I have a few questions about Banana Pi R4 and other models.
Can the SFP+ WAN port take in a SFP XPON ONU stick? (say like a HSGQ ODI DFP-34X-2C2)
Can the SFP+ LAN port take in a 2.5gbe SFP stick to connect to a 2.5gbe switch? or is there a way to connect a 10gbe SFP+ stick to a 2.5gbe switch with SFP port?
is the Banana Pi R4 worth it if I have no plan to use the wifi 7 expansion and just use it as a main wired router for a 500mbps fiber line and another 100mbps fiber line as a backup?
or would just a Banana Pi R2 Pro (with rockchip cpu) be correct for me if I don’t want SFP? also I’m not interested in the Banana Pi R3 as I don’t have use for its Wifi 6 capabilities, I already have a separate wifi 6 access point
Does the mediatek filogic 830/880 hardware acceleration work for wired routing or is it just for wifi?
Thanks in advance
