Anyone added a tv sat streaming server with a banana pi? Probably, running tvhead or something like this? I would like to buy me such a card:
Any recommendations for cards, software, best practice?
I have not yet implemented it, but I do plan to migrate my dvb-c setup to bpi-r64.
I currently have Ubuntu running on wrt1900acs, but the setup should be the same on BPI.
I suggest finding a USB stick dvb receiver, in your case dvb-s, in my case dvb-c t230c v2. I have 4 sticks connected through a usb3 hub. If you really need 8, you could try 4 dual receivers. Try to find the device on linuxtv.org and check if it is supported, preferably in mainstream Linux kernel.
Then run kernel menu config and add USB dvb support and your device driver. Then rebuild the kernel.
Then install tvheadend on debian, Ubuntu or arch Linux.
That should be it in a nutshell
I finally got to migrate my dvb setup to the BPI-R64.
My new arch-linux build script has dvb and some of the receivers enabled in prebuilt kernel.
There is a downloadable image for you to try. Then install tvheadend from the AUR.
I found that the usb-host of my BPI R64 does not like a usb3 xhci hub, with only usb2 devices attached. Plugging in at least one xhci device fixes the problem. In my case, I just use a 7 port hub, so there is one 4-port xhci hub attached to the first 4-port xhci hub.
After that I run 4 dvb-c receivers perfectly now on BPI R64. In combination with oscam and a cardreader, I can even descramble the encrypted channels (only the channels I’m paying for of course)
