My experiments with the BPI-R4 are coming to an end, time to make it “just work”.
The ISP has installed a ONT at my home (dumb bridge), where the router (which I am allowed to install myself but is getting outdated) plugs in with a RJ45 cable.
If (not sure when) the R4 pro is available, I’d like to use that to replace:
the router / AP
the 10/5/2.5gbe switch linked to the router
the ONT of the provider, named ‘ONT-GPON-4PORTS-V3’
all by this BYOD piece of technology
According to regulations, ISPs should allow to provide a method to replace the GPON ONT with your own if you want to (but off course they don’t like it).
But, question arises: Which SFP GPON can I use on the R4 pro?
I’ve had a bad experience with the SFP+ ports of the R4 when not carefully choosing modules.
GPON networking is completely new to me, so does anybody have a suggestion what to look for when searching the internet for a GPON module? According to the documentation I have from the ISP, I need a single-mode optical fiber GPON module GPON info of ISP, but which one will be compatible with the R4 pro?
Just guessing indeed . Here in Italy ISPs are checking the ont vendor, ploam password or the serial number of the ont. if that doesn’t match the one they have provisioned you don’t authenticate on the network. That is why personally I would look for one that allows to spoof everything from the original ont.
I already contacted my ISP. They said “If you can pass me the Serial number of your device, I can adjust it in your account and everything will be fine” So no help from their side, but also not a “No!”
