[Description]
This tutorial shows how to replace SPI NAND flash with a larger/smaller one on BPI R3, including how to build corresponding atf(TF-A), openwrt based on MediaTek SDK.
[Steps]
1. Setup ATF, U-boot, Openwrt environment
Please refer the following references
- For atf, U-boot :
[Tutorial] Build, customize and use MediaTek open-source U-Boot and ATF to set up uboot and atf code base.
- For openwrt :
GitHub - BPI-SINOVOIP/BPI-R3-OPENWRT-V21.02.3: BPI-R3-OPENWRT-V21.02.3
https://wiki.banana-pi.org/Banana_Pi_BPI-R3#MediaTek_MT7986.28Filogic_830.29
2. Choose a SPI NAND flash you want to replace with
Here, we take Macronix MX35LF4GE4AD nand flash and banana pi r3 (mt7986) as an example.
3. Rework nand flash on banana pi board
4. Build U-boot
- Note that the deconfig must be selected with SPI NAND related.
5. Build ATF
- First, please find out the page size of nand flash in its corresponding flash datasheet.
- Second, determine the NAND_TYPE with the following table. In this case, the page size of Macronix MX35LF4GE4AD nand flash is 4k+128 which can be found in Macronix MX35LF4GE4AD datasheet. Hence, we can select spim:4k+256 for NAND_TYPE.
| Value | Boot device | Platform | Description | Compatibel device setting |
| spim:2k+64 | spim-nand | mt7981/mt7986 | Page size: 2K, Spare size: 64 (default) | 2k+32, 2k+256 |
| spim:2k+128 | spim-nand | mt7981/mt7986 | Page size: 2K, Spare size: 128 | 2k+32, 2k+256 |
| spim:4k+256 | spim-nand | mt7981/mt7986 | Page size: 4K, Spare size: 256 | 4k+128 |
[Note.]
(i) Some special cases such as 4k+128, 2k+32, 2k+256 which aren’t available above will be set in “Compatible device setting”. You can use the corresponding NAND_TYPE value to build with.
- Third, after NAND_TYPE is determined, build the atf using the following command. More detailed information about how to build atf can refer to [Tutorial] Build, customize and use MediaTek open-source U-Boot and ATF
$make -f Makefile PLAT=<plat> BOOT_DEVICE=spim-nand nand_type=4k+256 BL33=<path-to-u-boot.bin> all fip
// Ex. $make -f Makefile PLAT=mt7986 BOOT_DEVICE=spim-nand NAND_TYPE=spim:4k+256 BL33=../U-boot/u-boot/u-boot.bin DRAM_USE_DDR4=1 all fip
6. Build Openwrt SDK (Optional by case)
It’s necessary to rebuild openwrt if you have changed to use a different page/block size nand flash. For example, if you replace a 1G nand flash with a new 4G nand flash which has a larger page/block size, then you have to follow this part.
Set the proper page size and block size for nand device in mt7986.mk (depends on which Soc you used).
$vim {Openwrt_Root_Path}/target/linux/mediatek/image/mt7986.mk
// 1. Set BLOCKSIZE to 256k
// 2. Set PAGESIZE to 4096
// save and exit
- After setting the proper page size and block size, rebuild the Openwrt image.
7. Update bl2.img & fip.bin & Openwrt image to banana pi
Please refer to [Tutorial] Build, customize and use MediaTek open-source U-Boot and ATF to study the methods about how to upgrade bl2.img, fip.bin and openwrt.
8. Done!
Finally, boot the banana pi and you will see that nand flash can be found successfully.
[Attachment]
- Macronix MX35LF4GE4AD nand flash datasheet :
