SOLVED [BPI-R3][OpenWRT Snapshot] Wifi Devices dissappeared
Hello everyone, I have a really complicated problem that is going to make me mad.
Yesterday I went to grab a beer, came back and my Wifi was gone. This morning I checked the box and the devices are gone. Reboots, power cycles, newest snapshots, rc2, nothing is working. I removed everything and tried only the UART but the Wifi seems dead. It does not lead the MT76 driver on boot. When I modload it then nothing happens and iw list stays empty. No devices, no PHY.
I am at the end of my knowledge and need some help here. Is the chip dead? Everything else works fine as far as I can tell. BPI-R3 is used with BPI Power Brick and BPI metal case and heatsinks.
I can provide any info necessary.
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    0.000000] Linux version 5.15.118 (builder@buildhost) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 12.3.0 r23228-cd17d8df2a) 12.3.0, GNU ld (GNU Binutils) 2.40.0) #0 SMP Mon Jun 26 11:20:39 2023
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] Machine model: Bananapi BPI-R3
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] Zone ranges:
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000]   DMA      [mem 0x0000000040000000-0x00000000bfffffff]
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000]   DMA32    empty
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000]   Normal   empty
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] Movable zone start for each node
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] Early memory node ranges
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000]   node   0: [mem 0x0000000040000000-0x0000000042ffffff]
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000]   node   0: [mem 0x0000000043000000-0x000000004302ffff]
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000]   node   0: [mem 0x0000000043030000-0x000000004fbfffff]
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000]   node   0: [mem 0x000000004fc00000-0x000000004ffbffff]
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000]   node   0: [mem 0x000000004ffc0000-0x00000000bfffffff]
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] psci: probing for conduit method from DT.
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] psci: PSCIv1.1 detected in firmware.
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] psci: Using standard PSCI v0.2 function IDs
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] psci: SMC Calling Convention v1.2
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] percpu: Embedded 17 pages/cpu s30040 r8192 d31400 u69632
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    0.000000] pcpu-alloc: s30040 r8192 d31400 u69632 alloc=17*4096
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] Detected VIPT I-cache on CPU0
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] CPU features: detected: GIC system register CPU interface
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] CPU features: kernel page table isolation disabled by kernel configuration
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    0.000000] Kernel command line: root=/dev/mmcblk0p65
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] Memory: 2040972K/2097152K available (8384K kernel code, 910K rwdata, 1468K rodata, 448K init, 301K bss, 56180K reserved, 0K cma-reserved)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] rcu: Hierarchical RCU implementation.
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] 	Tracing variant of Tasks RCU enabled.
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] GICv3: 640 SPIs implemented
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] GICv3: 0 Extended SPIs implemented
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] GICv3: Distributor has no Range Selector support
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] Root IRQ handler: 0xffffffc008423104
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] GICv3: 16 PPIs implemented
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] arch_timer: cp15 timer(s) running at 13.00MHz (phys).
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2ff89eacb, max_idle_ns: 440795202429 ns
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000123] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000131] pid_max: default: 32768 minimum: 301
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000342] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.000355] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.001398] rcu: Hierarchical SRCU implementation.
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.001703] smp: Bringing up secondary CPUs ...
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.001959] Detected VIPT I-cache on CPU1
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.001981] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.002006] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.002269] Detected VIPT I-cache on CPU2
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.002280] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.002291] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.002529] Detected VIPT I-cache on CPU3
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.002539] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.002548] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.002573] smp: Brought up 1 node, 4 CPUs
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.002587] SMP: Total of 4 processors activated.
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.002590] CPU features: detected: 32-bit EL0 Support
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.002593] CPU features: detected: CRC32 instructions
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.002618] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.002671] CPU: All CPU(s) started at EL2
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.002681] alternatives: patching kernel code
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.005574] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.005596] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.005738] pinctrl core: initialized pinctrl subsystem
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.006371] NET: Registered PF_NETLINK/PF_ROUTE protocol family
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.006623] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.006654] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.006680] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.006935] thermal_sys: Registered thermal governor 'fair_share'
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.006938] thermal_sys: Registered thermal governor 'bang_bang'
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.006941] thermal_sys: Registered thermal governor 'step_wise'
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.006944] thermal_sys: Registered thermal governor 'user_space'
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.007125] ASID allocator initialised with 65536 entries
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.007440] pstore: Registered ramoops as persistent store backend
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.007444] ramoops: using 0x10000@0x42ff0000, ecc: 0
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.017325] cryptd: max_cpu_qlen set to 1000
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.018909] 1.8vd: supplied by 12vd
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.019073] 3.3vd: supplied by 12vd
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    0.019333] SCSI subsystem initialized
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    0.019449] libata version 3.00 loaded.
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.020321] clocksource: Switched to clocksource arch_sys_counter
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.020765] NET: Registered PF_INET protocol family
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.020878] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.021537] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.021557] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.021565] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.021632] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.021795] TCP: Hash tables configured (established 16384 bind 16384)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.021869] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.021897] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.022075] NET: Registered PF_UNIX/PF_LOCAL protocol family
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.022095] PCI: CLS 0 bytes, default 64
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.023954] workingset: timestamp_bits=46 max_order=19 bucket_order=0
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.026705] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.026721] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.048597] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Sat Jul 15 14:22:53 2023 kern.err kernel: [    0.049643] pwm-mediatek 10048000.pwm: clock: top fail: -517
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.049903] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    0.049921] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.049930] mtk-pcie-gen3 11280000.pcie:      MEM 0x0020000000..0x002fffffff -> 0x0020000000
Sat Jul 15 14:22:53 2023 kern.err kernel: [    0.050011] /soc/pcie@11280000: Failed to get clk index: 0 ret: -517
Sat Jul 15 14:22:53 2023 kern.err kernel: [    0.050020] mtk-pcie-gen3 11280000.pcie: failed to get clocks
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.052766] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.054450] printk: console [ttyS0] disabled
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.074628] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 122, base_baud = 2500000) is a ST16650V2
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.762274] printk: console [ttyS0] enabled
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.787041] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 123, base_baud = 1625000) is a ST16650V2
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.816761] 11004000.serial: ttyS2 at MMIO 0x11004000 (irq = 124, base_baud = 1625000) is a ST16650V2
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.826598] mtk_rng 1020f000.rng: registered RNG driver
Sat Jul 15 14:22:53 2023 kern.warn kernel: [    0.826657] hwrng: no data available
Sat Jul 15 14:22:53 2023 kern.warn kernel: [    0.835420] cacheinfo: Unable to detect cache hierarchy for CPU 0
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.843634] loop: module loaded
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.846784] Loading iSCSI transport class v2.0-870.
Sat Jul 15 14:22:53 2023 kern.info kernel: [    0.853066] spi-nor spi0.0: w25q256 (32768 Kbytes)
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    0.857965] 6 fixed-partitions partitions found on MTD device spi0.0
Sat Jul 15 14:22:53 2023 kern.err kernel: [    0.864332] OF: Bad cell count for /soc/spi@1100a000/flash@0/partitions
Sat Jul 15 14:22:53 2023 kern.err kernel: [    0.870947] OF: Bad cell count for /soc/spi@1100a000/flash@0/partitions
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    0.877694] Creating 6 MTD partitions on "spi0.0":
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    0.882516] 0x000000c00000-0x000002000000 : "fit"
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    0.891103] 1 fit-fw partitions found on MTD device fit
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    0.896318] Creating 1 MTD partitions on "fit":
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    0.900841] 0x000000b00000-0x000001400000 : "rootfs_data"
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    0.906553] 0x000000180000-0x000000c00000 : "recovery"
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    0.911994] 0x000000100000-0x000000180000 : "fip"
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    0.916933] 0x000000080000-0x000000100000 : "reserved2"
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    0.922416] 0x000000040000-0x000000080000 : "u-boot-env"
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    0.927921] 0x000000000000-0x000000040000 : "bl2"
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    0.936797] FIT: Selected configuration: "config-mt7986a-bananapi-bpi-r3" (OpenWrt bananapi_bpi-r3)
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    0.945859] FIT:           kernel sub-image 0x00001000..0x004eae92 "kernel-1" (ARM64 OpenWrt Linux-5.15.118)
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    0.955757] FIT:          flat_dt sub-image 0x004eb000..0x004f29fc "fdt-1" (ARM64 OpenWrt bananapi_bpi-r3 device tree blob)
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    0.966958] FIT:          flat_dt sub-image 0x004f3000..0x004f31dc "fdt-mt7986a-bananapi-bpi-r3-emmc" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc)
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    0.983271] FIT:          flat_dt sub-image 0x004f4000..0x004f4390 "fdt-mt7986a-bananapi-bpi-r3-nand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nand)
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    0.999585] FIT:          flat_dt sub-image 0x004f5000..0x004f538f "fdt-mt7986a-bananapi-bpi-r3-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor)
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.015725] FIT:          flat_dt sub-image 0x004f6000..0x004f6146 "fdt-mt7986a-bananapi-bpi-r3-sd" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-sd)
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.031688] FIT:       filesystem sub-image 0x004f7000..0x00af0fff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r3 rootfs)
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.042275] FIT: selecting configured loadable "rootfs-1" to be root filesystem
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.049559]  mtdblock0: p1(rootfs-1)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.203510] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc009880000, irq 136
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.216878] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc009880000, irq 136
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.226414] i2c_dev: i2c /dev entries driver
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.232232] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.240759] NET: Registered PF_INET6 protocol family
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.246390] Segment Routing with IPv6
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.250064] In-situ OAM (IOAM) with IPv6
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.254049] NET: Registered PF_PACKET protocol family
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.259103] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.272145] 8021q: 802.1Q VLAN Support v1.8
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.277140] pstore: Using crash dump compression: deflate
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.288261] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.295602] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.301860] mtk-pcie-gen3 11280000.pcie:      MEM 0x0020000000..0x002fffffff -> 0x0020000000
Sat Jul 15 14:22:53 2023 kern.warn kernel: [    1.318368] mmc0: host does not support reading read-only switch, assuming write-enable
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.329399] mmc0: new high speed SDXC card at address aaaa
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.335649] mmcblk0: mmc0:aaaa SD64G 59.5 GiB
Sat Jul 15 14:22:53 2023 kern.warn kernel: [    1.343497] Alternate GPT is invalid, using primary GPT.
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.349741] FIT: Selected configuration: "config-mt7986a-bananapi-bpi-r3" (OpenWrt bananapi_bpi-r3)
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.358776] FIT:           kernel sub-image 0x00001000..0x004eae92 "kernel-1" (ARM64 OpenWrt Linux-5.15.118)
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.368673] FIT:          flat_dt sub-image 0x004eb000..0x004f29fc "fdt-1" (ARM64 OpenWrt bananapi_bpi-r3 device tree blob)
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.379872] FIT:          flat_dt sub-image 0x004f3000..0x004f31dc "fdt-mt7986a-bananapi-bpi-r3-emmc" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc)
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.396188] FIT:          flat_dt sub-image 0x004f4000..0x004f4390 "fdt-mt7986a-bananapi-bpi-r3-nand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nand)
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.412505] FIT:          flat_dt sub-image 0x004f5000..0x004f538f "fdt-mt7986a-bananapi-bpi-r3-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor)
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.428645] FIT:          flat_dt sub-image 0x004f6000..0x004f6146 "fdt-mt7986a-bananapi-bpi-r3-sd" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-sd)
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.444613] FIT:       filesystem sub-image 0x004f7000..0x00af0fff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r3 rootfs)
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.455200] FIT: selecting configured loadable "rootfs-1" to be root filesystem
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.462494]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p65(rootfs-1) p66(rootfs_data)
Sat Jul 15 14:22:53 2023 kern.err kernel: [    1.544636] mtk-pcie-gen3 11280000.pcie: PCIe link down, ltssm reg val: 0x1000001
Sat Jul 15 14:22:53 2023 kern.warn kernel: [    1.552141] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.580955] mt7530-mdio mdio-bus:1f: configuring for fixed/2500base-x link mode
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.589993] mt7530-mdio mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.598680] mt7530-mdio mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=144)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.619019] mt7530-mdio mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=145)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.639019] mt7530-mdio mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=146)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.659052] mt7530-mdio mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=147)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.679065] mt7530-mdio mdio-bus:1f lan4 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=148)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.690186] DSA: tree 0 setup
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.698449] VFS: Mounted root (squashfs filesystem) readonly on device 259:1.
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.705739] Freeing unused kernel memory: 448K
Sat Jul 15 14:22:53 2023 kern.info kernel: [    1.780424] Run /sbin/init as init process
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.784505]   with arguments:
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.787456]     /sbin/init
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.790148]   with environment:
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.793280]     HOME=/
Sat Jul 15 14:22:53 2023 kern.debug kernel: [    1.795624]     TERM=linux
Sat Jul 15 14:22:53 2023 user.info kernel: [    1.918721] init: Console is alive
Sat Jul 15 14:22:53 2023 user.info kernel: [    1.922248] init: - watchdog -
Sat Jul 15 14:22:53 2023 user.info kernel: [    2.205711] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.226420] usbcore: registered new interface driver usbfs
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.231959] usbcore: registered new interface driver hub
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.237286] usbcore: registered new device driver usb
Sat Jul 15 14:22:53 2023 kern.warn kernel: [    2.245742] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
Sat Jul 15 14:22:53 2023 kern.warn kernel: [    2.253157] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.261333] xhci-mtk 11200000.usb: xHCI Host Controller
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.266552] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.277006] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000210010
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.286168] xhci-mtk 11200000.usb: irq 128, io mem 0x11200000
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.291994] xhci-mtk 11200000.usb: xHCI Host Controller
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.297206] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.304588] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.312016] hub 1-0:1.0: USB hub found
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.315769] hub 1-0:1.0: 2 ports detected
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.320025] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.328376] hub 2-0:1.0: USB hub found
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.332148] hub 2-0:1.0: 1 port detected
Sat Jul 15 14:22:53 2023 user.info kernel: [    2.338475] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Sat Jul 15 14:22:53 2023 user.info kernel: [    2.350149] init: - preinit -
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.548814] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.557259] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.564042] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.577720] mt7530-mdio mdio-bus:1f lan1: Link is Up - 1Gbps/Full - flow control rx/tx
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.585718] IPv6: ADDRCONF(NETDEV_CHANGE): lan1: link becomes ready
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.780326] usb 1-1: new high-speed USB device number 2 using xhci-mtk
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.961003] hub 1-1:1.0: USB hub found
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    2.961819] random: procd: uninitialized urandom read (4 bytes read)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    2.964782] hub 1-1:1.0: 4 ports detected
Sat Jul 15 14:22:53 2023 user.info kernel: [    4.620823] mount_root: loading kmods from internal overlay
Sat Jul 15 14:22:53 2023 user.info kernel: [    4.630542] kmodloader: loading kernel modules from //etc/modules-boot.d/*
Sat Jul 15 14:22:53 2023 user.info kernel: [    4.637828] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
Sat Jul 15 14:22:53 2023 user.info kernel: [    6.225607] block: attempting to load /etc/config/fstab
Sat Jul 15 14:22:53 2023 user.err kernel: [    6.230933] block: unable to load configuration (fstab: Entry not found)
Sat Jul 15 14:22:53 2023 user.err kernel: [    6.237628] block: no usable configuration
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    6.636255] F2FS-fs (mmcblk0p66): Mounted with checkpoint version = 351ed6be
Sat Jul 15 14:22:53 2023 user.info kernel: [    6.644959] mount_root: loading kmods from internal overlay
Sat Jul 15 14:22:53 2023 user.info kernel: [    6.672660] kmodloader: loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
Sat Jul 15 14:22:53 2023 user.info kernel: [    6.681757] kmodloader: done loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
Sat Jul 15 14:22:53 2023 user.info kernel: [    8.166767] block: attempting to load /etc/config/fstab
Sat Jul 15 14:22:53 2023 user.err kernel: [    8.172068] block: unable to load configuration (fstab: Entry not found)
Sat Jul 15 14:22:53 2023 user.err kernel: [    8.178760] block: no usable configuration
Sat Jul 15 14:22:53 2023 user.info kernel: [    8.183955] mount_root: switching to f2fs overlay
Sat Jul 15 14:22:53 2023 kern.warn kernel: [    8.190182] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
Sat Jul 15 14:22:53 2023 user.debug kernel: [    8.201762] urandom-seed: Seeding with /etc/urandom.seed
Sat Jul 15 14:22:53 2023 kern.info kernel: [    8.223583] mt7530-mdio mdio-bus:1f lan1: Link is Down
Sat Jul 15 14:22:53 2023 user.info kernel: [    8.232257] procd: - early -
Sat Jul 15 14:22:53 2023 user.info kernel: [    8.235182] procd: - watchdog -
Sat Jul 15 14:22:53 2023 user.info kernel: [    8.763649] procd: - watchdog -
Sat Jul 15 14:22:53 2023 user.info kernel: [    8.767692] procd: - ubus -
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    8.788737] random: ubusd: uninitialized urandom read (4 bytes read)
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    8.821268] random: ubusd: uninitialized urandom read (4 bytes read)
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    8.827753] random: ubusd: uninitialized urandom read (4 bytes read)
Sat Jul 15 14:22:53 2023 user.info kernel: [    8.837458] procd: - init -
Sat Jul 15 14:22:53 2023 user.info kernel: [    8.967107] urngd: v1.0.2 started.
Sat Jul 15 14:22:53 2023 user.info kernel: [    8.984950] kmodloader: loading kernel modules from /etc/modules.d/*
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    8.986201] random: crng init done
Sat Jul 15 14:22:53 2023 kern.notice kernel: [    8.994693] random: 24 urandom warning(s) missed due to ratelimiting
Sat Jul 15 14:22:53 2023 kern.info kernel: [    9.007988] i2c-gpio i2c-gpio-0: using lines 427 (SDA) and 428 (SCL)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    9.014846] i2c-gpio i2c-gpio-1: using lines 429 (SDA) and 430 (SCL)
Sat Jul 15 14:22:53 2023 kern.info kernel: [    9.023002] crypto-safexcel 10320000.crypto: EIP97:230(0,1,4,4)-HIA:270(0,5,5),PE:150/433(alg:7fcdfc00)/0/0/0
Sat Jul 15 14:22:53 2023 kern.info kernel: [    9.037163] Loading modules backported from Linux version v6.1.24-0-g0102425ac76b
Sat Jul 15 14:22:53 2023 kern.info kernel: [    9.044659] Backport generated by backports.git v5.15.92-1-44-gd6ea70fafd36
Sat Jul 15 14:22:53 2023 kern.info kernel: [    9.056305] sfp sfp-1: Host maximum power 1.0W
Sat Jul 15 14:22:53 2023 kern.info kernel: [    9.061533] sfp sfp-2: Host maximum power 1.0W
Sat Jul 15 14:22:53 2023 kern.info kernel: [    9.094597] PPP generic driver version 2.4.2
Sat Jul 15 14:22:53 2023 kern.info kernel: [    9.099486] NET: Registered PF_PPPOX protocol family
Sat Jul 15 14:22:53 2023 kern.info kernel: [    9.105736] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
Sat Jul 15 14:22:53 2023 kern.info kernel: [    9.113633] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <[email protected]>. All Rights Reserved.
Sat Jul 15 14:22:53 2023 user.info kernel: [    9.125444] kmodloader: done loading kernel modules from /etc/modules.d/*
Sat Jul 15 14:22:53 2023 kern.info kernel: [    9.409923] sfp sfp-2: module OEM              SFP-2.5G-T       rev 1.0  sn 2302130019       dc 230213
Sat Jul 15 14:22:53 2023 kern.info kernel: [    9.459108] hwmon hwmon1: temp1_input not attached to any thermal zone
Sat Jul 15 14:22:53 2023 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Sat Jul 15 14:22:53 2023 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Sat Jul 15 14:22:53 2023 daemon.info dnsmasq[1]: started, version 2.89 cachesize 150
Sat Jul 15 14:22:53 2023 daemon.info dnsmasq[1]: DNS service limited to local subnets
Sat Jul 15 14:22:53 2023 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-nftset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Sat Jul 15 14:22:53 2023 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Sat Jul 15 14:22:53 2023 daemon.info dnsmasq[1]: using nameserver 1.1.1.1#53
Sat Jul 15 14:22:53 2023 daemon.info dnsmasq[1]: using nameserver 8.8.8.8#53
Sat Jul 15 14:22:53 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Sat Jul 15 14:22:53 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Sat Jul 15 14:22:53 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Sat Jul 15 14:22:53 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Sat Jul 15 14:22:53 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Sat Jul 15 14:22:53 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Sat Jul 15 14:22:53 2023 daemon.warn dnsmasq[1]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Sat Jul 15 14:22:53 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Sat Jul 15 14:22:53 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Sat Jul 15 14:22:53 2023 user.notice : Added device handler type: bonding
Sat Jul 15 14:22:53 2023 user.notice : Added device handler type: 8021ad
Sat Jul 15 14:22:53 2023 user.notice : Added device handler type: 8021q
Sat Jul 15 14:22:53 2023 user.notice : Added device handler type: macvlan
Sat Jul 15 14:22:53 2023 user.notice : Added device handler type: veth
Sat Jul 15 14:22:53 2023 user.notice : Added device handler type: bridge
Sat Jul 15 14:22:53 2023 user.notice : Added device handler type: Network device
Sat Jul 15 14:22:53 2023 user.notice : Added device handler type: tunnel
Sat Jul 15 14:22:54 2023 daemon.notice wpa_supplicant[1581]: Successfully initialized wpa_supplicant
Sat Jul 15 14:22:54 2023 daemon.notice procd: /etc/rc.d/S25packet_steering: uci: Entry not found
Sat Jul 15 14:22:54 2023 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/network
Sat Jul 15 14:22:54 2023 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/wireless
Sat Jul 15 14:22:54 2023 user.notice ucitrack: Setting up /etc/config/luci-splash reload dependency on /etc/config/firewall
Sat Jul 15 14:22:54 2023 user.notice ucitrack: Setting up /etc/config/qos reload dependency on /etc/config/firewall
Sat Jul 15 14:22:54 2023 user.notice ucitrack: Setting up /etc/config/miniupnpd reload dependency on /etc/config/firewall
Sat Jul 15 14:22:54 2023 user.notice ucitrack: Setting up /etc/config/odhcpd reload dependency on /etc/config/dhcp
Sat Jul 15 14:22:54 2023 user.notice ucitrack: Setting up non-init /etc/config/fstab reload handler: /sbin/block mount
Sat Jul 15 14:22:54 2023 user.notice ucitrack: Setting up /etc/config/system reload trigger for non-procd /etc/init.d/led
Sat Jul 15 14:22:54 2023 user.notice ucitrack: Setting up /etc/config/luci_statistics reload dependency on /etc/config/system
Sat Jul 15 14:22:54 2023 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/system
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.390573] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.425027] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.433479] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.434494] device eth0 entered promiscuous mode
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.447289] mt7530-mdio mdio-bus:1f lan2: configuring for phy/gmii link mode
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.457233] br-lan: port 1(lan2) entered blocking state
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.462528] br-lan: port 1(lan2) entered disabled state
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.470125] device lan2 entered promiscuous mode
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.477200] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'lan' is enabled
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'lan' is setting up now
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'lan' is now up
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.491056] mt7530-mdio mdio-bus:1f sfp2: configuring for inband/2500base-x link mode
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.501467] br-lan: port 2(sfp2) entered blocking state
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.506717] br-lan: port 2(sfp2) entered disabled state
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.514113] device sfp2 entered promiscuous mode
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'homelab' is setting up now
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'homelab_mgmt' is enabled
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'homelab_mgmt' is setting up now
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'homelab_mgmt' is now up
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'loopback' is enabled
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'loopback' is setting up now
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'loopback' is now up
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'vpn' is setting up now
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.525227] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.537393] bonding: bond-homelab is being created...
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.538059] mt7530-mdio mdio-bus:1f wan: configuring for phy/gmii link mode
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'wan' is enabled
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'guest' is enabled
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'guest' is setting up now
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'guest' is now up
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Network device 'eth0' link is up
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Network device 'lo' link is up
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'loopback' has link connectivity
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Network device 'wan' link is up
Sat Jul 15 14:22:54 2023 daemon.notice netifd: VLAN 'wan.20' link is up
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'wan' has link connectivity
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'wan' is setting up now
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.555320] mt7530-mdio mdio-bus:1f wan: Link is Up - 1Gbps/Full - flow control off
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.563052] IPv6: ADDRCONF(NETDEV_CHANGE): wan.20: link becomes ready
Sat Jul 15 14:22:54 2023 kern.info kernel: [   13.569670] IPv6: ADDRCONF(NETDEV_CHANGE): wan: link becomes ready
Sat Jul 15 14:22:54 2023 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Sat Jul 15 14:22:54 2023 daemon.notice netifd: radio0 (2294): Phy not found
Sat Jul 15 14:22:54 2023 daemon.notice netifd: radio0 (2294): Could not find PHY for device 'radio0'
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Wireless device 'radio0' set retry=0
Sat Jul 15 14:22:54 2023 daemon.crit netifd: Wireless device 'radio0' setup failed, retry=0
Sat Jul 15 14:22:54 2023 daemon.notice netifd: radio1 (2295): Phy not found
Sat Jul 15 14:22:54 2023 daemon.notice netifd: radio1 (2295): Could not find PHY for device 'radio1'
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Wireless device 'radio1' set retry=0
Sat Jul 15 14:22:54 2023 daemon.crit netifd: Wireless device 'radio1' setup failed, retry=0
Sat Jul 15 14:22:54 2023 daemon.notice netifd: vpn (2240): Warning: AllowedIP has nonzero host part: 192.168.178.1/24
Sat Jul 15 14:22:54 2023 daemon.info pppd[2329]: Plugin pppoe.so loaded.
Sat Jul 15 14:22:54 2023 daemon.info pppd[2329]: PPPoE plugin from pppd 2.4.9
Sat Jul 15 14:22:54 2023 daemon.notice netifd: radio0 (2343): WARNING: Variable 'data' does not exist or is not an array/object
Sat Jul 15 14:22:54 2023 daemon.notice netifd: radio0 (2343): Bug: PHY is undefined for device 'radio0'
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Wireless device 'radio0' is now down
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Interface 'vpn' is now up
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Network device 'vpn' link is up
Sat Jul 15 14:22:54 2023 daemon.notice netifd: radio1 (2354): WARNING: Variable 'data' does not exist or is not an array/object
Sat Jul 15 14:22:54 2023 daemon.notice netifd: radio1 (2354): Bug: PHY is undefined for device 'radio1'
Sat Jul 15 14:22:54 2023 daemon.notice netifd: Wireless device 'radio1' is now down
Sat Jul 15 14:22:54 2023 daemon.info procd: - init complete -
Sat Jul 15 14:22:54 2023 daemon.notice pppd[2329]: pppd 2.4.9 started by root, uid 0
Sat Jul 15 14:22:55 2023 user.notice firewall: Reloading firewall due to ifup of homelab_mgmt (lan1)
Sat Jul 15 14:22:55 2023 user.notice firewall: Reloading firewall due to ifup of guest (br-guest)
Sat Jul 15 14:22:55 2023 authpriv.warn dropbear[2608]: Failed listening on '22': Error listening: Address not available
Sat Jul 15 14:22:55 2023 authpriv.info dropbear[2608]: Not backgrounding
Sat Jul 15 14:22:55 2023 kern.info kernel: [   14.579695] mt7530-mdio mdio-bus:1f lan3: configuring for phy/gmii link mode
Sat Jul 15 14:22:55 2023 kern.info kernel: [   14.587505] bond-homelab: (slave lan3): Enslaving as a backup interface with a down link
Sat Jul 15 14:22:55 2023 kern.info kernel: [   14.600078] mt7530-mdio mdio-bus:1f lan3: Link is Up - 1Gbps/Full - flow control off
Sat Jul 15 14:22:55 2023 daemon.notice netifd: Network device 'lan3' link is up
Sat Jul 15 14:22:55 2023 daemon.info pppd[2329]: PPP session is 5270
Sat Jul 15 14:22:56 2023 daemon.warn pppd[2329]: Connected to ac:1f:6b:ed:69:91 via interface wan.20
Sat Jul 15 14:22:56 2023 kern.info kernel: [   14.901082] pppoe-wan: renamed from ppp0
Sat Jul 15 14:22:56 2023 user.notice firewall: Reloading firewall due to ifup of vpn (vpn)
Sat Jul 15 14:22:56 2023 daemon.info pppd[2329]: Renamed interface ppp0 to pppoe-wan
Sat Jul 15 14:22:56 2023 daemon.info pppd[2329]: Using interface pppoe-wan
Sat Jul 15 14:22:56 2023 daemon.notice pppd[2329]: Connect: pppoe-wan <--> wan.20
Sat Jul 15 14:22:56 2023 daemon.notice pppd[2329]: PAP authentication succeeded
Sat Jul 15 14:22:56 2023 daemon.notice pppd[2329]: peer from calling number AC:1F:6B:ED:69:91 authorized
Sat Jul 15 14:22:56 2023 daemon.notice pppd[2329]: local  IP address 79.116.61.229
Sat Jul 15 14:22:56 2023 daemon.notice pppd[2329]: remote IP address 10.0.0.1
Sat Jul 15 14:22:56 2023 daemon.notice netifd: Network device 'pppoe-wan' link is up
Sat Jul 15 14:22:56 2023 daemon.notice pppd[2329]: primary   DNS address 100.90.1.1
Sat Jul 15 14:22:56 2023 daemon.notice netifd: Interface 'wan_6' has link connectivity
Sat Jul 15 14:22:56 2023 daemon.notice pppd[2329]: secondary DNS address 100.100.1.1
Sat Jul 15 14:22:56 2023 daemon.notice netifd: Interface 'wan_6' is enabled
Sat Jul 15 14:22:56 2023 daemon.notice netifd: Interface 'wan_6' is setting up now
Sat Jul 15 14:22:56 2023 daemon.notice netifd: Interface 'wan' is now up
Sat Jul 15 14:22:56 2023 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Sat Jul 15 14:22:56 2023 daemon.info dnsmasq[1]: using nameserver 1.1.1.1#53
Sat Jul 15 14:22:56 2023 daemon.info dnsmasq[1]: using nameserver 8.8.8.8#53
Sat Jul 15 14:22:56 2023 daemon.info dnsmasq[1]: using nameserver 100.90.1.1#53
Sat Jul 15 14:22:56 2023 daemon.info dnsmasq[1]: using nameserver 100.100.1.1#53
Sat Jul 15 14:22:56 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Sat Jul 15 14:22:56 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Sat Jul 15 14:22:56 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Sat Jul 15 14:22:56 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Sat Jul 15 14:22:56 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Sat Jul 15 14:22:56 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Sat Jul 15 14:22:56 2023 daemon.notice pppd[2329]: local  LL address fe80::0000:0000:4f74:3de5
Sat Jul 15 14:22:56 2023 daemon.notice pppd[2329]: remote LL address fe80::0000:0000:0000:0001
Sat Jul 15 14:22:56 2023 user.notice firewall: Reloading firewall due to ifup of wan (pppoe-wan)
Sat Jul 15 14:22:56 2023 kern.info kernel: [   15.605386] mt7530-mdio mdio-bus:1f lan4: configuring for phy/gmii link mode
Sat Jul 15 14:22:56 2023 kern.info kernel: [   15.615775] bond-homelab: (slave lan4): Enslaving as a backup interface with a down link
Sat Jul 15 14:22:56 2023 kern.info kernel: [   15.617239] mt7530-mdio mdio-bus:1f lan4: Link is Up - 1Gbps/Full - flow control off
Sat Jul 15 14:22:56 2023 daemon.notice netifd: Network device 'lan4' link is up
Sat Jul 15 14:22:56 2023 kern.warn kernel: [   15.633782] bond-homelab: Warning: No 802.3ad response from the link partner for any adapters in the bond
Sat Jul 15 14:22:56 2023 kern.info kernel: [   15.633838] 8021q: adding VLAN 0 to HW filter on device bond-homelab
Sat Jul 15 14:22:56 2023 kern.info kernel: [   15.649828] IPv6: ADDRCONF(NETDEV_CHANGE): bond-homelab: link becomes ready
Sat Jul 15 14:22:56 2023 daemon.notice netifd: Interface 'homelab_dhcp' is enabled
Sat Jul 15 14:22:56 2023 daemon.notice netifd: Interface 'homelab_dhcp' is setting up now
Sat Jul 15 14:22:56 2023 kern.info kernel: [   15.657761] bond-homelab: (slave lan3): link status definitely up, 1000 Mbps full duplex
Sat Jul 15 14:22:56 2023 kern.info kernel: [   15.665922] bond-homelab: active interface up!
Sat Jul 15 14:22:56 2023 kern.info kernel: [   15.670511] bond-homelab: (slave lan4): link status definitely up, 1000 Mbps full duplex
Sat Jul 15 14:22:56 2023 daemon.notice netifd: Interface 'homelab_dhcp' is now up
Sat Jul 15 14:22:56 2023 daemon.notice netifd: Interface 'homelab' is now up
Sat Jul 15 14:22:56 2023 daemon.notice netifd: Network device 'bond-homelab' link is up
Sat Jul 15 14:22:56 2023 daemon.notice netifd: Network alias 'bond-homelab' link is up
Sat Jul 15 14:22:56 2023 daemon.notice netifd: Interface 'homelab_dhcp' has link connectivity
Sat Jul 15 14:22:56 2023 user.notice firewall: Reloading firewall due to ifupdate of wan (pppoe-wan)
Sat Jul 15 14:22:57 2023 user.notice firewall: Reloading firewall due to ifup of homelab (bond-homelab)
Sat Jul 15 14:22:57 2023 daemon.notice netifd: Network device 'lan1' link is up
Sat Jul 15 14:22:57 2023 daemon.notice netifd: Interface 'homelab_mgmt' has link connectivity
Sat Jul 15 14:22:57 2023 kern.info kernel: [   16.413207] mt7530-mdio mdio-bus:1f lan1: Link is Up - 1Gbps/Full - flow control rx/tx
Sat Jul 15 14:22:57 2023 kern.info kernel: [   16.421155] IPv6: ADDRCONF(NETDEV_CHANGE): lan1: link becomes ready
Sat Jul 15 14:22:57 2023 user.notice firewall: Reloading firewall due to ifup of homelab_dhcp (bond-homelab)
Sat Jul 15 14:35:47 2023 kern.info kernel: [   17.670606] mt7530-mdio mdio-bus:1f sfp2: Link is Up - 2.5Gbps/Full - flow control off
Sat Jul 15 14:35:47 2023 kern.info kernel: [   17.678716] br-lan: port 2(sfp2) entered blocking state
Sat Jul 15 14:35:47 2023 kern.info kernel: [   17.683939] br-lan: port 2(sfp2) entered forwarding state
Sat Jul 15 14:35:47 2023 daemon.notice netifd: Network device 'sfp2' link is up
Sat Jul 15 14:35:47 2023 kern.info kernel: [   17.689787] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Sat Jul 15 14:35:47 2023 daemon.notice netifd: bridge 'br-lan' link is up
Sat Jul 15 14:35:47 2023 daemon.notice netifd: Interface 'lan' has link connectivity
Sat Jul 15 14:35:48 2023 daemon.warn odhcpd[1761]: No default route present, overriding ra_lifetime!
Sat Jul 15 14:35:50 2023 daemon.notice netifd: Interface 'wan_6' is now up
Sat Jul 15 14:35:50 2023 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Sat Jul 15 14:35:50 2023 daemon.info dnsmasq[1]: using nameserver 1.1.1.1#53
Sat Jul 15 14:35:50 2023 daemon.info dnsmasq[1]: using nameserver 8.8.8.8#53
Sat Jul 15 14:35:50 2023 daemon.info dnsmasq[1]: using nameserver 100.90.1.1#53
Sat Jul 15 14:35:50 2023 daemon.info dnsmasq[1]: using nameserver 100.100.1.1#53
Sat Jul 15 14:35:50 2023 daemon.info dnsmasq[1]: using nameserver 2a0c:5a80:0:2::1#53
Sat Jul 15 14:35:50 2023 daemon.info dnsmasq[1]: using nameserver 2a0c:5a84:0:2::1#53
Sat Jul 15 14:35:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Sat Jul 15 14:35:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Sat Jul 15 14:35:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Sat Jul 15 14:35:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Sat Jul 15 14:35:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Sat Jul 15 14:35:50 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Sat Jul 15 14:35:50 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Sat Jul 15 14:35:50 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 10 names
Sat Jul 15 14:35:50 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c.2610 - 14 names
Sat Jul 15 14:35:50 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 0 names
Sat Jul 15 14:35:50 2023 user.notice firewall: Reloading firewall due to ifup of wan_6 (pppoe-wan)
Sat Jul 15 14:35:54 2023 daemon.info dnsmasq[1]: exiting on receipt of SIGTERM
Sat Jul 15 14:35:54 2023 authpriv.info dropbear[2608]: Early exit: Terminated by signal
Sat Jul 15 14:35:54 2023 authpriv.info dropbear[3417]: Not backgrounding
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: started, version 2.89 cachesize 150
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: DNS service limited to local subnets
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-nftset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 10.10.20.100 -- 10.10.20.249, lease time 12h
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 10.10.10.100 -- 10.10.10.249, lease time 12h
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.100.100 -- 192.168.100.254, lease time 12h
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: using nameserver 1.1.1.1#53
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: using nameserver 8.8.8.8#53
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: using nameserver 100.90.1.1#53
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: using nameserver 100.100.1.1#53
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: using nameserver 2a0c:5a80:0:2::1#53
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: using nameserver 2a0c:5a84:0:2::1#53
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 26 names
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq[1]: read /tmp/hosts/odhcpd - 0 names
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.126 d8:5e:d3:de:bf:1c
Sat Jul 15 14:35:58 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.126 d8:5e:d3:de:bf:1c DESKTOP-288UDOO
Sat Jul 15 14:36:09 2023 daemon.err uhttpd[1882]: [info] luci: accepted login on /admin/status/logs for root from 192.168.1.126
For everybody that comes here:
Apparently OpenWRT for Banana Pi R3 does not install the packages kmod-mt7915e and kmod-mt7986-firmwarewhich I somehow managed not to install or uninstall somehow.
