[ EDIT: updated /etc/fan_control.sh script to get rid of an unintended loop condition if the USB hub is unplugged while the router continues operating. ]
I bought a Rosonway RSH-A104 USB hub to plug into the router, so I can plug in the external USB hard drive and external USB AX3000M WiFi adapter, and so I can programmatically control power to the 92mm USB cooling fan sitting on top of the router.
The fan is plugged into Port 1 (the port nearest the USB cable end of the hub). The AX3000M is plugged into Port 3, the hard drive is plugged into Port 4.
This requires the uhubctl package be installed.
Run uhubctl to enumerate your hubs, then put the correct HUB_ID and PORT numbers in the script below. Change the temperature range to your liking. This doesn’t just measure CPU temperature, it also measures the WiFi chip temperatures, and triggers on the highest reading.
Paste this into a Terminal window logged into the OpenWRT One router via ssh, then press Enter:
cat << 'EOF' > /etc/fan_control.sh #!/bin/sh # CONFIGURATION HUB_ID="1-1" PORT="1" TEMP_HIGH=55 # Turn fan ON if ANY sensor reaches 55°C TEMP_LOW=50 # Turn fan OFF only when ALL sensors drop below 50°C CHECK_INTERVAL=30 # Check every 30 seconds LOGGING=1 # Options: 0=off | 1=concise | 2=all # Helper function to locate hwmon paths get_wifi_temp_path() { for path in /sys/class/ieee80211/$1/hwmon*/temp1_input; do if [ -f "${path}" ]; then echo "${path}" return fi done } # Resolve Wi-Fi paths once at startup PHY0_PATH=$(get_wifi_temp_path "phy0") PHY1_PATH=$(get_wifi_temp_path "phy1") CURRENT_STATE=-1 HARDWARE_BACKOFF=${CHECK_INTERVAL} while true; do # 1. Check for USB hub hardware if uhubctl -l "${HUB_ID}" >/dev/null 2>&1; then # Hardware found! Reset backoff interval HARDWARE_BACKOFF=${CHECK_INTERVAL} [ "${LOGGING}" -eq 2 ] && logger -t usb_fan "USB hub ${HUB_ID} connected." else # Hardware missing! Log it, sleep, and restart loop iteration [ "${LOGGING}" -ne 0 ] && logger -t usb_fan "USB hub ${HUB_ID} not detected. Retrying in ${HARDWARE_BACKOFF} seconds..." sleep "${HARDWARE_BACKOFF}" HARDWARE_BACKOFF=$((HARDWARE_BACKOFF + 1)) if [ "${HARDWARE_BACKOFF}" -gt 3600 ]; then HARDWARE_BACKOFF=3600 fi continue # Skip temperature checking since hardware is missing fi # 2. Read CPU if [ -f /sys/class/thermal/thermal_zone0/temp ]; then RAW_CPU=$(cat /sys/class/thermal/thermal_zone0/temp 2>/dev/null) MAX_TEMP=$((RAW_CPU / 1000)) else MAX_TEMP=0 fi # 3. Read 2.4GHz WiFi (if path exists) if [ -n "${PHY0_PATH}" ] && [ -f "${PHY0_PATH}" ]; then RAW_WIFI0=$(timeout 2 cat "${PHY0_PATH}" 2>/dev/null) if [ -n "${RAW_WIFI0}" ]; then WIFI0_C=$((RAW_WIFI0 / 1000)) [ "${WIFI0_C}" -gt "${MAX_TEMP}" ] && MAX_TEMP=${WIFI0_C} fi fi # 4. Read 5GHz WiFi (if path exists) if [ -n "${PHY1_PATH}" ] && [ -f "${PHY1_PATH}" ]; then RAW_WIFI1=$(timeout 2 cat "${PHY1_PATH}" 2>/dev/null) if [ -n "${RAW_WIFI1}" ]; then WIFI1_C=$((RAW_WIFI1 / 1000)) [ "${WIFI1_C}" -gt "${MAX_TEMP}" ] && MAX_TEMP=${WIFI1_C} fi fi # 5. Evaluate against the peak observed temperature if [ "${MAX_TEMP}" -ge "${TEMP_HIGH}" ] && [ "${CURRENT_STATE}" -ne 1 ]; then timeout 3 uhubctl -l "${HUB_ID}" -p "${PORT}" -a 1 > /dev/null 2>&1 if [ $? -eq 124 ]; then [ "${LOGGING}" -ne 0 ] && logger -t usb_fan "uhubctl timed out turning ON. Retrying next cycle." CURRENT_STATE=-1 else CURRENT_STATE=1 [ "${LOGGING}" -ne 0 ] && logger -t usb_fan "Peak temp ${MAX_TEMP}°C. Fan ON." fi elif [ "${MAX_TEMP}" -le "${TEMP_LOW}" ] && [ "${CURRENT_STATE}" -ne 0 ] && [ "${MAX_TEMP}" -gt 0 ]; then timeout 3 uhubctl -l "${HUB_ID}" -p "${PORT}" -a 0 > /dev/null 2>&1 if [ $? -eq 124 ]; then [ "${LOGGING}" -ne 0 ] && logger -t usb_fan "uhubctl timed out turning OFF. Retrying next cycle." CURRENT_STATE=-1 else CURRENT_STATE=0 [ "${LOGGING}" -ne 0 ] && logger -t usb_fan "Peak temp ${MAX_TEMP}°C. Fan OFF." fi fi sleep "${CHECK_INTERVAL}" done EOF
Make it executable:
chmod +x /etc/fan_control.sh
Create a service:
vi /etc/init.d/usb_fan
Press i to enter editing mode, then enter the following code:
#!/bin/sh /etc/rc.common START=99 STOP=10 USE_PROCD=1 start_service() { procd_open_instance procd_set_param command /etc/fan_control.sh # If it crashes, restart after 60 seconds. # If it crashes more than 10 times over 3600 seconds, give up. procd_set_param respawn 3600 60 10 procd_close_instance }
… then press Esc to exit editing mode, and press :wq to save and exit.
Issue the commands:
chmod +x /etc/init.d/usb_fan /etc/init.d/usb_fan enable /etc/init.d/usb_fan start
Make it all impervious to firmware updates: In the LuCI interface: System >> Backup / Flash Firmware >> Configuration (ie: /etc/sysupgrade.conf), paste:
/etc/init.d/usb_fan /etc/fan_control.sh
… into the list, then click the “Save” button.
