We’re designing the Banana Pi BPI-M5 Zreo Zero: RK3572, 65 × 30 mm SBC.
Current I/O: dual USB-C, Mini HDMI, 40-pin GPIO, MIPI CSI/DSI, PCIe/SATA.
What would you add, change, or drop? Help shape the design!
Rockchip RK3572 chip:
Personally, I would prefer a board that supports an RK182x acceleration module—ideally via an M.2 PCIe slot with a 4-pin power connector—though the “Zero” form factor likely wouldn’t accommodate this.
Most Rockchip-based boards currently on the market that support the RK182x are either too large or require an external power supply for the accelerator.
A board roughly the size of the BPI-M7, featuring an onboard power supply for an RK182x module, would be an excellent choice for developing embodied AI.
you can see BPI-SM10 or BPI-AIM7 ,can support M.2 AI Cards
What I mean is that the RK1828 M.2 card requires an additional 12V 3A power supply, connected via a 4-pin XH2.54(?) interface. Since the current board lacks such a power connector, I will need to source a separate power adapter and modify the power cable accordingly.
