Unable to flash image on BPI-6204
Hello, I am trying to flash BPI-6204 board. After flashing cs6202-install-tfcard-20240703_20240704_114350.img on MicroSD card and then to eMMC, following this guide, at the next reboot of the board nothing happens. The board has FN led always on, as well as the two blue led on the board, HDMI output doesn’t seem to work but network stack seems up (board gets IP from DHCP, but after portscan nothing seems running in it).
Could you help to troubleshoot the issue? Could it be some kind of hardware failure?
You can also try booting the SD card using this method.
Hi, there… the boot folder has a view scripts making the 6404 boot from SD and install the Ubuntu MATE 20.04 image on the eMMC. If you want to boot and run the image from the SD card you’ll have to change the scripts in the BPI-BOOT folder on your SD card. Let me know if you need help with that, also the image from BPi is not flawless (bugs) and the 8GB eMMC is to small in size when you want to do a upgrade to 22.04
