I have the old bpi-w2 working. I have installed two 1TB hard drives. I have updated the official version “Ubuntu Server 16.04 Operation system with kernel 4.9.119” to Ubuntu 22.04.
I leave some tips here!
- BPI-W2
- 2 x HDD Western Digital WD10SPZX
- 1 x SD card 8GB
Sources
- Banana Pi BPI-W2 - Banana Pi Wiki
- Getting Started with W2 - Banana Pi Wiki
- BPI-W2 How to make and run the 64-bit ubuntu on SD card - banana pi BPI-W2 smart router with Realtec RTD129
- https://cdimage.ubuntu.com/ubuntu-base/releases/22.04.3/release/ubuntu-base-22.04.3-base-arm64.tar.gz
1. Create SD card
apt-get install pv
curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash
bpi-copy xxx.img /dev/sdx # to install image on your TF card.
2. Update Ubuntu 22.04.
I have replaced the contents of the “ROOT” partition.
tar zxvf ubuntu-base-22.04.3-base-arm64.tar.gz -C /mnt/rootfs
I have solved some errors with the help of the forum.
- Mirroring folder
/var/lib/bananapi - There is a problem with the udev, all entries
sdmust be changed tosata - HDMI while booting and in console mode
Install Syncthing
apt install software-properties-common apt-transport-https wget curl -y
curl -o /usr/share/keyrings/syncthing-archive-keyring.gpg https://syncthing.net/release-key.gpg
echo "deb [signed-by=/usr/share/keyrings/syncthing-archive-keyring.gpg] https://apt.syncthing.net/ syncthing stable" | sudo tee /etc/apt/sources.list.d/syncthing.list
apt update
apt install syncthing
adduser syncthing
systemctl start [email protected]
systemctl enable [email protected]
