00e1 f904
00014b0 0009 5280 170c 5280 7c00 9bac 03e2 aa08
00014c0 0161 8b00 6028 9102 6960 b860 9820 b900
00014d0 2020 9100 0500 f900 8020 9100 0900 f900
00014e0 0042 b400 0c48 f900 7820 b940 041f 3100
00014f0 00a0 5400 0529 1100 ff9a 97ff 015f 6b09
0001500 fdc1 54ff 00e0 9120 7bfd a8c1 03c0 d65f
0001510 0400 1100 e021 9102 015f 6b00 fb21 54ff
0001520 0000 5280 ffde 17ff 0000 d280 03c0 d65f
0001530 0183 d000 2060 f904 0180 d000 4001 b90d
0001540 0180 d000 1c02 f904 03c0 d65f 0182 d000
0001550 8041 9120 0003 f940 1043 f904 0402 f940
0001560 0422 f900 0802 f940 0822 f900 0181 d000
0001570 2021 f944 0401 f900 0181 d000 4021 b94d
0001580 1401 b900 03c0 d65f 7bfd a9bd 03fd 9100
0001590 0404 f940 53f3 a901 1001 b940 03f3 aa00
00015a0 0180 d000 8002 9120 1000 f944 0260 f900
00015b0 0440 f940 0660 f900 03e4 a902 0180 d000
00015c0 4084 8b21 4005 b94d 0180 d000 0843 f940
00015d0 0a63 f900 1c06 f944 00a5 4b01 fc63 d360
00015e0 a3e2 9100 03e1 2a01 83e0 9100 00c0 d63f
00015f0 03f4 2a00 0120 3400 03e1 2a00 0140 9000
0001600 b400 910a 15c4 9400 03e0 2a14 53f3 a941
0001610 7bfd a8c3 03c0 d65f 0660 f940 17e1 f940
0001620 0021 4b00 1261 b900 fe6c 97ff fff7 17ff
0001630 7bfd a9bd 03fd 9100 13f5 f900 0195 d000
0001640 53f3 a901 03f3 2a00 26a0 f944 0000 f940
0001650 0000 d63f 03f4 2a00 26a1 f944 0420 2941
0001660 0402 d100 0a73 9ba1 0a73 9ac0 0673 9100
0001670 26a0 f944 0000 f940 0000 d63f 0281 4b00
0001680 003f eb13 ff63 54ff 53f3 a941 13f5 f940
0001690 7bfd a8c3 03c0 d65f 7d01 5280 7c00 1b01
00016a0 ffe4 17ff 0181 d000 2420 f904 03c0 d65f
00016b0 0181 d000 2820 f904 03c0 d65f 0080 5280
00016c0 03c0 d65f 0400 f940 0423 a940 fc03 a900
00016d0 0c01 f900 0440 f900 0000 5280 03c0 d65f
00016e0 0400 f940 043f 7100 00e0 5400 0c3f 7100
00016f0 0060 5400 02a0 1280 03c0 d65f 0801 f940
0001700 0042 8b01 0802 f900 0000 5280 fffb 17ff
0001710 041f f900 0000 5280 03c0 d65f 7bfd a9b8
0001720 03fd 9100 73fb a905 041c f940 6bf9 a904
0001730 5bf5 a902 0015 d280 039a f940 53f3 a901
0001740 03f4 aa02 63f7 a903 1356 f940 0fe1 a907
0001750 06c0 d100 33e0 f900 03e0 cb16 37e0 f900
0001760 00b4 b500 3fe0 f940 0015 f900 0000 5280
0001770 001f 1400 0b99 f940 33e0 f940 0742 f940
0001780 0333 8a00 0780 f940 0297 8b13 0339 8b00
0001790 0b39 9ad6 005f eb17 00a3 5400 33e0 f940
00017a0 0002 8b17 37e0 f940 0042 8a00 0044 cb13
00017b0 03f8 aa1a 0080 cb14 029f eb04 3000 9a9f
00017c0 0701 f841 0000 aa13 05c0 b400 0b44 f940
00017d0 03e0 2a19 0080 d63f 37e1 f940 003b 8a00
00017e0 027f eb1b 0123 5400 0080 1280 53f3 a941
00017f0 5bf5 a942 63f7 a943 6bf9 a944 73fb a945
0001800 7bfd a8c8 03c0 d65f 0364 cb13 0080 cb14
0001810 029f eb04 3000 9a9f 0084 cb00 0340 f940
0001820 03e2 aa04 3be1 f940 0260 8b00 02a1 8b01
0001830 943b 9400 0341 f940 03e2 aa1b 0704 f940
0001840 03e0 2a19 0080 d63f 027f eb00 fce2 54ff
0001850 0013 cb13 0b82 f940 0261 cb14 029f eb13
0001860 3021 9a9f 0273 cb01 0021 cb00 0042 8b13
0001870 02b5 8b13 0034 8b17 0b82 f900 ffb9 17ff
0001880 03fb aa04 ffe6 17ff 7bfd a9b8 03fd 9100
0001890 6bf9 a904 041a f940 5bf5 a902 53f3 a901
00018a0 03f3 aa02 0359 f940 63f7 a903 73fb a905
00018b0 001c d280 1335 f940 8fe1 a906 06b7 d100
00018c0 03f8 cb15 0173 b500 3be0 f940 001c f900
00018d0 0000 5280 53f3 a941 5bf5 a942 63f7 a943
00018e0 6bf9 a944 73fb a945 7bfd a8c8 03c0 d65f
00018f0 8341 a940 0722 f940 0003 8a17 0000 8b01
0001900 0276 8b03 0800 9ad5 005f eb16 0063 5400
0001910 02e2 8b16 0042 8a18 0321 f940 3fe3 f900
0001920 0b26 f940 00c0 d63f 3fe3 f940 007f eb00
0001930 0262 5400 0002 cb03 027f eb02 0054 cb13
0001940 3294 9a9f 0321 f940 0053 cb14 0294 cb00
0001950 03e2 aa13 37e0 f940 0061 8b01 0380 8b00
0001960 93ef 9400 0b40 f940 039c 8b13 0000 8b13
0001970 0293 8b16 0b40 f900 ffd3 17ff 0080 1280
0001980 ffd5 17ff 7bfd a9be 0181 d000 03fd 9100
0001990 0bf3 f900 03f3 aa00 0400 f940 3421 f944
00019a0 0002 f940 005f eb01 01c1 5400 0401 d280
00019b0 fda6 97ff 03e0 aa13 0201 d280 fda3 97ff
00019c0 0181 d000 4420 b94d 0400 5100 4420 b90d
00019d0 0000 5280 0bf3 f940 7bfd a8c2 03c0 d65f
00019e0 0020 1280 fffc 17ff 0185 d000 44a2 b94d
00019f0 0182 3500 0184 d000 0186 d000 60c3 9121
0001a00 a087 9121 3488 f944 0122 d000 c042 9112
0001a10 1c62 a900 00a8 b400 0020 5280 44a0 b90d
0001a20 0020 1280 03c0 d65f 3480 f904 0022 5280
0001a30 0000 5280 44a2 b90d 0023 f900 fffa 17ff
0001a40 7bfd a9be 03fd 9100 0bf3 f900 03f3 aa00
0001a50 0180 d000 6000 9121 0104 9400 0080 3500
0001a60 0121 d000 e021 9113 0261 f900 0bf3 f940
0001a70 7bfd a8c2 03c0 d65f 0060 5280 03c0 d65f
0001a80 0400 f940 1000 f940 0020 f900 0000 5280
0001a90 03c0 d65f 7bfd a9be 0181 d000 03fd 9100
0001aa0 0bf3 f900 03f3 aa00 e020 9122 0c01 f940
0001ab0 0061 b400 0601 d280 fd64 97ff 067f f900
0001ac0 0000 5280 0bf3 f940 7bfd a8c2 03c0 d65f
0001ad0 7bfd a9bb 03e3 aa01 03fd 9100 53f3 a901
0001ae0 0194 d000 0193 d000 a282 9122 c261 9122
0001af0 13f5 f900 0415 f940 03e0 2a03 0b0c 9400
0001b00 00e0 3400 0033 1280 13f5 f940 03e0 2a13
0001b10 53f3 a941 7bfd a8c5 03c0 d65f 5681 f944
0001b20 c3e2 9100 5a60 f944 00ee 9400 fec0 35ff
0001b30 1be0 f940 e3e3 9100 03e1 9101 0202 d280
0001b40 012d 9400 03f3 2a00 0140 3500 43e1 b940
0001b50 0020 5280 4c80 72b5 003f 6b00 0101 5400
0001b60 47e0 b940 00c0 3400 4fe0 b940 12a0 7900
0001b70 1be0 f940 0128 9400 ffe4 17ff 0033 1280
0001b80 fffc 17ff 7bfd a9bc 03fd 9100 53f3 a901
0001b90 03f4 aa00 0180 b000 03f3 aa01 5bf5 a902
0001ba0 03f6 aa02 5401 f944 0180 b000 03f5 aa03
0001bb0 e3e2 9100 5800 f944 00ca 9400 03c0 3500
0001bc0 0694 f940 0021 5280 0e80 f940 0282 b940
0001bd0 0042 8b00 1fe0 f940 00f7 9400 0120 3400
0001be0 0033 1280 1fe0 f940 010b 9400 5bf5 a942
0001bf0 03e0 2a13 53f3 a941 7bfd a8c4 03c0 d65f
0001c00 1fe0 f940 03e1 aa13 c3e3 9100 03e2 aa16
0001c10 00f9 9400 03f3 2a00 fe40 35ff 1be1 f940
0001c20 0280 b940 02a1 f900 0000 0b01 0280 b900
0001c30 ffed 17ff 0033 1280 ffed 17ff 0185 b000
0001c40 48a2 b94d 0182 3500 0184 b000 0186 b000
0001c50 20c3 9122 6087 9122 4c88 f944 0122 b000
0001c60 0042 9114 1c62 a900 00a8 b400 0020 5280
0001c70 48a0 b90d 0160 1280 03c0 d65f 4c80 f904
0001c80 0022 5280 0000 5280 48a2 b90d 0023 f900
0001c90 fffa 17ff 7bfd a9ba 03fd 9100 5bf5 a902
0001ca0 23f9 f900 0199 b000 e335 9122 53f3 a901
0001cb0 63f7 a903 0ea0 f940 0600 b500 0180 b000
0001cc0 03f8 aa01 03f6 aa02 43e2 9101 5401 f944
0001cd0 0180 b000 5800 f944 0082 9400 0520 3500
0001ce0 2be0 f940 0202 d280 0021 5280 00b2 9400
0001cf0 0300 3500 0194 b000 0137 f000 0294 9123
0001d00 4ef7 910b 2be0 f940 63e3 9101 03e1 aa14
0001d10 0502 d280 00b8 9400 03f3 2a00 01c0 3500
0001d20 03e1 aa18 03e0 aa14 0202 d280 92ef 9400
0001d30 03f3 2a00 02a0 3400 03e1 aa17 03e0 aa14
0001d40 0202 d280 92e9 9400 fde0 35ff 0ebf f900
0001d50 0033 1280 2be0 f940 00af 9400 5bf5 a942
0001d60 03e0 2a13 53f3 a941 63f7 a943 23f9 f940
0001d70 7bfd a8c6 03c0 d65f 02d3 1280 fff8 17ff
0001d80 0033 1280 fff6 17ff bb3f b908 06d5 f900
0001d90 fff1 17ff 0181 b000 0400 f940 583f f904
0001da0 0181 b000 543f f904 0181 b000 4c22 f944
0001db0 0001 f940 005f eb01 0181 5400 7bfd a9bf
0001dc0 0201 d280 03fd 9100 fca0 97ff 0181 b000
0001dd0 7bfd a8c1 4820 b94d 0400 5100 4820 b90d
0001de0 0000 5280 03c0 d65f 0020 1280 03c0 d65f
0001df0 7bfd a9be 03fd 9100 0bf3 f900 03f3 aa00
0001e00 0180 b000 2000 9122 0018 9400 0080 3500
0001e10 0121 b000 2021 9115 0261 f900 0bf3 f940
0001e20 7bfd a8c2 03c0 d65f 0182 b000 a042 9123
0001e30 0001 d280 7843 f861 001f eb03 00a0 5400
0001e40 0421 9100 103f f100 ff61 54ff 03c0 d65f
0001e50 585f f821 0181 b000 5020 b94d 0400 5100
0001e60 5020 b90d fffa 17ff 0181 b000 4c20 b94d
0001e70 081f 7100 00a8 5400 0400 1100 4c20 b90d
0001e80 0000 5280 03c0 d65f 0160 1280 fffe 17ff
0001e90 03e3 aa00 03e0 aa01 03e1 aa02 0063 f940
0001ea0 03f0 aa03 0200 d61f 0002 f940 1c42 f940
0001eb0 0062 b400 03f0 aa02 0200 d61f 0000 5280
0001ec0 03c0 d65f 0001 f940 2021 f940 0061 b400
0001ed0 03f0 aa01 0200 d61f 0000 5280 03c0 d65f
0001ee0 7bfd a9bc 0185 b000 03fd 9100 53f3 a901
0001ef0 03f3 aa00 50a0 b94d 5bf5 a902 1bf7 f900
0001f00 0c1f 7100 0508 5400 0184 b000 03f6 aa02
0001f10 a084 9123 0003 d280 7882 f863 03a2 b400
0001f20 0463 9100 107f f100 ff81 54ff 0003 5280
0001f30 0022 1280 7c77 d37c 0195 b000 22b5 9124
0001f40 0400 1100 02f4 8b15 50a0 b90d 5894 f823
0001f50 02e2 3500 0260 f940 03e2 aa14 0403 f940
0001f60 03e0 aa13 0060 d63f 03e4 2a00 0160 3500
0001f70 6ab3 f837 02d4 f900 53f3 a941 03e0 2a04
0001f80 5bf5 a942 1bf7 f940 7bfd a8c4 03c0 d65f
0001f90 0002 5280 ffe8 17ff 03e0 aa14 ffa3 97ff
0001fa0 fff6 17ff 0164 1280 fff4 17ff 0024 1280
0001fb0 fff2 17ff 0003 f940 0063 f940 0863 f940
0001fc0 0063 b400 03f0 aa03 0200 d61f 0240 1280
0001fd0 03c0 d65f 0002 f940 0042 f940 0c42 f940
0001fe0 0062 b400 03f0 aa02 0200 d61f 0240 1280
0001ff0 03c0 d65f 0004 f940 0084 f940 1084 f940
0002000 0064 b400 03f0 aa04 0200 d61f 0240 1280
0002010 03c0 d65f 7bfd a9be 03fd 9100 0001 f940
0002020 0021 f940 1821 f940 0bf3 f900 03f3 aa00
0002030 0121 b400 0020 d63f 03e4 2a00 03e0 aa13
0002040 ff7a 97ff 0bf3 f940 03e0 2a04 7bfd a8c2
0002050 03c0 d65f 0004 5280 fff9 17ff 0182 d000
0002060 a042 9113 0002 f900 0000 d282 0020 f900
0002070 03c0 d65f 7bfd a9b8 03fd 9100 63f7 a903
0002080 03f7 aa01 0181 b000 5bf5 a902 03f8 aa03
0002090 4835 b949 53f3 a901 0454 d100 4294 8b20
00020a0 6bf9 a904 203a 9125 03e1 2a15 73fb a905
00020b0 03f3 aa02 0a94 9ac1 0741 b940 081b 1ad5
00020c0 081c 1ac1 8376 1b15 0ab5 1ac1 839c 1b01
00020d0 c3e0 9101 0ad6 1ac1 e3e1 9101 ffe0 97ff
00020e0 031f f900 015c 3500 0741 b940 0a60 9ac1
00020f0 cc00 9b01 00c0 b500 7f79 1b15 037f 6b14
0002100 0129 5400 0000 5280 0017 1400 3fe0 f940
0002110 0741 b940 003f eb00 ff09 54ff 02a0 1280
0002120 0011 1400 1b41 f940 03e0 2a1b 0020 d63f
0002130 01a0 37f8 041f 7100 05c1 5400 0b40 f940
0002140 077b 1100 0342 b940 0694 1100 037f 6b14
0002150 2361 1a94 0800 9ac2 003f 6b00 0523 5400
0002160 0080 1280 53f3 a941 5bf5 a942 63f7 a943
0002170 6bf9 a944 73fb a945 7bfd a8c8 03c0 d65f
0002180 1f43 f940 0321 0b16 009c 3500 0740 b940
0002190 001f eb13 03a9 5400 3be2 f940 03e0 aa1a
00021a0 0060 d63f fe00 35ff 0742 b940 03e0 aa17
00021b0 3be1 f940 0042 4b1c 005f eb13 9042 9a93
00021c0 6fe2 b900 4021 8b3c 91d5 9400 6fe3 b940
00021d0 0300 f940 42f7 8b23 4273 eb23 4000 8b23
00021e0 0300 f900 01e0 5400 06d6 1100 001c 5280
00021f0 02df 6b15 fc63 54ff 077b 1100 0016 5280
0002200 0339 0b15 ffbe 17ff 03e2 aa17 03e0 aa1a
0002210 0060 d63f fa80 35ff 0743 b940 ffed 17ff
0002220 001c 5280 fff5 17ff 0180 b000 2000 9125
0002230 03c0 d65f 0800 5ac0 03c0 d65f 1c00 1200
0002240 1c21 1200 081f 7100 00c0 5400 101f 7100
0002250 0180 5400 041f 7100 17e0 1a9f 03c0 d65f
0002260 0180 b000 9000 b949 0081 3500 041f 7218
0002270 07e0 1a9f fffa 17ff 041f 721a fffd 17ff
0002280 0180 b000 003f 7100 9000 b949 2402 d349
0002290 1c00 d347 1000 1a82 fff1 17ff 7bfd a9bd
00022a0 0183 b000 2063 9126 03fd 9100 53f3 a901
00022b0 03f4 aa00 0021 5280 13f5 f900 0875 f940
00022c0 0000 3940 ffde 97ff 1c1f 7200 0500 5400
00022d0 2280 3940 00c0 3400 2680 3940 0021 5280
00022e0 ffd7 97ff 1c1f 7200 0420 5400 6280 3940
00022f0 00c0 3400 6680 3940 0021 5280 ffd0 97ff
0002300 1c1f 7200 0340 5400 2a80 b940 0100 3400
0002310 2680 b940 041f 7100 8280 3940 17e1 1a9f
0002320 ffc7 97ff 1c1f 7200 0220 5400 02a1 f940
0002330 0460 b940 0020 d63f 03f3 2a00 00e0 3500
0002340 12a1 f940 03e0 aa14 0020 d63f 03f3 2a00
0002350 06a0 f940 0000 d63f 13f5 f940 03e0 2a13
0002360 53f3 a941 7bfd a8c3 03c0 d65f 0593 1280
0002370 fffa 17ff 7bfd a9bb 03fd 9100 53f3 a901
0002380 03f3 2a01 5bf5 a902 03f5 aa00 03f6 aa02
0002390 0440 a940 63f7 a903 23f9 f900 0381 b400
00023a0 001f f100 17e0 1a9f 12c1 f940 0221 b400
00023b0 0ac1 f940 01e1 b400 0ec1 f940 01a1 b400
00023c0 0180 3500 03e1 2a13 03e0 aa15 8fbe 9400
00023d0 03e1 2a00 0014 5280 01e1 36f8 069f 7100
00023e0 0240 5400 0120 f000 8c00 910b 124a 9400
00023f0 02a0 1280 53f3 a941 5bf5 a942 63f7 a943
0002400 23f9 f940 7bfd a8c5 03c0 d65f 0020 5280
0002410 ffe6 17ff 03e0 aa15 0694 1100 8fb7 9400
0002420 03e1 2a00 ffed 17ff 03e1 2a13 03e0 aa15
0002430 0138 f000 0197 b000 d419 5290 8fa2 9400
0002440 4318 910c 03f4 2a00 22f7 9126 0013 5280
0002450 0039 72a0 0234 36f8 0180 b000 2013 9126
0002460 8800 b949 0a74 f940 0a81 f940 0020 d63f
0002470 fc20 35ff 0e81 f940 5bf5 a942 03f0 aa01
0002480 63f7 a943 23f9 f940 0a60 b940 53f3 a941
0002490 7bfd a8c5 0200 d61f 03e2 aa18 03e1 2a14
00024a0 03e0 aa15 0003 d280 909e 9400 0080 b500
00024b0 0120 f000 5000 910c ffcd 17ff 0000 b940
00024c0 0122 f000 03e1 2a14 cc42 910c 0003 d280
00024d0 ff59 97ff 02f9 2900 03e0 aa15 9091 9400
00024e0 0080 b400 0000 b940 ff53 97ff 02e0 b900
00024f0 0122 f000 03e1 2a14 1442 910d 03e0 aa15
0002500 0003 d280 9087 9400 0040 b400 0273 321f
0002510 0122 f000 03e1 2a14 3842 910d 03e0 aa15
0002520 0003 d280 907f 9400 0040 b400 0273 3200
0002530 0122 f000 03e1 2a14 5c42 910d 03e0 aa15
0002540 0003 d280 9077 9400 0040 b400 0273 321e
0002550 0122 f000 03e1 2a14 8c42 910d 03e0 aa15
0002560 0003 d280 906f 9400 0040 b400 0273 321c
0002570 0122 f000 03e1 2a14 b442 910d 03e0 aa15
0002580 0003 d280 9067 9400 0040 b400 0273 321b
0002590 0122 f000 03e1 2a14 f442 910d 03e0 aa15
00025a0 0003 d280 905f 9400 0120 b400 0000 b940
00025b0 ff21 97ff 081f 7100 0360 5400 101f 7100
00025c0 0360 5400 041f 7100 f141 54ff 0122 f000
00025d0 03e1 2a14 3842 910e 03e0 aa15 0003 d280
00025e0 9050 9400 0120 b400 0000 b940 ff12 97ff
00025f0 081f 7100 0200 5400 101f 7100 0200 5400
0002600 041f 7100 ef61 54ff 03e1 2a14 03e0 aa15
0002610 0af3 b900 0af6 f900 8f38 9400 03f4 2a00
0002620 ff8d 17ff 0273 321a ffe9 17ff 0273 3219
0002630 ffe7 17ff 0273 3218 fff4 17ff 0273 3217
0002640 fff2 17ff 7bfd a9bd 03e2 aa00 03fd 9100
0002650 53f3 a901 0194 b000 d293 f944 13f5 f900
0002660 0673 d100 0a73 b240 0673 9100 0275 8b00
0002670 0180 b000 d400 f944 001f eb15 0143 5400
0002680 03e0 aa13 0001 5280 90ba 9400 d295 f904
0002690 13f5 f940 03e0 aa13 53f3 a941 7bfd a8c3
00026a0 03c0 d65f 0013 d280 fffa 17ff 7bfd a9b8
00026b0 03fd 9100 23f9 f900 0199 f000 53f3 a901
00026c0 03f4 aa00 a320 3953 5bf5 a902 03f3 aa01
00026d0 03f5 aa02 63f7 a903 03f6 aa05 03f8 aa03
00026e0 03f7 aa04 0080 3500 003e 9400 0020 5280
00026f0 a320 3913 0180 b000 02f6 8b16 0001 5280
0002700 d416 f904 0180 b000 d017 f904 0000 5280
0002710 0732 9400 03f6 aa00 0160 b500 0120 f000
0002720 7c00 910e 117c 9400 0160 1280 53f3 a941
0002730 5bf5 a942 63f7 a943 23f9 f940 7bfd a8c8
0002740 03c0 d65f 0281 f940 7fe1 a905 02a1 f940
0002750 37e1 f900 43e1 9101 33f3 f900 63ff a907
0002760 054f 9400 03e1 2a00 141f 7100 01a1 5400
0002770 0281 f940 03e2 aa13 02a0 f940 9068 9400
0002780 0280 f940 0000 8b13 0280 f900 02a0 f940
0002790 0273 8b00 0000 5280 02b3 f900 ffe4 17ff
00027a0 041f 7100 0141 5400 03e0 aa16 0724 9400
00027b0 0280 f940 2fe1 f940 0000 8b01 0280 f900
00027c0 3be0 f940 02b3 f940 fff2 17ff 0120 f000
00027d0 e800 910e 1150 9400 0080 1280 ffd4 17ff
00027e0 6405 5290 0183 b000 5063 9135 0000 d280
00027f0 b705 72bd 03e1 2a00 0102 5280 0024 9340
0002800 0442 7100 0084 0a05 0481 4a41 ff81 54ff
0002810 7861 b820 0400 9100 001f f104 fec1 54ff
0002820 03c0 d65f 0185 b000 03e2 2a22 50a5 9135
0002830 0004 d280 003f eb04 0061 5400 03e0 2a22
0002840 03c0 d65f 6803 3864 0484 9100 0043 ca03
0002850 1c63 9240 78a3 b863 2062 4a42 fff6 17ff
0002860 0c03 f940 03e6 2a02 407f eb22 04c9 5400
0002870 3003 b940 007f 6b02 0469 5400 0805 f940
0002880 1002 f940 0023 b940 0042 cb05 03e4 2a03
0002890 405f eb23 9042 9a84 0063 4b02 0023 b900
00028a0 04a1 d100 03e4 2a02 0021 cb06 00df eb05
00028b0 0063 5400 1402 f940 0021 8b02 0803 f940
00028c0 0422 9100 0005 f940 0466 9100 0806 f900
00028d0 68a1 3861 68a1 3823 1401 f940 003f eb02
00028e0 1041 9a9f 0484 7100 fea1 54ff 0801 a941
00028f0 005f eb01 0042 5400 0c01 f900 0020 5280
0002900 03c0 d65f 0000 5280 fffe 17ff 0003 b940
0002910 e004 12bf 007f 6b04 0168 5400 5c63 5318
0002920 0003 b900 0c03 f940 0805 f940 0466 9100
0002930 0c06 f900 0404 b940 68a3 3863 2063 0b04
0002940 0403 b900 1003 2940 0025 7940 7c66 530b
0002950 7cc6 1b05 00df 6b04 05e9 5400 0003 5281
0002960 0063 4b05 0006 b900 14a3 0b83 0023 7900
0002970 0083 d280 5062 8b22 0043 5280 0021 8b02
0002980 0106 5280 0024 5280 e00a 12bf 000b 5281
0002990 9003 b900 0002 b940 4429 8b24 005f 6b0a
00029a0 0168 5400 5c42 5318 0002 b900 0c02 f940
00029b0 0807 f940 0448 9100 0c08 f900 0405 b940
00029c0 68e2 3862 2042 0b05 0402 b900 1c08 2940
00029d0 7884 531f 0122 7940 7d05 530b 7ca5 1b02
00029e0 00bf 6b07 06c9 5400 0005 b900 0165 4b02
00029f0 1442 0b85 3c42 1200 0122 7900 00df 6b04
0002a00 fca8 54ff 0063 4b06 0063 0b04 9003 b900
0002a10 03c0 d65f 0063 4b06 0084 4b06 1003 2900
0002a20 14a5 4b45 0025 7900 e005 12bf 007f 6b05
0002a30 0148 5400 5c63 5318 0003 b900 0c03 f940
0002a40 0805 f940 0466 9100 0c06 f900 68a3 3863
0002a50 2064 0b04 0404 b900 1406 2940 0423 7940
0002a60 7cc4 530b 7c84 1b03 009f 6b05 0169 5400
0002a70 0004 b900 0004 5281 0084 4b03 7c42 d37c
0002a80 1042 9104 1463 0b84 0423 7900 0021 8b02
0002a90 0143 5280 ffbb 17ff 00c6 4b04 1463 4b43
0002aa0 00a5 4b04 1406 2900 2006 5280 0423 7900
0002ab0 1021 9108 0243 5280 ffb3 17ff 1442 4b42
0002ac0 0108 4b05 00e7 4b05 3c42 1200 0484 1100
0002ad0 1c08 2900 ffc9 17ff a00d 9100 7bfd a9be
0002ae0 03ec aa00 03fd 9100 09a1 f940 11a0 f940
0002af0 0bf3 f900 003f eb00 00e2 5400 9180 b940
0002b00 00a0 3400 7d82 b940 4181 9102 03e0 aa0d
0002b10 ff54 97ff 418e 9102 e012 12bf 016f 5280
0002b20 0013 5281 09a3 f940 11a1 f940 0180 b940
0002b30 007f eb01 0082 5400 8981 a941 003f eb02
0002b40 00c9 5400 e001 12bf 001f 6b01 4349 5400
0002b50 0020 5280 00f9 1400 9d82 b940 8d85 b940
0002b60 0042 0a03 001f 6b12 0148 5400 5c00 5318
0002b70 0180 b900 0980 f940 0426 9100 0d86 f900
0002b80 0584 b940 6800 3861 2000 0b04 0580 b900
0002b90 7ca6 d37c 03e0 2a05 40c6 8b22 1181 2940
0002ba0 0586 8b06 40c7 7941 7c28 530b 7d08 1b07
0002bb0 011f 6b04 1149 5400 0260 4b07 0188 b900
0002bc0 14e0 0b80 40c0 7901 0460 d100 0783 b500
0002bd0 15a1 f940 0421 d100 0da6 f940 01a7 f940
0002be0 0726 b400 68e1 3861 8988 2952 0104 5280
0002bf0 0042 8a03 0084 4b08 2042 9ac8 2421 1ac4
0002c00 0021 0b02 c002 5280 3021 9ba2 3021 913c
0002c10 18bf 7100 06a8 5400 0020 5280 0182 b940
0002c20 7c08 d37f 005f 6b12 0168 5400 5c42 5318
0002c30 0182 b900 0d82 f940 0985 f940 0446 9100
0002c40 0d86 f900 0584 b940 68a2 3862 2042 0b04
0002c50 0582 b900 1586 2940 7800 531f 6822 7868
0002c60 7cc4 530b 7c84 1b02 009f 6b05 0309 5400
0002c70 0184 b900 0264 4b02 1442 0b84 3c42 1200
0002c80 6822 7828 fc1f 7103 fca9 54ff 0461 9100
0002c90 09a1 f900 68e0 3823 05a0 a941 003f eb00
0002ca0 0042 5400 0da0 f900 8d80 b940 0c1f 7100
0002cb0 08a8 5400 8d9f b900 ff9b 17ff 03e1 aa00
0002cc0 ffc6 17ff 0001 5280 ffc8 17ff 1442 4b42
0002cd0 00c6 4b04 00a5 4b04 3c42 1200 0400 1100
0002ce0 1586 2900 ffe7 17ff 7d82 b940 0000 cb02
0002cf0 007f eb02 0068 5400 15a2 f940 0000 8b02
0002d00 04e6 b400 68ea 3860 794a 531f 2006 5280
0002d10 0020 5280 014b 0a06 00c4 0b00 0084 0b0b
0002d20 0182 b940 794a 531f f884 d37f 005f 6b12
0002d30 0168 5400 5c42 5318 0182 b900 0d82 f940
0002d40 0988 f940 0449 9100 0d89 f900 0585 b940
0002d50 6902 3862 2042 0b05 0582 b900 2189 2940
0002d60 7800 531f 6822 7864 7d25 530b 7ca5 1b02
0002d70 00bf 6b08 0189 5400 0185 b900 0265 4b02
0002d80 00c6 0a2b 1442 0b85 3c42 1200 6822 7824
0002d90 fc1f 7103 fc09 54ff ffbd 17ff 000a 5280
0002da0 ffda 17ff 1442 4b42 0129 4b05 0108 4b05
0002db0 3c42 1200 0400 1100 03e6 2a0b 2189 2900
0002dc0 fff3 17ff 1802 5100 0c01 5100 281f 7100
0002dd0 3020 1a82 8d80 b900 ff53 17ff 0021 4b08
0002de0 0083 4b08 0d81 2900 14e7 4b47 40c7 7901
0002df0 003f 6b12 0148 5400 5c21 5318 0181 b900
0002e00 0d81 f940 0984 f940 0427 9100 0d87 f900
0002e10 6881 3861 2023 0b03 0583 b900 0d81 2940
0002e20 0580 8b00 4004 7944 7c27 530b 7ce7 1b04
0002e30 00ff 6b03 1a29 5400 0261 4b04 18bf 7100
0002e40 0187 b900 1481 0b81 4001 7904 00e1 5280
0002e50 0140 5280 8000 1a81 8d80 b900 8580 b940
0002e60 1181 911c 8980 b900 8180 b940 8580 b900
0002e70 7d80 b940 8180 b900 03e0 aa0c fea4 97ff
0002e80 9180 b940 00a1 5280 141f 7100 9002 1a81
0002e90 0020 5280 0842 5100 2042 9100 e042 d379
0002ea0 0181 b940 4446 8b20 003f 6b12 0168 5400
0002eb0 5c21 5318 0181 b900 0d81 f940 0984 f940
0002ec0 0425 9100 0d85 f900 0583 b940 6881 3861
0002ed0 2021 0b03 0581 b900 1185 2940 7800 531f
0002ee0 6981 7866 7ca3 530b 7c63 1b01 007f 6b04
0002ef0 02a9 5400 0183 b900 0263 4b01 1421 0b83
0002f00 3c21 1200 6981 7826 fc1f 7100 fca9 54ff
0002f10 0000 5101 0c1f 7100 0248 5400 7d80 b900
0002f20 7d82 b940 03e1 aa0e 03e0 aa0d fe4d 97ff
0002f30 1c00 7200 df81 54ff 0bf3 f940 7bfd a8c2
0002f40 03c0 d65f 1421 4b41 00a5 4b03 0084 4b03
0002f50 3c21 1200 0400 1100 1185 2900 ffea 17ff
0002f60 0001 1200 7c02 5301 0821 1100 341f 7100
0002f70 06a8 5400 0445 5100 0023 5280 0187 9118
0002f80 03ea 2a03 2021 1ac5 7d81 b900 4021 cb20
0002f90 0008 5280 e009 12bf 000b 5281 f821 d37f
0002fa0 0821 d100 0180 b940 4430 8b23 001f 6b09
0002fb0 0168 5400 5c00 5318 0180 b900 0d80 f940
0002fc0 0984 f940 0406 9100 0d86 f900 0582 b940
0002fd0 6880 3860 2000 0b02 0580 b900 0186 2940
0002fe0 7863 531f 68e2 7870 7d91 b940 7cc4 530b
0002ff0 7c84 1b02 009f 6b00 0129 5400 0160 4b02
0003000 0184 b900 1440 0b80 68e0 7830 0508 1100
0003010 00bf 6b08 fc88 54ff ffc2 17ff 0000 4b04
Read back not ok:
0000000 ffff ffff ffff ffff ffff ffff ffff ffff
0000010 ffff ffff ffff ffff ffff ffff ffff ffff
0000020 ffff ffff ffff ffff ffff ffff ffff ffff
0000030 ffff ffff ffff ffff ffff ffff ffff ffff
0000040 ffff ffff ffff ffff ffff ffff ffff ffff
0000800 ffff ffff ffff ffff ffff ffff ffff ffff
0000810 ffff ffff ffff ffff ffff ffff ffff ffff
0000820 ffff ffff ffff ffff ffff ffff ffff ffff
0000830 ffff ffff ffff ffff ffff ffff ffff ffff
0000840 ffff ffff ffff ffff ffff ffff ffff ffff
0000850 ffff ffff ffff ffff ffff ffff ffff ffff
0000860 ffff ffff ffff ffff ffff ffff ffff ffff
0000870 ffff ffff ffff ffff ffff ffff ffff ffff
0000880 ffff ffff ffff ffff ffff ffff ffff ffff
0000890 ffff ffff ffff ffff ffff ffff ffff ffff
00008a0 ffff ffff ffff ffff ffff ffff ffff ffff
00008b0 ffff ffff ffff ffff ffff ffff ffff ffff
00008c0 ffff ffff ffff ffff ffff ffff ffff ffff
00008d0 ffff ffff ffff ffff ffff ffff ffff ffff
00008e0 ffff ffff ffff ffff ffff ffff ffff ffff
00008f0 ffff ffff ffff ffff ffff ffff ffff ffff
0000900 ffff ffff ffff ffff ffff ffff ffff ffff
0000910 ffff ffff ffff ffff ffff ffff ffff ffff
0000920 ffff ffff ffff ffff ffff ffff ffff ffff
0000930 ffff ffff ffff ffff ffff ffff ffff ffff
0000940 ffff ffff ffff ffff ffff ffff ffff ffff
0000950 ffff ffff ffff ffff ffff ffff ffff ffff
0000960 ffff ffff ffff ffff ffff ffff ffff ffff
0000970 ffff ffff ffff ffff ffff ffff ffff ffff
0000980 ffff ffff ffff ffff ffff ffff ffff ffff
0000990 ffff ffff ffff ffff ffff ffff ffff ffff
00009a0 ffff ffff ffff ffff ffff ffff ffff ffff
00009b0 ffff ffff ffff ffff ffff ffff ffff ffff
00009c0 ffff ffff ffff ffff ffff ffff ffff ffff
00009d0 ffff ffff ffff ffff ffff ffff ffff ffff
00009e0 ffff ffff ffff ffff ffff ffff ffff ffff
00009f0 ffff ffff ffff ffff ffff ffff ffff ffff
0000a00 ffff ffff ffff ffff ffff ffff ffff ffff
0000a10 ffff ffff ffff ffff ffff ffff ffff ffff
0000a20 ffff ffff ffff ffff ffff ffff ffff ffff
0000a30 ffff ffff ffff ffff ffff ffff ffff ffff
0000a40 ffff ffff ffff ffff ffff ffff ffff ffff
0000a50 ffff ffff ffff ffff ffff ffff ffff ffff
0000a60 ffff ffff ffff ffff ffff ffff ffff ffff
0000a70 ffff ffff ffff ffff ffff ffff ffff ffff
0000a80 ffff ffff ffff ffff ffff ffff ffff ffff
0000a90 ffff ffff ffff ffff ffff ffff ffff ffff
0000aa0 ffff ffff ffff ffff ffff ffff ffff ffff
0000ab0 ffff ffff ffff ffff ffff ffff ffff ffff
0000ac0 ffff ffff ffff ffff ffff ffff ffff ffff
0000ad0 ffff ffff ffff ffff ffff ffff ffff ffff
0000ae0 ffff ffff ffff ffff ffff ffff ffff ffff
0000af0 ffff ffff ffff ffff ffff ffff ffff ffff
0000b00 ffff ffff ffff ffff ffff ffff ffff ffff
0000b10 ffff ffff ffff ffff ffff ffff ffff ffff
0000b20 ffff ffff ffff ffff ffff ffff ffff ffff
0000b30 ffff ffff ffff ffff ffff ffff ffff ffff
0000b40 ffff ffff ffff ffff ffff ffff ffff ffff
0000b50 ffff ffff ffff ffff ffff ffff ffff ffff
0000b60 ffff ffff ffff ffff ffff ffff ffff ffff
0000b70 ffff ffff ffff ffff ffff ffff ffff ffff
0000b80 ffff ffff ffff ffff ffff ffff ffff ffff
0000b90 ffff ffff ffff ffff ffff ffff ffff ffff
0000ba0 ffff ffff ffff ffff ffff ffff ffff ffff
0000bb0 ffff ffff ffff ffff ffff ffff ffff ffff
0000bc0 ffff ffff ffff ffff ffff ffff ffff ffff
0000bd0 ffff ffff ffff ffff ffff ffff ffff ffff
0000be0 ffff ffff ffff ffff ffff ffff ffff ffff
0000bf0 ffff ffff ffff ffff ffff ffff ffff ffff
0000c00 ffff ffff ffff ffff ffff ffff ffff ffff
0000c10 ffff ffff ffff ffff ffff ffff ffff ffff
0000c20 ffff ffff ffff ffff ffff ffff ffff ffff
0000c30 ffff ffff ffff ffff ffff ffff ffff ffff
0000c40 ffff ffff ffff ffff ffff ffff ffff ffff
0000c50 ffff ffff ffff ffff ffff ffff ffff ffff
0000c60 ffff ffff ffff ffff ffff ffff ffff ffff
0000c70 ffff ffff ffff ffff ffff ffff ffff ffff
0000c80 ffff ffff ffff ffff ffff ffff ffff ffff
0000c90 ffff ffff ffff ffff ffff ffff ffff ffff
0000ca0 ffff ffff ffff ffff ffff ffff ffff ffff
0000cb0 ffff ffff ffff ffff ffff ffff ffff ffff
0000cc0 ffff ffff ffff ffff ffff ffff ffff ffff
0000cd0 ffff ffff ffff ffff ffff ffff ffff ffff
0000ce0 ffff ffff ffff ffff ffff ffff ffff ffff
0000cf0 ffff ffff ffff ffff ffff ffff ffff ffff
0000d00 ffff ffff ffff ffff ffff ffff ffff ffff
0000d10 ffff ffff ffff ffff ffff ffff ffff ffff
0000d20 ffff ffff ffff ffff ffff ffff ffff ffff
0000d30 ffff ffff ffff ffff ffff ffff ffff ffff
0000d40 ffff ffff ffff ffff ffff ffff ffff ffff
0000d50 ffff ffff ffff ffff ffff ffff ffff ffff
0000d60 ffff ffff ffff ffff ffff ffff ffff ffff
0000d70 ffff ffff ffff ffff ffff ffff ffff ffff
0000d80 ffff ffff ffff ffff ffff ffff ffff ffff
0000d90 ffff ffff ffff ffff ffff ffff ffff ffff
0000da0 ffff ffff ffff ffff ffff ffff ffff ffff
0000db0 ffff ffff ffff ffff ffff ffff ffff ffff
0000dc0 ffff ffff ffff ffff ffff ffff ffff ffff
0000dd0 ffff ffff ffff ffff ffff ffff ffff ffff
0000de0 ffff ffff ffff ffff ffff ffff ffff ffff
0000df0 ffff ffff ffff ffff ffff ffff ffff ffff
0000e00 ffff ffff ffff ffff ffff ffff ffff ffff
0000e10 ffff ffff ffff ffff ffff ffff ffff ffff
0000e20 ffff ffff ffff ffff ffff ffff ffff ffff
0000e30 ffff ffff ffff ffff ffff ffff ffff ffff
0000e40 ffff ffff ffff ffff ffff ffff ffff ffff
0000e50 ffff ffff ffff ffff ffff ffff ffff ffff
0000e60 ffff ffff ffff ffff ffff ffff ffff ffff
0000e70 ffff ffff ffff ffff ffff ffff ffff ffff
0000e80 ffff ffff ffff ffff ffff ffff ffff ffff
0000e90 ffff ffff ffff ffff ffff ffff ffff ffff
0000ea0 ffff ffff ffff ffff ffff ffff ffff ffff
0000eb0 ffff ffff ffff ffff ffff ffff ffff ffff
0000ec0 ffff ffff ffff ffff ffff ffff ffff ffff
0000ed0 ffff ffff ffff ffff ffff ffff ffff ffff
0000ee0 ffff ffff ffff ffff ffff ffff ffff ffff
0000ef0 ffff ffff ffff ffff ffff ffff ffff ffff
0000f00 ffff ffff ffff ffff ffff ffff ffff ffff
0000f10 ffff ffff ffff ffff ffff ffff ffff ffff
0000f20 ffff ffff ffff ffff ffff ffff ffff ffff
0000f30 ffff ffff ffff ffff ffff ffff ffff ffff
0000f40 ffff ffff ffff ffff ffff ffff ffff ffff
0000f50 ffff ffff ffff ffff ffff ffff ffff ffff
0000f60 ffff ffff ffff ffff ffff ffff ffff ffff
0000f70 ffff ffff ffff ffff ffff ffff ffff ffff
0000f80 ffff ffff ffff ffff ffff ffff ffff ffff
0000f90 ffff ffff ffff ffff ffff ffff ffff ffff
0000fa0 ffff ffff ffff ffff ffff ffff ffff ffff
0000fb0 ffff ffff ffff ffff ffff ffff ffff ffff
0000fc0 ffff ffff ffff ffff ffff ffff ffff ffff
0000fd0 ffff ffff ffff ffff ffff ffff ffff ffff
0000fe0 ffff ffff ffff ffff ffff ffff ffff ffff
0000ff0 ffff ffff ffff ffff ffff ffff ffff ffff
0001800 ffff ffff ffff ffff ffff ffff ffff ffff
0001810 ffff ffff ffff ffff ffff ffff ffff ffff
0001820 ffff ffff ffff ffff ffff ffff ffff ffff
0001830 ffff ffff ffff ffff ffff ffff ffff ffff
0001840 ffff ffff ffff ffff ffff ffff ffff ffff
0001850 ffff ffff ffff ffff ffff ffff ffff ffff
0001860 ffff ffff ffff ffff ffff ffff ffff ffff
0001870 ffff ffff ffff ffff ffff ffff ffff ffff
0001880 ffff ffff ffff ffff ffff ffff ffff ffff
0001890 ffff ffff ffff ffff ffff ffff ffff ffff
00018a0 ffff ffff ffff ffff ffff ffff ffff ffff
00018b0 ffff ffff ffff ffff ffff ffff ffff ffff
00018c0 ffff ffff ffff ffff ffff ffff ffff ffff
00018d0 ffff ffff ffff ffff ffff ffff ffff ffff
00018e0 ffff ffff ffff ffff ffff ffff ffff ffff
00018f0 ffff ffff ffff ffff ffff ffff ffff ffff
0001900 ffff ffff ffff ffff ffff ffff ffff ffff
0001910 ffff ffff ffff ffff ffff ffff ffff ffff
0001920 ffff ffff ffff ffff ffff ffff ffff ffff
0001930 ffff ffff ffff ffff ffff ffff ffff ffff
0001940 ffff ffff ffff ffff ffff ffff ffff ffff
0001950 ffff ffff ffff ffff ffff ffff ffff ffff
0001960 ffff ffff ffff ffff ffff ffff ffff ffff
0001970 ffff ffff ffff ffff ffff ffff ffff ffff
0001980 ffff ffff ffff ffff ffff ffff ffff ffff
0001990 ffff ffff ffff ffff ffff ffff ffff ffff
00019a0 ffff ffff ffff ffff ffff ffff ffff ffff
00019b0 ffff ffff ffff ffff ffff ffff ffff ffff
00019c0 ffff ffff ffff ffff ffff ffff ffff ffff
00019d0 ffff ffff ffff ffff ffff ffff ffff ffff
00019e0 ffff ffff ffff ffff ffff ffff ffff ffff
00019f0 ffff ffff ffff ffff ffff ffff ffff ffff
0001a00 ffff ffff ffff ffff ffff ffff ffff ffff
0001a10 ffff ffff ffff ffff ffff ffff ffff ffff
0001a20 ffff ffff ffff ffff ffff ffff ffff ffff
0001a30 ffff ffff ffff ffff ffff ffff ffff ffff
0001a40 ffff ffff ffff ffff ffff ffff ffff ffff
0001a50 ffff ffff ffff ffff ffff ffff ffff ffff
0001a60 ffff ffff ffff ffff ffff ffff ffff ffff
0001a70 ffff ffff ffff ffff ffff ffff ffff ffff
0001a80 ffff ffff ffff ffff ffff ffff ffff ffff
0001a90 ffff ffff ffff ffff ffff ffff ffff ffff
0001aa0 ffff ffff ffff ffff ffff ffff ffff ffff
0001ab0 ffff ffff ffff ffff ffff ffff ffff ffff
0001ac0 ffff ffff ffff ffff ffff ffff ffff ffff
0001ad0 ffff ffff ffff ffff ffff ffff ffff ffff
0001ae0 ffff ffff ffff ffff ffff ffff ffff ffff
0001af0 ffff ffff ffff ffff ffff ffff ffff ffff
0001b00 ffff ffff ffff ffff ffff ffff ffff ffff
0001b10 ffff ffff ffff ffff ffff ffff ffff ffff
0001b20 ffff ffff ffff ffff ffff ffff ffff ffff
0001b30 ffff ffff ffff ffff ffff ffff ffff ffff
0001b40 ffff ffff ffff ffff ffff ffff ffff ffff
0001b50 ffff ffff ffff ffff ffff ffff ffff ffff
0001b60 ffff ffff ffff ffff ffff ffff ffff ffff
0001b70 ffff ffff ffff ffff ffff ffff ffff ffff
0001b80 ffff ffff ffff ffff ffff ffff ffff ffff
0001b90 ffff ffff ffff ffff ffff ffff ffff ffff
0001ba0 ffff ffff ffff ffff ffff ffff ffff ffff
0001bb0 ffff ffff ffff ffff ffff ffff ffff ffff
0001bc0 ffff ffff ffff ffff ffff ffff ffff ffff
0001bd0 ffff ffff ffff ffff ffff ffff ffff ffff
0001be0 ffff ffff ffff ffff ffff ffff ffff ffff
0001bf0 ffff ffff ffff ffff ffff ffff ffff ffff
0001c00 ffff ffff ffff ffff ffff ffff ffff ffff
0001c10 ffff ffff ffff ffff ffff ffff ffff ffff
0001c20 ffff ffff ffff ffff ffff ffff ffff ffff
0001c30 ffff ffff ffff ffff ffff ffff ffff ffff
0001c40 ffff ffff ffff ffff ffff ffff ffff ffff
0001c50 ffff ffff ffff ffff ffff ffff ffff ffff
0001c60 ffff ffff ffff ffff ffff ffff ffff ffff
0001c70 ffff ffff ffff ffff ffff ffff ffff ffff
0001c80 ffff ffff ffff ffff ffff ffff ffff ffff
0001c90 ffff ffff ffff ffff ffff ffff ffff ffff
0001ca0 ffff ffff ffff ffff ffff ffff ffff ffff
0001cb0 ffff ffff ffff ffff ffff ffff ffff ffff
0001cc0 ffff ffff ffff ffff ffff ffff ffff ffff
0001cd0 ffff ffff ffff ffff ffff ffff ffff ffff
0001ce0 ffff ffff ffff ffff ffff ffff ffff ffff
0001cf0 ffff ffff ffff ffff ffff ffff ffff ffff
0001d00 ffff ffff ffff ffff ffff ffff ffff ffff
0001d10 ffff ffff ffff ffff ffff ffff ffff ffff
0001d20 ffff ffff ffff ffff ffff ffff ffff ffff
0001d30 ffff ffff ffff ffff ffff ffff ffff ffff
0001d40 ffff ffff ffff ffff ffff ffff ffff ffff
0001d50 ffff ffff ffff ffff ffff ffff ffff ffff
0001d60 ffff ffff ffff ffff ffff ffff ffff ffff
0001d70 ffff ffff ffff ffff ffff ffff ffff ffff
0001d80 ffff ffff ffff ffff ffff ffff ffff ffff
0001d90 ffff ffff ffff ffff ffff ffff ffff ffff
0001da0 ffff ffff ffff ffff ffff ffff ffff ffff
0001db0 ffff ffff ffff ffff ffff ffff ffff ffff
0001dc0 ffff ffff ffff ffff ffff ffff ffff ffff
0001dd0 ffff ffff ffff ffff ffff ffff ffff ffff
0001de0 ffff ffff ffff ffff ffff ffff ffff ffff
0001df0 ffff ffff ffff ffff ffff ffff ffff ffff
0001e00 ffff ffff ffff ffff ffff ffff ffff ffff
0001e10 ffff ffff ffff ffff ffff ffff ffff ffff
0001e20 ffff ffff ffff ffff ffff ffff ffff ffff
0001e30 ffff ffff ffff ffff ffff ffff ffff ffff
0001e40 ffff ffff ffff ffff ffff ffff ffff ffff
0001e50 ffff ffff ffff ffff ffff ffff ffff ffff
0001e60 ffff ffff ffff ffff ffff ffff ffff ffff
0001e70 ffff ffff ffff ffff ffff ffff ffff ffff
0001e80 ffff ffff ffff ffff ffff ffff ffff ffff
0001e90 ffff ffff ffff ffff ffff ffff ffff ffff
0001ea0 ffff ffff ffff ffff ffff ffff ffff ffff
0001eb0 ffff ffff ffff ffff ffff ffff ffff ffff
0001ec0 ffff ffff ffff ffff ffff ffff ffff ffff
0001ed0 ffff ffff ffff ffff ffff ffff ffff ffff
0001ee0 ffff ffff ffff ffff ffff ffff ffff ffff
0001ef0 ffff ffff ffff ffff ffff ffff ffff ffff
0001f00 ffff ffff ffff ffff ffff ffff ffff ffff
0001f10 ffff ffff ffff ffff ffff ffff ffff ffff
0001f20 ffff ffff ffff ffff ffff ffff ffff ffff
0001f30 ffff ffff ffff ffff ffff ffff ffff ffff
0001f40 ffff ffff ffff ffff ffff ffff ffff ffff
0001f50 ffff ffff ffff ffff ffff ffff ffff ffff
0001f60 ffff ffff ffff ffff ffff ffff ffff ffff
0001f70 ffff ffff ffff ffff ffff ffff ffff ffff
0001f80 ffff ffff ffff ffff ffff ffff ffff ffff
0001f90 ffff ffff ffff ffff ffff ffff ffff ffff
0001fa0 ffff ffff ffff ffff ffff ffff ffff ffff
0001fb0 ffff ffff ffff ffff ffff ffff ffff ffff
0001fc0 ffff ffff ffff ffff ffff ffff ffff ffff
0001fd0 ffff ffff ffff ffff ffff ffff ffff ffff
0001fe0 ffff ffff ffff ffff ffff ffff ffff ffff
0001ff0 ffff ffff ffff ffff ffff ffff ffff ffff
0002800 ffff ffff ffff ffff ffff ffff ffff ffff
0002810 ffff ffff ffff ffff ffff ffff ffff ffff
0002820 ffff ffff ffff ffff ffff ffff ffff ffff
0002830 ffff ffff ffff ffff ffff ffff ffff ffff
0002840 ffff ffff ffff ffff ffff ffff ffff ffff
0002850 ffff ffff ffff ffff ffff ffff ffff ffff
0002860 ffff ffff ffff ffff ffff ffff ffff ffff
0002870 ffff ffff ffff ffff ffff ffff ffff ffff
0002880 ffff ffff ffff ffff ffff ffff ffff ffff
0002890 ffff ffff ffff ffff ffff ffff ffff ffff
00028a0 ffff ffff ffff ffff ffff ffff ffff ffff
00028b0 ffff ffff ffff ffff ffff ffff ffff ffff
00028c0 ffff ffff ffff ffff ffff ffff ffff ffff
00028d0 ffff ffff ffff ffff ffff ffff ffff ffff
00028e0 ffff ffff ffff ffff ffff ffff ffff ffff
00028f0 ffff ffff ffff ffff ffff ffff ffff ffff
0002900 ffff ffff ffff ffff ffff ffff ffff ffff
0002910 ffff ffff ffff ffff ffff ffff ffff ffff
0002920 ffff ffff ffff ffff ffff ffff ffff ffff
0002930 ffff ffff ffff ffff ffff ffff ffff ffff
0002940 ffff ffff ffff ffff ffff ffff ffff ffff
0002950 ffff ffff ffff ffff ffff ffff ffff ffff
0002960 ffff ffff ffff ffff ffff ffff ffff ffff
0002970 ffff ffff ffff ffff ffff ffff ffff ffff
0002980 ffff ffff ffff ffff ffff ffff ffff ffff
0002990 ffff ffff ffff ffff ffff ffff ffff ffff
00029a0 ffff ffff ffff ffff ffff ffff ffff ffff
00029b0 ffff ffff ffff ffff ffff ffff ffff ffff
00029c0 ffff ffff ffff ffff ffff ffff ffff ffff
00029d0 ffff ffff ffff ffff ffff ffff ffff ffff
00029e0 ffff ffff ffff ffff ffff ffff ffff ffff
00029f0 ffff ffff ffff ffff ffff ffff ffff ffff
0002a00 ffff ffff ffff ffff ffff ffff ffff ffff
0002a10 ffff ffff ffff ffff ffff ffff ffff ffff
0002a20 ffff ffff ffff ffff ffff ffff ffff ffff
0002a30 ffff ffff ffff ffff ffff ffff ffff ffff
0002a40 ffff ffff ffff ffff ffff ffff ffff ffff
0002a50 ffff ffff ffff ffff ffff ffff ffff ffff
0002a60 ffff ffff ffff ffff ffff ffff ffff ffff
0002a70 ffff ffff ffff ffff ffff ffff ffff ffff
0002a80 ffff ffff ffff ffff ffff ffff ffff ffff
0002a90 ffff ffff ffff ffff ffff ffff ffff ffff
0002aa0 ffff ffff ffff ffff ffff ffff ffff ffff
0002ab0 ffff ffff ffff ffff ffff ffff ffff ffff
0002ac0 ffff ffff ffff ffff ffff ffff ffff ffff
0002ad0 ffff ffff ffff ffff ffff ffff ffff ffff
0002ae0 ffff ffff ffff ffff ffff ffff ffff ffff
0002af0 ffff ffff ffff ffff ffff ffff ffff ffff
0002b00 ffff ffff ffff ffff ffff ffff ffff ffff
0002b10 ffff ffff ffff ffff ffff ffff ffff ffff
0002b20 ffff ffff ffff ffff ffff ffff ffff ffff
0002b30 ffff ffff ffff ffff ffff ffff ffff ffff
0002b40 ffff ffff ffff ffff ffff ffff ffff ffff
0002b50 ffff ffff ffff ffff ffff ffff ffff ffff
0002b60 ffff ffff ffff ffff ffff ffff ffff ffff
0002b70 ffff ffff ffff ffff ffff ffff ffff ffff
0002b80 ffff ffff ffff ffff ffff ffff ffff ffff
0002b90 ffff ffff ffff ffff ffff ffff ffff ffff
0002ba0 ffff ffff ffff ffff ffff ffff ffff ffff
0002bb0 ffff ffff ffff ffff ffff ffff ffff ffff
0002bc0 ffff ffff ffff ffff ffff ffff ffff ffff
0002bd0 ffff ffff ffff ffff ffff ffff ffff ffff
0002be0 ffff ffff ffff ffff ffff ffff ffff ffff
0002bf0 ffff ffff ffff ffff ffff ffff ffff ffff
0002c00 ffff ffff ffff ffff ffff ffff ffff ffff
0002c10 ffff ffff ffff ffff ffff ffff ffff ffff
0002c20 ffff ffff ffff ffff ffff ffff ffff ffff
0002c30 ffff ffff ffff ffff ffff ffff ffff ffff
0002c40 ffff ffff ffff ffff ffff ffff ffff ffff
0002c50 ffff ffff ffff ffff ffff ffff ffff ffff
0002c60 ffff ffff ffff ffff ffff ffff ffff ffff
0002c70 ffff ffff ffff ffff ffff ffff ffff ffff
0002c80 ffff ffff ffff ffff ffff ffff ffff ffff
0002c90 ffff ffff ffff ffff ffff ffff ffff ffff
0002ca0 ffff ffff ffff ffff ffff ffff ffff ffff
0002cb0 ffff ffff ffff ffff ffff ffff ffff ffff
0002cc0 ffff ffff ffff ffff ffff ffff ffff ffff
0002cd0 ffff ffff ffff ffff ffff ffff ffff ffff
0002ce0 ffff ffff ffff ffff ffff ffff ffff ffff
0002cf0 ffff ffff ffff ffff ffff ffff ffff ffff
0002d00 ffff ffff ffff ffff ffff ffff ffff ffff
0002d10 ffff ffff ffff ffff ffff ffff ffff ffff
0002d20 ffff ffff ffff ffff ffff ffff ffff ffff
0002d30 ffff ffff ffff ffff ffff ffff ffff ffff
0002d40 ffff ffff ffff ffff ffff ffff ffff ffff
0002d50 ffff ffff ffff ffff ffff ffff ffff ffff
0002d60 ffff ffff ffff ffff ffff ffff ffff ffff
0002d70 ffff ffff ffff ffff ffff ffff ffff ffff
0002d80 ffff ffff ffff ffff ffff ffff ffff ffff
0002d90 ffff ffff ffff ffff ffff ffff ffff ffff
0002da0 ffff ffff ffff ffff ffff ffff ffff ffff
0002db0 ffff ffff ffff ffff ffff ffff ffff ffff
0002dc0 ffff ffff ffff ffff ffff ffff ffff ffff
0002dd0 ffff ffff ffff ffff ffff ffff ffff ffff
0002de0 ffff ffff ffff ffff ffff ffff ffff ffff
0002df0 ffff ffff ffff ffff ffff ffff ffff ffff
0002e00 ffff ffff ffff ffff ffff ffff ffff ffff
0002e10 ffff ffff ffff ffff ffff ffff ffff ffff
0002e20 ffff ffff ffff ffff ffff ffff ffff ffff
0002e30 ffff ffff ffff ffff ffff ffff ffff ffff
0002e40 ffff ffff ffff ffff ffff ffff ffff ffff
0002e50 ffff ffff ffff ffff ffff ffff ffff ffff
0002e60 ffff ffff ffff ffff ffff ffff ffff ffff
0002e70 ffff ffff ffff ffff ffff ffff ffff ffff
0002e80 ffff ffff ffff ffff ffff ffff ffff ffff
0002e90 ffff ffff ffff ffff ffff ffff ffff ffff
0002ea0 ffff ffff ffff ffff ffff ffff ffff ffff
0002eb0 ffff ffff ffff ffff ffff ffff ffff ffff
0002ec0 ffff ffff ffff ffff ffff ffff ffff ffff
0002ed0 ffff ffff ffff ffff ffff ffff ffff ffff
0002ee0 ffff ffff ffff ffff ffff ffff ffff ffff
0002ef0 ffff ffff ffff ffff ffff ffff ffff ffff
0002f00 ffff ffff ffff ffff ffff ffff ffff ffff
0002f10 ffff ffff ffff ffff ffff ffff ffff ffff
0002f20 ffff ffff ffff ffff ffff ffff ffff ffff
0002f30 ffff ffff ffff ffff ffff ffff ffff ffff
0002f40 ffff ffff ffff ffff ffff ffff ffff ffff
0002f50 ffff ffff ffff ffff ffff ffff ffff ffff
0002f60 ffff ffff ffff ffff ffff ffff ffff ffff
0002f70 ffff ffff ffff ffff ffff ffff ffff ffff
0002f80 ffff ffff ffff ffff ffff ffff ffff ffff
0002f90 ffff ffff ffff ffff ffff ffff ffff ffff
0002fa0 ffff ffff ffff ffff ffff ffff ffff ffff
0002fb0 ffff ffff ffff ffff ffff ffff ffff ffff
0002fc0 ffff ffff ffff ffff ffff ffff ffff ffff
0002fd0 ffff ffff ffff ffff ffff ffff ffff ffff
0002fe0 ffff ffff ffff ffff ffff ffff ffff ffff
0002ff0 ffff ffff ffff ffff ffff ffff ffff ffff
The actual file was longer, but did not fit, so I truncated.
My guess is linux driver does not reset and tries applying its setting over already configured spi bus
Indeed. The nand driver is almost functional, initialized correctly for reading. Just this bug when writing. Some setting in hardware is not initialized by linux driver.
So it seems the driver is missing some mtk_spi_compatible for the mt7981, mt7986 and mt7988. I will add and test this when I can:
currently linux driver binding is done with mediatek,spi-ipm and so the mtk_ipm_compat. but if mt798x needs some tuned settings you have to add these settings. only tested read-access from linux.
The 4 settings above are set in the u-boot devicetree for mt7981/6/8. I see 3 in mtk_ipm_compat. So maybe it is must_tx that is missing? i’ll give it a try.
Otherwise it may be the tick_dly.
So it turns out there is 1 register not being setup correctly, namely SPI_CFG0_REG
It has two values:
  • Chip select setup time
  • Chip select hold time
U-Boot sets up the register with both times set to 3.
In the kernel these times are set with spi-cs-setup-delay-ns and spi-cs-hold-delay-ns in the devicetree only. Setting them to 15ns the value in the register is also set to 3.
The dtbo for nand now has become:
/dts-v1/;
/plugin/;
#define MTK_PUPD_SET_R1R0_00 100
&spi_flash_pins {
    conf-pu {
      pins = "SPI2_CS", "SPI2_HOLD", "SPI2_WP";
      drive-strength = <8>;
      bias-pull-up = <MTK_PUPD_SET_R1R0_00>;
    conf-pd {
      pins = "SPI2_CLK", "SPI2_MOSI", "SPI2_MISO";
      bias-pull-down = <MTK_PUPD_SET_R1R0_00>;
&spi0 {
  #address-cells = <1>;
  #size-cells = <0>;
  spi_nand: flash@0 {
    compatible = "spi-nand";
    reg = <0>;
    spi-max-frequency = <10000000>;
    spi-tx-bus-width = <4>;
    spi-rx-bus-width = <4>;
    spi-cs-setup-delay-ns = <15>;
    spi-cs-hold-delay-ns = <15>;
    partitions {
      compatible = "fixed-partitions";
      #size-cells = <1>;
      partition@0 {
        label = "bl2";
        reg = <0x0 0x200000>;
//      read-only;
      partition@200000 {
        label = "ubi";
        reg = <0x200000 0x7a80000>;
Although I think the pinconf should eventually not be in the overlay.
Now I’m able to write to nand, without issuing the uboot command mtd list, or can even write to nand if u-boot is left out of the bootchain.
Solution in short:
  1. buswidth → bus-width
  2. Add conf-pu and conf-pd to mt7986a-bananapi-bpi-r3.dts
  3. Add spi-cs-setup-delay-ns and spi-cs-hold-delay-ns to mt7986a-bananapi-bpi-r3-nand.dtso
With these changes you have fixed the error?
Yep. I’ve been running a test script that writes only 100kb at a random offset, minimising the writes to nand, I can read it back now without any differences. No matter u-boot setup/presence.
So the delay has more to do with the nand chip itself then the spi controller.
May need to add these delays to other boards with the same/similar nand chip.
do you need extra settings in driver (compatibles+compat),or only the dts change with delay and bus-width? Is the pd/pu config needed?
