Weird upload speed issue BPI-R4
I use BPI-R4 as my main router. ISP 1Gbps cable is plugged in WAN port.
Also I have my PC and a wifi router (Gl Inet MT-6000 Flint 2) connected to LAN ports.
When I use speedtest.net to test my network speed from my PC, I have 500 Mbps Download /500 Mbps Upload speed, as it should be. When I use it from any wifi device on my network (iPhone, mac, dell laptop) there may be 2 cases:
  1. 500/500 Mbps and it’s ok
  2. 500/10 Mbps and it’s not ok. If I test my speed on PC and then on wifi again, it becomes 500/500 again for some time and then it goes back to 500/10.
When I use Keenetic Giga instead of BPI-R4, there’s no bug and everything works ok.
Is this known issue? Any workaround?
If not, how to troubleshoot it?
This is most likely an RF noise issue, which has been discussed here. TL;DR: take a look at the SNR figures for wireless clients, find a better Wi-Fi channel, change the way the pigtails are routed inside the case, populate SFP cages. None of those is a complete fix, though.
I don’t use BPI as a wifi router so there are no pigtales inside the case, no SFP. Just BPI-R4 router.
