I route part of my home and small-office traffic through a VPS in Canada, mainly so client data stays in the country (PIPEDA, BC rules and Quebec Law 25 come up a lot). Notes from setting it up on a Banana Pi router running OpenWrt:
- Use an image that is actively maintained for your board so WireGuard and kernel fixes keep coming.
- Generate keys on each device and never copy private keys around in chat or email.
- Tune the MTU. Starting lower than the default fixed stalls on some sites for me.
- Put the tunnel in its own firewall zone and decide which LAN clients are allowed to use it.
- Check for DNS leaks after it is up, because DNS often still goes out the normal WAN.
- Pick the VPS city by latency. Vancouver and Toronto give very different ping times depending on where you are.
- Back up the router config after every change so a reflash takes minutes, not hours.
Anyone else running a tunnel like this? What MTU and settings worked for you?
