The size of DC connector on BPI-R64, BPI-R3, BPI-R4, BPI-R2 PRO&BPI-W2, BPI-W3
Hi, sorry for the off-topic if I unscrewed the antenna while the board was on would it damage the RF amplifier
I got info that the antenna cable should be enough to prevent damage on amplifier,but if your out of luck it could happen…do not force it
I think so.
How could I tell if it’s damaged, for now it seems fine, I disconnected 5ghz antenna and reconnected it and seems to still work
According to Google, it is necessary to install the NetSpot program to check for signal loss/drop:
Bad/Damaged:
Good/No problems:
Thanks for that, I appreciate the help
the entries dont seem to pop up for me
Buy some SMA dummy load.
