Uart1 & 2 as debug console
Possibly the uart_*_* are full uart with more than 2 pins? Then we have to create lite defines with only rx/tx to not clash with other functions.
The tops_uart is unrelated (but the typo is still in upstreamed driver) but you should use the uart-lite to map only 2 pins for uart. Have you tried my change above and using it in dts?
yes, the issue i am having at the moment is with RX (can’t type in the console)… voltage is ~3.4v on both tx/rx pins … however can see any voltage rx fluctuation if I sent any characters to the console…debugging at the moment
so, finally got uart2 to work both on rx/tx … there is a software/pinctrl configuration issue. The RX pad was toggling electrically, but the mux state was drifting out of uart2_3_lite, so the UART block never saw RX until I forced the pinctrl state.
This is ikely a conflicting pinctrl consumer or missing ā€œkeep UART pins as defaultā€ in DTS.
I had to create a patch for 8250.mtk.c that forced the pins in UART mode. I also included monitoring that was useful to confirm it wasn’t an hardware fault (typing break on puty i could see the the pins state changing. See the patch below in case anyone needs it in the future
Force the uart2 mode for gpio 58 / 59 in UART mode echo 1 > /sys/kernel/debug/mtk8250/11000200.serial/force_pins
Enable monitoring (this can become quite verbose) echo 1 > /sys/kernel/debug/mtk8250/11000200.serial/rx_watch
--- a/drivers/tty/serial/8250/8250_mtk.c
+++ b/drivers/tty/serial/8250/8250_mtk.c
@@ -7,9 +7,11 @@
 #include <linux/clk.h>
 #include <linux/io.h>
+#include <linux/debugfs.h>
 #include <linux/module.h>
 #include <linux/of_irq.h>
 #include <linux/of_platform.h>
+#include <linux/of.h>
 #include <linux/pinctrl/consumer.h>
 #include <linux/platform_device.h>
 #include <linux/pm_runtime.h>
@@ -17,6 +19,9 @@
 #include <linux/serial_reg.h>
 #include <linux/console.h>
 #include <linux/dma-mapping.h>
+#include <linux/jiffies.h>
+#include <linux/seq_file.h>
+#include <linux/workqueue.h>
 #include <linux/tty.h>
 #include <linux/tty_flip.h>
@@ -57,6 +62,18 @@
 #define MTK_UART_XON1		40	/* I/O: Xon character 1 */
 #define MTK_UART_XOFF1		42	/* I/O: Xoff character 1 */
+#define MT7988_GPIO_BASE	0x1001f000
+#define MT7988_GPIO_SIZE	0x1000
+#define MT7988_GPIO_MODE_7	0x370
+#define MT7988_GPIO_DI0		0x200
+#define MT7988_GPIO_DI		0x210
+#define MT7988_GPIO_DI2		0x220
+#define MT7988_GPIO_DIR		0x010
+#define MT7988_IOCFG_TR_BASE	0x11c10000
+#define MT7988_IOCFG_TR_SIZE	0x1000
+#define MT7988_IOCFG_TR_IES	0x40
+#define MT7988_IOCFG_TR_SMT	0xe0
 #ifdef CONFIG_SERIAL_8250_DMA
 enum dma_rx_status {
 	DMA_RX_START = 0,
@@ -75,6 +92,20 @@ struct mtk8250_data {
 	enum dma_rx_status	rx_status;
 #endif
+#if IS_ENABLED(CONFIG_DEBUG_FS)
+	struct dentry		*debugfs_dir;
+	void __iomem		*gpio_base;
+	void __iomem		*iocfg_tr_base;
+	struct device		*dev;
+	struct delayed_work	rx_work;
+	bool			rx_watch;
+	bool			force_pins;
+	u8			last_lsr;
+	u32			last_di0;
+	u32			last_di1;
+	u32			last_di2;
+	u32			last_gpio_mode;
+#endif
 	int			rx_wakeup_irq;
@@ -426,6 +457,264 @@ mtk8250_set_termios(struct uart_port *po
 		tty_termios_encode_baud_rate(termios, baud, baud);
+static struct dentry *mtk8250_debugfs_root;
+static int mtk8250_debugfs_show(struct seq_file *s, void *unused)
+	struct uart_8250_port *up = s->private;
+	struct mtk8250_data *data = up->port.private_data;
+	unsigned long flags;
+	u32 val;
+	uart_port_lock_irqsave(&up->port, &flags);
+	seq_printf(s, "line=%d mapbase=%pa uartclk=%u regshift=%u\n",
+		   data->line, &up->port.mapbase, up->port.uartclk,
+		   up->port.regshift);
+	seq_printf(s, "LSR=%#x IIR=%#x IER=%#x LCR=%#x MCR=%#x MSR=%#x SCR=%#x\n",
+		   serial_in(up, UART_LSR),
+		   serial_in(up, UART_IIR),
+		   serial_in(up, UART_IER),
+		   serial_in(up, UART_LCR),
+		   serial_in(up, UART_MCR),
+		   serial_in(up, UART_MSR),
+		   serial_in(up, UART_SCR));
+	seq_printf(s, "HIGHS=%#x SAMPLE_COUNT=%#x SAMPLE_POINT=%#x RATE_FIX=%#x\n",
+		   serial_in(up, MTK_UART_HIGHS),
+		   serial_in(up, MTK_UART_SAMPLE_COUNT),
+		   serial_in(up, MTK_UART_SAMPLE_POINT),
+		   serial_in(up, MTK_UART_RATE_FIX));
+	seq_printf(s, "DMA_EN=%#x DEBUG0=%#x\n",
+		   serial_in(up, MTK_UART_DMA_EN),
+		   serial_in(up, MTK_UART_DEBUG0));
+	uart_port_unlock_irqrestore(&up->port, flags);
+	if (data->gpio_base) {
+		val = readl(data->gpio_base + MT7988_GPIO_MODE_7);
+		seq_printf(s, "gpio_mode=0x%08x mode58=%u mode59=%u\n",
+			   val, (val >> 8) & 0xf, (val >> 12) & 0xf);
+		val = readl(data->gpio_base + MT7988_GPIO_DI);
+		seq_printf(s, "gpio_di=0x%08x di58=%u di59=%u\n",
+			   val, (val >> 26) & 1, (val >> 27) & 1);
+		val = readl(data->gpio_base + MT7988_GPIO_DIR);
+		seq_printf(s, "gpio_dir=0x%08x dir58=%u dir59=%u\n",
+	if (data->iocfg_tr_base) {
+		val = readl(data->iocfg_tr_base + MT7988_IOCFG_TR_IES);
+		seq_printf(s, "iocfg_tr_ies=0x%08x ies58=%u ies59=%u\n",
+			   val, (val >> 4) & 1, (val >> 5) & 1);
+		val = readl(data->iocfg_tr_base + MT7988_IOCFG_TR_SMT);
+		seq_printf(s, "iocfg_tr_smt=0x%08x smt58=%u smt59=%u\n",
+	return 0;
+static void mtk8250_rx_watch_work(struct work_struct *work)
+	struct mtk8250_data *data = container_of(to_delayed_work(work),
+					 struct mtk8250_data, rx_work);
+	struct uart_8250_port *up;
+	int ret;
+	u8 lsr;
+	u32 di0 = 0;
+	u32 di1 = 0;
+	u32 di2 = 0;
+	u32 mode = 0;
+	u32 chg0 = 0;
+	u32 chg1 = 0;
+	u32 chg2 = 0;
+	u32 chg_mode = 0;
+	bool di_valid = false;
+	bool mode_valid = false;
+	if (!data->rx_watch)
+		return;
+	if (data->force_pins && data->dev) {
+		ret = pinctrl_pm_select_default_state(data->dev);
+		if (ret)
+			dev_warn_ratelimited(data->dev,
+					     "pinctrl default state failed: %d\n",
+					     ret);
+	up = serial8250_get_port(data->line);
+	if (!up)
+		goto resched;
+	lsr = serial_in(up, UART_LSR);
+		mode = readl(data->gpio_base + MT7988_GPIO_MODE_7);
+		di0 = readl(data->gpio_base + MT7988_GPIO_DI0);
+		di1 = readl(data->gpio_base + MT7988_GPIO_DI);
+		di2 = readl(data->gpio_base + MT7988_GPIO_DI2);
+		chg0 = di0 ^ data->last_di0;
+		chg1 = di1 ^ data->last_di1;
+		chg2 = di2 ^ data->last_di2;
+		chg_mode = mode ^ data->last_gpio_mode;
+		di_valid = true;
+		mode_valid = true;
+	if (lsr != data->last_lsr ||
+	    (di_valid && (chg0 || chg1 || chg2)) ||
+	    (mode_valid && chg_mode)) {
+		dev_info(up->port.dev,
+			"uart%d LSR %#x -> %#x DI58=%u DI59=%u MODE=0x%08x M58=%u M59=%u DIchg0=%#x DIchg1=%#x DIchg2=%#x\n",
+			 data->line, data->last_lsr, lsr,
+			 (di1 >> 26) & 0x1, (di1 >> 27) & 0x1,
+			 mode, (mode >> 8) & 0xf, (mode >> 12) & 0xf,
+			 chg0, chg1, chg2);
+		data->last_lsr = lsr;
+		if (di_valid) {
+			data->last_di0 = di0;
+			data->last_di1 = di1;
+			data->last_di2 = di2;
+		if (mode_valid)
+			data->last_gpio_mode = mode;
+resched:
+	schedule_delayed_work(&data->rx_work, msecs_to_jiffies(100));
+static int mtk8250_rx_watch_get(void *arg, u64 *val)
+	struct mtk8250_data *data = arg;
+	*val = data->rx_watch;
+	return 0;
+static int mtk8250_rx_watch_set(void *arg, u64 val)
+	u8 lsr;
+	u32 di0 = 0;
+	u32 di1 = 0;
+	u32 di2 = 0;
+	u32 mode = 0;
+	if (val && !data->rx_watch) {
+		data->rx_watch = true;
+		if (up) {
+		schedule_delayed_work(&data->rx_work, 0);
+	} else if (!val && data->rx_watch) {
+		data->rx_watch = false;
+		cancel_delayed_work_sync(&data->rx_work);
+	return 0;
+static int mtk8250_force_pins_get(void *arg, u64 *val)
+	*val = data->force_pins;
+	return 0;
+static int mtk8250_force_pins_set(void *arg, u64 val)
+	int ret = 0;
+	data->force_pins = !!val;
+		if (ret)
+			dev_warn(data->dev,
+				 ret);
+	return 0;
+DEFINE_SIMPLE_ATTRIBUTE(mtk8250_force_pins_fops, mtk8250_force_pins_get,
+			  mtk8250_force_pins_set, "%llu\n");
+DEFINE_SIMPLE_ATTRIBUTE(mtk8250_rx_watch_fops, mtk8250_rx_watch_get,
+			  mtk8250_rx_watch_set, "%llu\n");
+static int mtk8250_debugfs_open(struct inode *inode, struct file *file)
+	return single_open(file, mtk8250_debugfs_show, inode->i_private);
+static const struct file_operations mtk8250_debugfs_fops = {
+	.open = mtk8250_debugfs_open,
+	.read = seq_read,
+	.llseek = seq_lseek,
+	.release = single_release,
+static void mtk8250_debugfs_init(struct platform_device *pdev,
+				 struct mtk8250_data *data)
+	if (!mtk8250_debugfs_root)
+		mtk8250_debugfs_root = debugfs_create_dir("mtk8250", NULL);
+	if (IS_ERR_OR_NULL(mtk8250_debugfs_root))
+		return;
+	data->debugfs_dir = debugfs_create_dir(dev_name(&pdev->dev),
+					      mtk8250_debugfs_root);
+	if (IS_ERR_OR_NULL(data->debugfs_dir))
+		return;
+	if (!up)
+		return;
+	debugfs_create_file("regs", 0400, data->debugfs_dir, up,
+			    &mtk8250_debugfs_fops);
+	debugfs_create_file("force_pins", 0600, data->debugfs_dir, data,
+			    &mtk8250_force_pins_fops);
+	debugfs_create_file("rx_watch", 0600, data->debugfs_dir, data,
+			    &mtk8250_rx_watch_fops);
+static void mtk8250_debugfs_exit(struct mtk8250_data *data)
+	debugfs_remove_recursive(data->debugfs_dir);
+	data->debugfs_dir = NULL;
+#endif
 static int __maybe_unused mtk8250_runtime_suspend(struct device *dev)
 	struct mtk8250_data *data = dev_get_drvdata(dev);
@@ -543,6 +832,17 @@ static int mtk8250_probe(struct platform
 	data->clk_count = 0;
+	if (of_device_is_compatible(pdev->dev.of_node, "mediatek,mt7988-uart")) {
+		data->dev = &pdev->dev;
+		data->gpio_base = devm_ioremap(&pdev->dev, MT7988_GPIO_BASE,
+					       MT7988_GPIO_SIZE);
+		data->iocfg_tr_base = devm_ioremap(&pdev->dev,
+						   MT7988_IOCFG_TR_BASE,
+						   MT7988_IOCFG_TR_SIZE);
+#endif
 	if (pdev->dev.of_node) {
 		err = mtk8250_probe_of(pdev, &uart.port, data);
 		if (err)
@@ -579,11 +879,19 @@ static int mtk8250_probe(struct platform
 	if (data->line < 0)
 		return data->line;
+	INIT_DELAYED_WORK(&data->rx_work, mtk8250_rx_watch_work);
+#endif
 	data->rx_wakeup_irq = platform_get_irq_optional(pdev, 1);
 	pm_runtime_set_active(&pdev->dev);
 	pm_runtime_enable(&pdev->dev);
+	mtk8250_debugfs_init(pdev, data);
+#endif
 	return 0;
@@ -591,6 +899,10 @@ static void mtk8250_remove(struct platfo
 	struct mtk8250_data *data = platform_get_drvdata(pdev);
+	mtk8250_debugfs_exit(data);
+#endif
 	pm_runtime_get_sync(&pdev->dev);
 	serial8250_unregister_port(data->line);
Note the above patch is for openwrt snapshot.
I am now looking to add a ā€œpinctrl hogā€ to lock the pins in UART mode so nothing else can remux them.
How do your dts changes look like? I wonder why something should remux the pins (and can if they already bound). As far as i see most code is for the watching and only code in mtk8250_force_pins_set should be needed…maybe some supend issue?
yes the mtk8250_force_pins_set is what is needed to have the console showing using uart2. I am changing the dts to have something like this (pinctrl hogging) to check if there is something remuxing the pins. I don’t think i should need something like mtk8250_force_pins_set
+&pio {
+	pinctrl-names = "default";
+	pinctrl-0 = <&uart2_3_pins>;
+	i2c1_pins: i2c1-pins {
+		mux {
+			function = "i2c";
+			groups = "i2c1_0";
+	uart2_3_pins: uart2-3-pins {
+		mux {
+			function = "uart";
+			groups = "uart2_3_lite";
+		conf-rx {
+			pins = "JTAG_JTDI";
+			input-enable;
let’s see if it works…not an expert on this so been trial & error but relieved there is no hw issue
That is wrong…this have to be in the uart node not pio…and why conf-rx? And the mux above for i2c (i guess it is only your unrelated local change)
let me prepare the changes i think needed for this in code and dts so far (except the routing from uart0 to uart2)
i need to remove conf-rx this was part of an earlier test … the &pio change with pinctrl-0 = <&uart2_3_pins> I agree is wrong but want to set it as the default state to check if i get any of the remux issues (without the need to force the pins) …no intention for any of this work to be upstreamed but find the root cause
pushed these change to 6.19-rc…only these should be needed for uart1/uart2 to work
basicly the both uart seems working…started a minicom there to debug-uart of my other R4 :wink:
only looks they are swapped (uart0 on header is ttyS2 and uart1 is ttyS1)
[    0.849373] 11000000.serial: ttyS0 at MMIO 0x11000000 (irq = 99, base_baud = 2500000) is a ST16650V2
[    0.858662] printk: legacy console [ttyS0] enabled
[    0.900106] 11000100.serial: ttyS1 at MMIO 0x11000100 (irq = 100, base_baud = 2500000) is a ST16650V2
[    0.930193] 11000200.serial: ttyS2 at MMIO 0x11000200 (irq = 101, base_baud = 2500000) is a ST16650V2
6,8,10 = ttyS2
9,11,13 = ttyS1
So far so right,only confusing that uart2 on 8/10 is labeled uart0
https://wiki.fw-web.de/doku.php?id=en:bpi-r4:start#gpio
tx and rx are working for both uart :slight_smile: but noticed that something broke xsphy in 6.19, but i guess it is not related…
[    1.371212] phy phy-11e10000.xs-phy.2: error -EBUSY: can't request region for resource [mem 0x00000000-0x000003ff]
[    1.381579] mtk-xsphy 11e10000.xs-phy: failed to remap phy regs
[    1.395495] mtk-xsphy 11e10000.xs-phy: probe with driver mtk-xsphy failed with error -16
Seems it is caused by my patch try to fix binding errors (looks like i defined xsphy too small),but have seen patch from angelo regarding same…will revert mine and try his one…seems working better.
so that worked - testing on your 6.19-rc repo. I had to change the the stdout-path and include a stdin-path on the dts though, and update the uEnv and point the console to ttyS2. earlycon though doesn’t work (the console gets stuck) this is most likely to u-boot.
Regarding u-boot/mtk-atf, and based on my tests so far with openwrt there’s quite some work, namely
a/plat/mediatek/mt7988/aarch64/plat_helpers.S UART0_BASE needs to move to UART2_BASE on a couple of places
b/plat/mediatek/mt7988/include/mt7988_def.h needs to move from UART0_BASE to UART2_BASE
also need to set GPIO58 and 59 to GPIO mode 3
i will report back if i get the uboot console to work with uart2
