You can force the OpenWRT One hardware to dial back at a lower-than-stock temperature. I’m playing with this to determine what each setting does.
This all goes in System >> Startup >> Local Startup (the /etc/rc.local file):
# ============================== # SET CPU THERMAL LIMITS: echo 90000 > /sys/class/thermal/thermal_zone0/trip_point_0_temp # Hard Critical shutdown threshold echo 85000 > /sys/class/thermal/thermal_zone0/trip_point_1_temp # Extreme throttle threshold echo 75000 > /sys/class/thermal/thermal_zone0/trip_point_2_temp # Aggressive throttle threshold echo 65000 > /sys/class/thermal/thermal_zone0/trip_point_3_temp # Maximum safe optimal operating temperature echo 55000 > /sys/class/thermal/thermal_zone0/trip_point_4_temp # The baseline operating threshold # SET THERMAL LIMITS FOR WIFI CHIPS # Wait 10 seconds to ensure drivers are fully registered in sysfs sleep 10 # Use 'ls -d' to isolate the physical hardware paths for hwmon_dir in $(ls -d /sys/class/ieee80211/phy*/hwmon* 2>/dev/null); do MAX_FILE="${hwmon_dir}/temp1_max" CRIT_FILE="${hwmon_dir}/temp1_crit" # Write to max file if it exists (using printf to prevent newline) if [ -f "$MAX_FILE" ]; then printf "%s" "85000" > "$MAX_FILE" 2>/dev/null > "$MAX_FILE" fi # Write to crit file if it exists (using printf to prevent newline) if [ -f "$CRIT_FILE" ]; then printf "%s" "75000" > "$CRIT_FILE" 2>/dev/null > "$CRIT_FILE" fi done # ==============================
Issue the command:
ps | grep rc.local
You’ll see something like this:
ps | grep rc.local 3598 root 1332 S grep rc.local 21369 root 1352 S sh /etc/rc.local
So you’d issue:
kill 21369
Then you can restart /etc/rc.local to load the changes without having to reboot:
sh /etc/rc.local
I know /sys/class/thermal/thermal_zone0/trip_point_0_temp shuts down the router, and I know /sys/class/ieee80211/phy*/hwmon*/temp1_max shuts off the WiFi chip. The rest of them, I assume, are logging warnings and throttling the hardware to reduce heat generation.
