Hi, I consider buying Banana PI BPI-R3. But I am not sure, if my setup will be possible. I hope that the experienced people here can give me a hand with it.
So, I’d like to attach hard drives to the BPI-R3 via board like this: From what I’ve read, this should be possible with the m.2 slot on the bottom of the BPI-R3.
https://www.aliexpress.com/item/1005006474436187.html?spm=a2g0o.cart.0.0.3f7038daBprEB1&mp=1.
But I also want to have few more Ethernet ports. So I wander if I can use the following (or similar) extension board, with the other PCIe port (the one intended for LTE modem).
Has anyone tried this setup?
Thank you in advance, Greetings.
