[Solved] Banana Pi BPI-R3 OpenWRT constantly rebooting
Hi, I’m quite new user of BPI-R3 and trying several possibilities to run my own router on this board. I tried to use OpenWRT with several kernels even newest 6.14-rc from: GitHub - frank-w/BPI-Router-Linux: Linux kernel 4.14+ for BPI-R2, 5.4+ for R64, 6.1+ for R2Pro and R3 and on every kernel I’ve got the same issue - kernel panic and then reboot. The issue doesn’t occur when I remove support for MT6915E driver from the kernel.
Is this known issue or maybe I missed anything? What can I do here to get stable system with support for wifi interfaces?
Here are the logs:
> [2025-02-24 13:31:32] NOTICE:  BL2: v2.10.0	(release):OpenWrt v2024.01.17~bacca82a-3 (mt7986-sdmmc-ddr4)
> [2025-02-24 13:31:32] NOTICE:  BL2: Built : 23:09:37, Feb  3 2025
> [2025-02-24 13:31:32] NOTICE:  WDT: [40000000] Software reset (reboot)
> [2025-02-24 13:31:32] NOTICE:  WDT: disabled
> [2025-02-24 13:31:32] NOTICE:  CPU: MT7986 (2000MHz)
> [2025-02-24 13:31:32] NOTICE:  EMI: Using DDR4 settings
> [2025-02-24 13:31:33] NOTICE:  EMI: Detected DRAM size: 2048MB
> [2025-02-24 13:31:33] NOTICE:  EMI: complex R/W mem test passed
> [2025-02-24 13:31:33] NOTICE:  BL2: Booting BL31
> [2025-02-24 13:31:33] NOTICE:  BL31: v2.10.0	(release):OpenWrt v2024.01.17~bacca82a-3 (mt7986-sdmmc-ddr4)
> [2025-02-24 13:31:33] NOTICE:  BL31: Built : 23:09:37, Feb  3 2025
> [2025-02-24 13:31:33] U-Boot 2024.10-OpenWrt-r28427-6df0e3d02a (Feb 03 2025 - 23:09:37 +0000)
> [2025-02-24 13:31:33] CPU:   MediaTek MT7986
> [2025-02-24 13:31:33] Model: BananaPi BPi-R3
> [2025-02-24 13:31:33] DRAM:  2 GiB
> [2025-02-24 13:31:33] Core:  54 devices, 24 uclasses, devicetree: embed
> [2025-02-24 13:31:33] jedec_spi_nor spi_nor@0: unrecognized JEDEC id bytes: ff, ef, aa
> [2025-02-24 13:31:33] MMC:   mmc@11230000: 0
> [2025-02-24 13:31:33] Loading Environment from MMC... Reading from redundant MMC(0)... OK
> [2025-02-24 13:31:34] In:    serial@11002000
> [2025-02-24 13:31:34] Out:   serial@11002000
> [2025-02-24 13:31:34] Err:   serial@11002000
> [2025-02-24 13:31:34] Loading Environment from MMC... Reading from redundant MMC(0)... OK
> [2025-02-24 13:31:34] Net:   eth0: ethernet@15100000
> [2025-02-24 13:31:34]       ( ( ( OpenWrt ) ) )  [SD card]       U-Boot 2024.10-OpenWrt-r28427-6df0e3d02a (Feb 03 2025 - 23:09:37 +0000)Press UP/DOWN to move, ENTER to select, ESC to quit1. Run default boot command.2. Boot system via TFTP.3. Boot production system from SD card.4. Boot recovery system from SD card.5. Load production system via TFTP then write to SD card.6. Load recovery system via TFTP then write to SD card.7. Install bootloader, recovery and production to NOR.8. Install bootloader, recovery and production to NAND.9. Reboot.a. Reset all settings to factory defaults.0. ExitHit any key to stop autoboot: 3 Hit any key to stop autoboot: 2 Hit any key to stop autoboot: 1 spi-nand: spi_nand spi_nand@1: Winbond SPI NAND was found.
> [2025-02-24 13:31:37] spi-nand: spi_nand spi_nand@1: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
> [2025-02-24 13:31:37] jedec_spi_nor spi_nor@0: unrecognized JEDEC id bytes: 00, ef, aa
> [2025-02-24 13:31:37] 'spi-nand0' is now active device
> [2025-02-24 13:31:37] * spi-nand0
> [2025-02-24 13:31:37]   - device: spi_nand@1
> [2025-02-24 13:31:37]   - parent: spi@1100a000
> [2025-02-24 13:31:37]   - driver: spi_nand
> [2025-02-24 13:31:37]   - type: NAND flash
> [2025-02-24 13:31:37]   - block size:        0x20000 bytes
> [2025-02-24 13:31:37]   - page size:         0x800 bytes
> [2025-02-24 13:31:37]   - OOB size:          64 bytes
> [2025-02-24 13:31:37]   - OOB available:     24 bytes
> [2025-02-24 13:31:37]   - 0x000000000000-0x000008000000 : "spi-nand0"
> [2025-02-24 13:31:37] 	  - 0x000000000000-0x000000200000 : "bl2"
> [2025-02-24 13:31:37] 	  - 0x000000200000-0x000008000000 : "ubi"
> [2025-02-24 13:31:37] MMC read: dev # 0, block # 24576, count 256 ... 256 blocks read: OK
> [2025-02-24 13:31:37] MMC read: dev # 0, block # 24576, count 18096 ... 18096 blocks read: OK
> [2025-02-24 13:31:38] ## Loading kernel from FIT Image at 46000000 ...
> [2025-02-24 13:31:38]    Using 'config-mt7986a-bananapi-bpi-r3' configuration
> [2025-02-24 13:31:38]    Trying 'kernel-1' kernel subimage
> [2025-02-24 13:31:38]      Description:  ARM64 OpenWrt Linux-6.6.73
> [2025-02-24 13:31:38]      Type:         Kernel Image
> [2025-02-24 13:31:38]      Compression:  lzma compressed
> [2025-02-24 13:31:38]      Data Start:   0x460000e8
> [2025-02-24 13:31:38]      Data Size:    4124961 Bytes = 3.9 MiB
> [2025-02-24 13:31:38]      Architecture: AArch64
> [2025-02-24 13:31:38]      OS:           Linux
> [2025-02-24 13:31:38]      Load Address: 0x44000000
> [2025-02-24 13:31:38]      Entry Point:  0x44000000
> [2025-02-24 13:31:38]      Hash algo:    crc32
> [2025-02-24 13:31:38]      Hash value:   872f6c71
> [2025-02-24 13:31:38]      Hash algo:    sha1
> [2025-02-24 13:31:38]      Hash value:   e44c0ac56c0d22984d001156c566c5ec86fea5c8
> [2025-02-24 13:31:38]    Verifying Hash Integrity ... crc32+ sha1+ OK
> [2025-02-24 13:31:38] ## Loading ramdisk from FIT Image at 46000000 ...
> [2025-02-24 13:31:38]    Trying 'initrd-1' ramdisk subimage
> [2025-02-24 13:31:38]      Description:  ARM64 OpenWrt bananapi_bpi-r3 initrd
> [2025-02-24 13:31:38]      Type:         RAMDisk Image
> [2025-02-24 13:31:38]      Compression:  uncompressed
> [2025-02-24 13:31:38]      Data Start:   0x463ef348
> [2025-02-24 13:31:38]      Data Size:    5098164 Bytes = 4.9 MiB
> [2025-02-24 13:31:38]      Load Address: unavailable
> [2025-02-24 13:31:38]      Entry Point:  unavailable
> [2025-02-24 13:31:38]      Hash value:   b1d06b06
> [2025-02-24 13:31:38]      Hash value:   430f3df6fa295385f7f063305c9c5bd3eec6dc09
> [2025-02-24 13:31:38] ## Loading fdt from FIT Image at 46000000 ...
> [2025-02-24 13:31:38]    Trying 'fdt-1' fdt subimage
> [2025-02-24 13:31:38]      Description:  ARM64 OpenWrt bananapi_bpi-r3 device tree blob
> [2025-02-24 13:31:38]      Type:         Flat Device Tree
> [2025-02-24 13:31:38]      Data Start:   0x468cbf08
> [2025-02-24 13:31:38]      Data Size:    31935 Bytes = 31.2 KiB
> [2025-02-24 13:31:38]      Load Address: 0x43f00000
> [2025-02-24 13:31:38]      Hash value:   fae8a5f6
> [2025-02-24 13:31:38]      Hash value:   4487cda227d6248f1d6cf259593bedbbfc609872
> [2025-02-24 13:31:38]    Loading fdt from 0x468cbf08 to 0x43f00000
> [2025-02-24 13:31:38]    Using 'mt7986a-bananapi-bpi-r3-sd' configuration
> [2025-02-24 13:31:38]    Trying 'fdt-mt7986a-bananapi-bpi-r3-sd' fdt subimage
> [2025-02-24 13:31:38]      Description:  ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-sd
> [2025-02-24 13:31:38]      Data Start:   0x468d4e20
> [2025-02-24 13:31:38]      Data Size:    836 Bytes = 836 Bytes
> [2025-02-24 13:31:38]      Hash value:   d42f2ae8
> [2025-02-24 13:31:38]      Hash value:   17df94373cd82dec3921ddc92c3a61bcc4cef81d
> [2025-02-24 13:31:38]    Using 'mt7986a-bananapi-bpi-r3-nand' configuration
> [2025-02-24 13:31:38]    Trying 'fdt-mt7986a-bananapi-bpi-r3-nand' fdt subimage
> [2025-02-24 13:31:38]      Description:  ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nand
> [2025-02-24 13:31:38]      Data Start:   0x468d4248
> [2025-02-24 13:31:38]      Data Size:    1166 Bytes = 1.1 KiB
> [2025-02-24 13:31:38]      Hash value:   80cf140c
> [2025-02-24 13:31:38]      Hash value:   cd9c9ecb32a6ebeb009f82eb718e49d29feff6a1
> [2025-02-24 13:31:38]    Booting using the fdt blob at 0x43f00000
> [2025-02-24 13:31:38] Working FDT set to 43f00000
> [2025-02-24 13:31:38]    Uncompressing Kernel Image to 44000000
> [2025-02-24 13:31:39]    Loading Ramdisk to be30e000, end be7eaab4 ... OK
> [2025-02-24 13:31:39]    Loading Device Tree to 00000000be303000, end 00000000be30d112 ... OK
> [2025-02-24 13:31:39] Working FDT set to be303000
> [2025-02-24 13:31:39] Add 'ramoops@42ff0000' node failed: FDT_ERR_EXISTS
> [2025-02-24 13:31:39] set /chosen/rootdisk to bootrom media: rootdisk-sd (phandle 0x00000059)
> [2025-02-24 13:31:39] Starting kernel ...
> [2025-02-24 13:31:39] [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
> [2025-02-24 13:31:39] [    0.000000] Linux version 6.6.73 (builder@buildhost) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 13.3.0 r28427-6df0e3d02a) 13.3.0, GNU ld (GNU Binutils) 2.42) #0 SMP Mon Feb  3 23:09:37 2025
> [2025-02-24 13:31:39] [    0.000000] Machine model: Bananapi BPI-R3
> [2025-02-24 13:31:39] [    0.000000] OF: reserved mem: 0x0000000042ff0000..0x0000000042ffffff (64 KiB) map non-reusable ramoops@42ff0000
> [2025-02-24 13:31:39] [    0.000000] OF: reserved mem: 0x0000000043000000..0x000000004302ffff (192 KiB) nomap non-reusable secmon@43000000
> [2025-02-24 13:31:39] [    0.000000] OF: reserved mem: 0x000000004fc00000..0x000000004fcfffff (1024 KiB) nomap non-reusable wmcpu-reserved@4fc00000
> [2025-02-24 13:31:39] [    0.000000] OF: reserved mem: 0x000000004fd00000..0x000000004fd3ffff (256 KiB) nomap non-reusable wo-emi@4fd00000
> [2025-02-24 13:31:39] [    0.000000] OF: reserved mem: 0x000000004fd40000..0x000000004fd7ffff (256 KiB) nomap non-reusable wo-emi@4fd40000
> [2025-02-24 13:31:39] [    0.000000] OF: reserved mem: 0x000000004fd80000..0x000000004ffbffff (2304 KiB) nomap non-reusable wo-data@4fd80000
> [2025-02-24 13:31:39] [    0.000000] Zone ranges:
> [2025-02-24 13:31:39] [    0.000000]   DMA      [mem 0x0000000040000000-0x00000000bfffffff]
> [2025-02-24 13:31:39] [    0.000000]   DMA32    empty
> [2025-02-24 13:31:39] [    0.000000]   Normal   empty
> [2025-02-24 13:31:39] [    0.000000] Movable zone start for each node
> [2025-02-24 13:31:39] [    0.000000] Early memory node ranges
> [2025-02-24 13:31:39] [    0.000000]   node   0: [mem 0x0000000040000000-0x0000000042ffffff]
> [2025-02-24 13:31:39] [    0.000000]   node   0: [mem 0x0000000043000000-0x000000004302ffff]
> [2025-02-24 13:31:39] [    0.000000]   node   0: [mem 0x0000000043030000-0x000000004fbfffff]
> [2025-02-24 13:31:39] [    0.000000]   node   0: [mem 0x000000004fc00000-0x000000004ffbffff]
> [2025-02-24 13:31:39] [    0.000000]   node   0: [mem 0x000000004ffc0000-0x00000000bfffffff]
> [2025-02-24 13:31:39] [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
> [2025-02-24 13:31:39] [    0.000000] psci: probing for conduit method from DT.
> [2025-02-24 13:31:39] [    0.000000] psci: PSCIv1.1 detected in firmware.
> [2025-02-24 13:31:39] [    0.000000] psci: Using standard PSCI v0.2 function IDs
> [2025-02-24 13:31:39] [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
> [2025-02-24 13:31:39] [    0.000000] psci: SMC Calling Convention v1.4
> [2025-02-24 13:31:39] [    0.000000] percpu: Embedded 18 pages/cpu s35560 r8192 d29976 u73728
> [2025-02-24 13:31:39] [    0.000000] pcpu-alloc: s35560 r8192 d29976 u73728 alloc=18*4096
> [2025-02-24 13:31:39] [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
> [2025-02-24 13:31:39] [    0.000000] Detected VIPT I-cache on CPU0
> [2025-02-24 13:31:39] [    0.000000] CPU features: detected: GIC system register CPU interface
> [2025-02-24 13:31:39] [    0.000000] CPU features: kernel page table isolation disabled by kernel configuration
> [2025-02-24 13:31:39] [    0.000000] alternatives: applying boot alternatives
> [2025-02-24 13:31:39] [    0.000000] Kernel command line: root=/dev/fit0 rootwait
> [2025-02-24 13:31:39] [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
> [2025-02-24 13:31:39] [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
> [2025-02-24 13:31:39] [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
> [2025-02-24 13:31:39] [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
> [2025-02-24 13:31:39] [    0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 2MB
> [2025-02-24 13:31:39] [    0.000000] software IO TLB: area num 4.
> [2025-02-24 13:31:39] [    0.000000] software IO TLB: mapped [mem 0x00000000bf67f000-0x00000000bf87f000] (2MB)
> [2025-02-24 13:31:39] [    0.000000] Memory: 2032988K/2097152K available (9024K kernel code, 998K rwdata, 1672K rodata, 448K init, 305K bss, 64164K reserved, 0K cma-reserved)
> [2025-02-24 13:31:39] [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
> [2025-02-24 13:31:39] [    0.000000] rcu: Hierarchical RCU implementation.
> [2025-02-24 13:31:39] [    0.000000] 	Tracing variant of Tasks RCU enabled.
> [2025-02-24 13:31:39] [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
> [2025-02-24 13:31:39] [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
> [2025-02-24 13:31:39] [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
> [2025-02-24 13:31:39] [    0.000000] GICv3: 640 SPIs implemented
> [2025-02-24 13:31:39] [    0.000000] GICv3: 0 Extended SPIs implemented
> [2025-02-24 13:31:39] [    0.000000] Root IRQ handler: 0xffffffc080010080
> [2025-02-24 13:31:39] [    0.000000] GICv3: GICv3 features: 16 PPIs
> [2025-02-24 13:31:39] [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
> [2025-02-24 13:31:39] [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
> [2025-02-24 13:31:39] [    0.000000] arch_timer: cp15 timer(s) running at 13.00MHz (phys).
> [2025-02-24 13:31:39] [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2ff89eacb, max_idle_ns: 440795202429 ns
> [2025-02-24 13:31:39] [    0.000001] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
> [2025-02-24 13:31:39] [    0.000069] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
> [2025-02-24 13:31:39] [    0.000077] pid_max: default: 32768 minimum: 301
> [2025-02-24 13:31:39] [    0.002108] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
> [2025-02-24 13:31:39] [    0.002118] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
> [2025-02-24 13:31:39] [    0.003698] cacheinfo: Unable to detect cache hierarchy for CPU 0
> [2025-02-24 13:31:39] [    0.004077] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
> [2025-02-24 13:31:39] [    0.004181] rcu: Hierarchical SRCU implementation.
> [2025-02-24 13:31:39] [    0.004182] rcu: 	Max phase no-delay instances is 1000.
> [2025-02-24 13:31:39] [    0.004505] smp: Bringing up secondary CPUs ...
> [2025-02-24 13:31:39] [    0.004766] Detected VIPT I-cache on CPU1
> [2025-02-24 13:31:39] [    0.004801] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
> [2025-02-24 13:31:39] [    0.004830] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
> [2025-02-24 13:31:39] [    0.005125] Detected VIPT I-cache on CPU2
> [2025-02-24 13:31:39] [    0.005146] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
> [2025-02-24 13:31:39] [    0.005156] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
> [2025-02-24 13:31:39] [    0.005416] Detected VIPT I-cache on CPU3
> [2025-02-24 13:31:39] [    0.005433] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
> [2025-02-24 13:31:39] [    0.005443] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
> [2025-02-24 13:31:39] [    0.005470] smp: Brought up 1 node, 4 CPUs
> [2025-02-24 13:31:39] [    0.005474] SMP: Total of 4 processors activated.
> [2025-02-24 13:31:39] [    0.005477] CPU features: detected: 32-bit EL0 Support
> [2025-02-24 13:31:39] [    0.005480] CPU features: detected: CRC32 instructions
> [2025-02-24 13:31:39] [    0.005506] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
> [2025-02-24 13:31:39] [    0.005509] CPU: All CPU(s) started at EL2
> [2025-02-24 13:31:39] [    0.005510] alternatives: applying system-wide alternatives
> [2025-02-24 13:31:39] [    0.008597] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
> [2025-02-24 13:31:39] [    0.008614] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
> [2025-02-24 13:31:39] [    0.009506] pinctrl core: initialized pinctrl subsystem
> [2025-02-24 13:31:39] [    0.010437] NET: Registered PF_NETLINK/PF_ROUTE protocol family
> [2025-02-24 13:31:39] [    0.010697] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
> [2025-02-24 13:31:39] [    0.010723] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
> [2025-02-24 13:31:39] [    0.010746] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
> [2025-02-24 13:31:39] [    0.011065] thermal_sys: Registered thermal governor 'fair_share'
> [2025-02-24 13:31:39] [    0.011068] thermal_sys: Registered thermal governor 'bang_bang'
> [2025-02-24 13:31:39] [    0.011070] thermal_sys: Registered thermal governor 'step_wise'
> [2025-02-24 13:31:39] [    0.011072] thermal_sys: Registered thermal governor 'user_space'
> [2025-02-24 13:31:39] [    0.011120] ASID allocator initialised with 65536 entries
> [2025-02-24 13:31:39] [    0.011891] pstore: Using crash dump compression: deflate
> [2025-02-24 13:31:39] [    0.011895] pstore: Registered ramoops as persistent store backend
> [2025-02-24 13:31:40] [    0.011897] ramoops: using 0x10000@0x42ff0000, ecc: 0
> [2025-02-24 13:31:40] [    0.013055] /soc/interrupt-controller@c000000: Fixed dependency cycle(s) with /soc/interrupt-controller@c000000
> [2025-02-24 13:31:40] [    0.018996] Modules: 29616 pages in range for non-PLT usage
> [2025-02-24 13:31:40] [    0.019005] Modules: 521136 pages in range for PLT usage
> [2025-02-24 13:31:40] [    0.019922] cryptd: max_cpu_qlen set to 1000
> [2025-02-24 13:31:40] [    0.020821] SCSI subsystem initialized
> [2025-02-24 13:31:40] [    0.020916] libata version 3.00 loaded.
> [2025-02-24 13:31:40] [    0.021967] clocksource: Switched to clocksource arch_sys_counter
> [2025-02-24 13:31:40] [    0.023603] NET: Registered PF_INET protocol family
> [2025-02-24 13:31:40] [    0.023722] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
> [2025-02-24 13:31:40] [    0.025356] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
> [2025-02-24 13:31:40] [    0.025372] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
> [2025-02-24 13:31:40] [    0.025380] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
> [2025-02-24 13:31:40] [    0.025448] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
> [2025-02-24 13:31:40] [    0.025788] TCP: Hash tables configured (established 16384 bind 16384)
> [2025-02-24 13:31:40] [    0.026082] MPTCP token hash table entries: 2048 (order: 3, 49152 bytes, linear)
> [2025-02-24 13:31:40] [    0.026188] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
> [2025-02-24 13:31:40] [    0.026219] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
> [2025-02-24 13:31:40] [    0.026489] NET: Registered PF_UNIX/PF_LOCAL protocol family
> [2025-02-24 13:31:40] [    0.026513] PCI: CLS 0 bytes, default 64
> [2025-02-24 13:31:40] [    0.026692] Unpacking initramfs...
> [2025-02-24 13:31:40] [    0.032903] workingset: timestamp_bits=46 max_order=19 bucket_order=0
> [2025-02-24 13:31:40] [    0.036219] squashfs: version 4.0 (2009/01/31) Phillip Lougher
> [2025-02-24 13:31:40] [    0.036223] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
> [2025-02-24 13:31:40] [    0.057880] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
> [2025-02-24 13:31:40] [    0.059539] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
> [2025-02-24 13:31:40] [    0.059558] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
> [2025-02-24 13:31:40] [    0.059567] mtk-pcie-gen3 11280000.pcie:      MEM 0x0020000000..0x002fffffff -> 0x0020000000
> [2025-02-24 13:31:40] [    0.059667] /soc/pcie@11280000: Failed to get clk index: 0 ret: -517
> [2025-02-24 13:31:40] [    0.059676] mtk-pcie-gen3 11280000.pcie: failed to get clocks
> [2025-02-24 13:31:40] [    0.062612] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
> [2025-02-24 13:31:40] [    0.065381] printk: console [ttyS0] disabled
> [2025-02-24 13:31:40] [    0.085731] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 116, base_baud = 2500000) is a ST16650V2
> [2025-02-24 13:31:40] [    0.085781] printk: console [ttyS0] enabled
> [2025-02-24 13:31:40] [    0.932328] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 117, base_baud = 1625000) is a ST16650V2
> [2025-02-24 13:31:40] [    0.962527] 11004000.serial: ttyS2 at MMIO 0x11004000 (irq = 118, base_baud = 1625000) is a ST16650V2
> [2025-02-24 13:31:40] [    0.972597] mtk_rng 1020f000.rng: registered RNG driver
> [2025-02-24 13:31:40] [    0.980844] loop: module loaded
> [2025-02-24 13:31:40] [    0.985745] spi-nand spi0.0: Winbond SPI NAND was found.
> [2025-02-24 13:31:40] [    0.991094] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
> [2025-02-24 13:31:40] [    1.037633] Freeing initrd memory: 4976K
> [2025-02-24 13:31:40] [    1.047189] 2 fixed-partitions partitions found on MTD device spi0.0
> [2025-02-24 13:31:40] [    1.053584] OF: Bad cell count for /soc/spi@1100a000/spi_nand@0/partitions
> [2025-02-24 13:31:40] [    1.060453] OF: Bad cell count for /soc/spi@1100a000/spi_nand@0/partitions
> [2025-02-24 13:31:40] [    1.067552] Creating 2 MTD partitions on "spi0.0":
> [2025-02-24 13:31:40] [    1.072338] 0x000000200000-0x000008000000 : "ubi"
> [2025-02-24 13:31:40] [    1.213097] ubi0: default fastmap pool size: 50
> [2025-02-24 13:31:40] [    1.217635] ubi0: default fastmap WL pool size: 25
> [2025-02-24 13:31:40] [    1.222419] ubi0: attaching mtd0
> [2025-02-24 13:31:44] [    4.931976] ubi0: scanning is finished
> [2025-02-24 13:31:44] [    4.977227] ubi0: attached mtd0 (name "ubi", size 126 MiB)
> [2025-02-24 13:31:44] [    4.982724] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
> [2025-02-24 13:31:44] [    4.989577] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
> [2025-02-24 13:31:44] [    4.996347] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
> [2025-02-24 13:31:44] [    5.003289] ubi0: good PEBs: 1008, bad PEBs: 0, corrupted PEBs: 0
> [2025-02-24 13:31:44] [    5.009362] ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
> [2025-02-24 13:31:44] [    5.016563] ubi0: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 1642748947
> [2025-02-24 13:31:44] [    5.025671] ubi0: available PEBs: 493, total reserved PEBs: 515, PEBs reserved for bad PEB handling: 20
> [2025-02-24 13:31:44] [    5.035050] ubi0: background thread "ubi_bgt0d" started, PID 291
> [2025-02-24 13:31:44] [    5.037329] block ubiblock0_1: created from ubi0:1(rootfs)
> [2025-02-24 13:31:44] [    5.046531] ubiblock: device ubiblock0_1 (rootfs) set to be root filesystem
> [2025-02-24 13:31:44] [    5.053595] 0x000000000000-0x000000200000 : "bl2"
> [2025-02-24 13:31:44] [    5.193243] mtk_soc_eth 15100000.ethernet: generated random MAC address 65:74:68:25:64:00
> [2025-02-24 13:31:44] [    5.204005] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc085a80000, irq 123
> [2025-02-24 13:31:44] [    5.213809] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc085a80000, irq 123
> [2025-02-24 13:31:44] [    5.223506] i2c_dev: i2c /dev entries driver
> [2025-02-24 13:31:44] [    5.229701] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
> [2025-02-24 13:31:44] [    5.238361] NET: Registered PF_INET6 protocol family
> [2025-02-24 13:31:44] [    5.243958] Segment Routing with IPv6
> [2025-02-24 13:31:44] [    5.247627] In-situ OAM (IOAM) with IPv6
> [2025-02-24 13:31:44] [    5.251570] NET: Registered PF_PACKET protocol family
> [2025-02-24 13:31:44] [    5.256662] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
> [2025-02-24 13:31:44] [    5.269762] 8021q: 802.1Q VLAN Support v1.8
> [2025-02-24 13:31:44] [    5.287475] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
> [2025-02-24 13:31:44] [    5.294806] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
> [2025-02-24 13:31:44] [    5.301058] mtk-pcie-gen3 11280000.pcie:      MEM 0x0020000000..0x002fffffff -> 0x0020000000
> [2025-02-24 13:31:44] [    5.309530] debugfs: File 'type' in directory 'phy-soc:[email protected]' already present!
> [2025-02-24 13:31:44] [    5.317714] debugfs: File 'efuse' in directory 'phy-soc:[email protected]' already present!
> [2025-02-24 13:31:44] [    5.325978] debugfs: File 'intr' in directory 'phy-soc:[email protected]' already present!
> [2025-02-24 13:31:44] [    5.334146] debugfs: File 'tx-imp' in directory 'phy-soc:[email protected]' already present!
> [2025-02-24 13:31:44] [    5.342487] debugfs: File 'rx-imp' in directory 'phy-soc:[email protected]' already present!
> [2025-02-24 13:31:44] [    5.681982] mtk-pcie-gen3 11280000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
> [2025-02-24 13:31:45] [    5.690787] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
> [2025-02-24 13:31:45] [    5.806087] mt7530-mdio mdio-bus:1f: configuring for fixed/2500base-x link mode
> [2025-02-24 13:31:45] [    5.815054] mt7530-mdio mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
> [2025-02-24 13:31:45] [    5.825533] mt7530-mdio mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=128)
> [2025-02-24 13:31:45] [    5.847630] mt7530-mdio mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=129)
> [2025-02-24 13:31:45] [    5.869594] mt7530-mdio mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=130)
> [2025-02-24 13:31:45] [    5.891520] mt7530-mdio mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=131)
> [2025-02-24 13:31:45] [    5.913451] mt7530-mdio mdio-bus:1f lan4 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=132)
> [2025-02-24 13:31:45] [    5.924757] mtk_soc_eth 15100000.ethernet eth0: entered promiscuous mode
> [2025-02-24 13:31:45] [    5.931478] DSA: tree 0 setup
> [2025-02-24 13:31:45] [    5.934997] clk: Disabling unused clocks
> [2025-02-24 13:31:45] [    5.961849] Freeing unused kernel memory: 448K
> [2025-02-24 13:31:45] [    5.966345] Run /init as init process
> [2025-02-24 13:31:45] [    5.969991]   with arguments:
> [2025-02-24 13:31:45] [    5.973011]     /init
> [2025-02-24 13:31:45] [    5.975270]   with environment:
> [2025-02-24 13:31:45] [    5.978394]     HOME=/
> [2025-02-24 13:31:45] [    5.980738]     TERM=linux
> [2025-02-24 13:31:45] [    5.994901] mmc0: host does not support reading read-only switch, assuming write-enable
> [2025-02-24 13:31:45] [    6.004858] mmc0: new high speed SDXC card at address 59b4
> [2025-02-24 13:31:45] [    6.011413] mmcblk0: mmc0:59b4 SD64G 59.4 GiB
> [2025-02-24 13:31:45] [    6.020318] Alternate GPT is invalid, using primary GPT.
> [2025-02-24 13:31:45] [    6.025787]  mmcblk0: p1 p2 p3 p4 p5 p6 p7
> [2025-02-24 13:31:45] [    6.031855] FIT: Detected U-Boot 2024.10-OpenWrt-r28427-6df0e3d02a
> [2025-02-24 13:31:45] [    6.038107] FIT: Selected configuration: "config-mt7986a-bananapi-bpi-r3" (OpenWrt bananapi_bpi-r3)
> [2025-02-24 13:31:45] [    6.047191] FIT:           kernel sub-image 0x00001000..0x00560599 "kernel-1" (ARM64 OpenWrt Linux-6.6.73)
> [2025-02-24 13:31:45] [    6.056950] FIT:          flat_dt sub-image 0x00561000..0x00568cbe "fdt-1" (ARM64 OpenWrt bananapi_bpi-r3 device tree blob)
> [2025-02-24 13:31:45] [    6.068176] FIT:          flat_dt sub-image 0x00569000..0x005693dd "fdt-mt7986a-bananapi-bpi-r3-emmc" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-emmc)
> [2025-02-24 13:31:45] [    6.084511] FIT:          flat_dt sub-image 0x0056a000..0x0056a48d "fdt-mt7986a-bananapi-bpi-r3-nand" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nand)
> [2025-02-24 13:31:45] [    6.100857] FIT:          flat_dt sub-image 0x0056b000..0x0056b4bd "fdt-mt7986a-bananapi-bpi-r3-nor" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-nor)
> [2025-02-24 13:31:45] [    6.117022] FIT:          flat_dt sub-image 0x0056c000..0x0056c343 "fdt-mt7986a-bananapi-bpi-r3-sd" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-sd)
> [2025-02-24 13:31:45] [    6.133017] FIT:          flat_dt sub-image 0x0056d000..0x0056d555 "fdt-mt7986a-bananapi-bpi-r3-respeaker-2mics" (ARM64 OpenWrt bananapi_bpi-r3 device tree overlay mt7986a-bananapi-bpi-r3-respeaker-2mics)
> [2025-02-24 13:31:45] [    6.151273] FIT:       filesystem sub-image 0x0056e000..0x00b0dfff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r3 rootfs)
> [2025-02-24 13:31:45] [    6.162077] init: Console is alive
> [2025-02-24 13:31:45] [    6.162338] block mmcblk0p7: mapped 1 uImage.FIT filesystem sub-image as /dev/fit0
> [2025-02-24 13:31:45] [    6.165605] init: - watchdog -
> [2025-02-24 13:31:45] [    6.173316] block mmcblk0p7: mapped remaining space as /dev/fitrw
> [2025-02-24 13:31:45] [    6.179900] kmodloader: loading kernel modules from /etc/modules-boot.d/*
> [2025-02-24 13:31:45] [    6.194297] usbcore: registered new interface driver usbfs
> [2025-02-24 13:31:45] [    6.199814] usbcore: registered new interface driver hub
> [2025-02-24 13:31:45] [    6.205170] usbcore: registered new device driver usb
> [2025-02-24 13:31:45] [    6.210644] gpio_button_hotplug: loading out-of-tree module taints kernel.
> [2025-02-24 13:31:45] [    6.222515] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
> [2025-02-24 13:31:45] [    6.229943] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
> [2025-02-24 13:31:45] [    6.238305] xhci-mtk 11200000.usb: xHCI Host Controller
> [2025-02-24 13:31:45] [    6.243614] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
> [2025-02-24 13:31:45] [    6.254080] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000200010
> [2025-02-24 13:31:45] [    6.263231] xhci-mtk 11200000.usb: irq 134, io mem 0x11200000
> [2025-02-24 13:31:45] [    6.269040] xhci-mtk 11200000.usb: xHCI Host Controller
> [2025-02-24 13:31:45] [    6.274254] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
> [2025-02-24 13:31:45] [    6.281632] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
> [2025-02-24 13:31:45] [    6.289011] hub 1-0:1.0: USB hub found
> [2025-02-24 13:31:45] [    6.292792] hub 1-0:1.0: 2 ports detected
> [2025-02-24 13:31:45] [    6.297072] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
> [2025-02-24 13:31:45] [    6.305419] hub 2-0:1.0: USB hub found
> [2025-02-24 13:31:45] [    6.309174] hub 2-0:1.0: 1 port detected
> [2025-02-24 13:31:45] [    6.315912] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
> [2025-02-24 13:31:45] [    6.327523] init: - preinit -
> [2025-02-24 13:31:45] [    6.403989] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
> [2025-02-24 13:31:45] [    6.412540] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
> [2025-02-24 13:31:45] [    6.430642] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
> [2025-02-24 13:31:45] [    6.444061] mt7530-mdio mdio-bus:1f lan1: Link is Up - 100Mbps/Full - flow control rx/tx
> [2025-02-24 13:31:45] Press the [f] key and hit [enter] to enter failsafe mode
> [2025-02-24 13:31:45] Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
> [2025-02-24 13:31:46] [    6.771969] usb 1-1: new high-speed USB device number 2 using xhci-mtk
> [2025-02-24 13:31:46] [    6.964123] hub 1-1:1.0: USB hub found
> [2025-02-24 13:31:46] [    6.971763] hub 1-1:1.0: 4 ports detected
> [2025-02-24 13:31:48] [    9.401971] random: crng init done
> [2025-02-24 13:31:49] [   10.657520] mt7530-mdio mdio-bus:1f lan1: Link is Down
> [2025-02-24 13:31:49] [   10.665837] procd: - early -
> [2025-02-24 13:31:49] [   10.668763] procd: - watchdog -
> [2025-02-24 13:31:50] [   11.189490] procd: - watchdog -
> [2025-02-24 13:31:50] [   11.192788] procd: - ubus -
> [2025-02-24 13:31:50] [   11.246348] procd: - init -
> [2025-02-24 13:31:50] Please press Enter to activate this console.
> [2025-02-24 13:31:50] [   11.372805] kmodloader: loading kernel modules from /etc/modules.d/*
> [2025-02-24 13:31:50] [   11.384607] i2c-gpio i2c-gpio-0: using lines 528 (SDA) and 529 (SCL)
> [2025-02-24 13:31:50] [   11.391287] i2c-gpio i2c-gpio-1: using lines 530 (SDA) and 531 (SCL)
> [2025-02-24 13:31:50] [   11.401351] crypto-safexcel 10320000.crypto: EIP97:230(0,1,4,4)-HIA:270(0,5,5),PE:150/433(alg:7fcdfc00)/0/0/0
> [2025-02-24 13:31:50] [   11.413746] Loading modules backported from Linux version v6.12.6-0-ge9d65b48ce1a
> [2025-02-24 13:31:50] [   11.421222] Backport generated by backports.git v6.1.110-1-35-g410656ef04d2
> [2025-02-24 13:31:50] [   11.431677] sfp sfp-1: Host maximum power 3.0W
> [2025-02-24 13:31:50] [   11.436811] sfp sfp-2: Host maximum power 3.0W
> [2025-02-24 13:31:50] [   11.508005] urngd: v1.0.2 started.
> [2025-02-24 13:31:51] [   11.771522] sfp sfp-1: module OEM              SFP-2.5G-T-R-RM  rev 1.0  sn xxxxxxxxxx       dc xxxxxx
> [2025-02-24 13:31:51] [   11.822433] sfp sfp-2: module OEM              SFP-2.5G-T-R-RM  rev 1.0  sn xxxxxxxxxx       dc xxxxxx
> [2025-02-24 13:31:51] [   11.832805] hwmon hwmon2: temp1_input not attached to any thermal zone
> [2025-02-24 13:31:51] [   11.852194] mt798x-wmac 18000000.wifi: HW/SW Version: 0x8a108a10, Build Time: 20240823160739a
> [2025-02-24 13:31:51] [   11.869924] mt798x-wmac 18000000.wifi: WM Firmware Version: ____000000, Build Time: 20240823160804
> [2025-02-24 13:31:51] [   11.870787] hwmon hwmon3: temp1_input not attached to any thermal zone
> [2025-02-24 13:31:51] [   11.909065] mt798x-wmac 18000000.wifi: WA Firmware Version: DEV_000000, Build Time: 20240823160840
> [2025-02-24 13:32:11] [   32.471972] mt798x-wmac 18000000.wifi: Retry message 00000002 (seq 11)
> [2025-02-24 13:32:32] [   52.951965] mt798x-wmac 18000000.wifi: Message 00000002 (seq 11) timeout
> [2025-02-24 13:32:32] [   52.958654] mt798x-wmac 18000000.wifi: Failed to start WA firmware
> [2025-02-24 13:32:32] [   52.958672] Unable to handle kernel write to read-only memory at virtual address 0000000000000008
> [2025-02-24 13:32:32] [   52.973665] Mem abort info:
> [2025-02-24 13:32:32] [   52.976445]   ESR = 0x0000000096000045
> [2025-02-24 13:32:32] [   52.980176]   EC = 0x25: DABT (current EL), IL = 32 bits
> [2025-02-24 13:32:32] [   52.985472]   SET = 0, FnV = 0
> [2025-02-24 13:32:32] [   52.988510]   EA = 0, S1PTW = 0
> [2025-02-24 13:32:32] [   52.991634]   FSC = 0x05: level 1 translation fault
> [2025-02-24 13:32:32] [   52.996496] Data abort info:
> [2025-02-24 13:32:32] [   52.999360]   ISV = 0, ISS = 0x00000045, ISS2 = 0x00000000
> [2025-02-24 13:32:32] [   53.004829]   CM = 0, WnR = 1, TnD = 0, TagAccess = 0
> [2025-02-24 13:32:32] [   53.009861]   GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
> [2025-02-24 13:32:32] [   53.015157] user pgtable: 4k pages, 39-bit VAs, pgdp=00000000478a7000
> [2025-02-24 13:32:32] [   53.021576] [0000000000000008] pgd=0000000000000000, p4d=0000000000000000, pud=0000000000000000
> [2025-02-24 13:32:32] [   53.030257] Internal error: Oops: 0000000096000045 [#1] SMP
> [2025-02-24 13:32:32] [   53.035810] Modules linked in: mt7915e(O+) mt76_connac_lib(O) mt76(O) mac80211(O) cfg80211(O) slhc sfp nfnetlink nf_reject_ipv6 nf_reject_ipv4 nf_log_syslog nf_defrag_ipv6 nf_defrag_ipv4 mdio_i2c libcrc32c compat(O) crypto_safexcel pwm_fan i2c_gpio i2c_algo_bit sha512_arm64 sha1_ce sha1_generic seqiv md5 geniv des_generic libdes authencesn authenc leds_gpio xhci_plat_hcd xhci_pci xhci_mtk_hcd xhci_hcd gpio_button_hotplug(O) usbcore usb_common aquantia
> [2025-02-24 13:32:32] [   53.075753] CPU: 3 PID: 44 Comm: kworker/u8:3 Tainted: G           O       6.6.73 #0
> [2025-02-24 13:32:32] [   53.083474] Hardware name: Bananapi BPI-R3 (DT)
> [2025-02-24 13:32:32] [   53.087986] Workqueue: mt76 0xffffffc078ee2d60 [mt7915e@0000000092e9bdf4+0x1a000]
> [2025-02-24 13:32:32] [   53.095451] pstate: a0400005 (NzCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
> [2025-02-24 13:32:32] [   53.102391] pc : 0xffffffc078eb5c30 [mt76@00000000e89e6d79+0xd000]
> [2025-02-24 13:32:32] [   53.108552] lr : 0xffffffc078eb61f8 [mt76@00000000e89e6d79+0xd000]
> [2025-02-24 13:32:32] [   53.114712] sp : ffffffc080f8bc00
> [2025-02-24 13:32:32] [   53.118010] x29: ffffffc080f8bc00 x28: ffffffc080f8bc70 x27: ffffff8008d39fe0
> [2025-02-24 13:32:32] [   53.125125] x26: ffffffffffff5af8 x25: ffffff8008d31ff8 x24: ffffff8008d35678
> [2025-02-24 13:32:32] [   53.132242] x23: ffffff8008d32790 x22: ffffff8008d31fe0 x21: ffffff8008d32008
> [2025-02-24 13:32:32] [   53.139357] x20: ffffff8008d31fe0 x19: ffffff8008d31fe0 x18: 0000000000000000
> [2025-02-24 13:32:32] [   53.146472] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
> [2025-02-24 13:32:32] [   53.153587] x14: 0000000000000000 x13: 0000000000000020 x12: 0101010101010101
> [2025-02-24 13:32:32] [   53.160702] x11: 7f7f7f7f7f7f7f7f x10: fefefefefefefeff x9 : 7f7f7f7f7f7f7f7f
> [2025-02-24 13:32:32] [   53.167818] x8 : 8080808080808080 x7 : ffffff80009865c0 x6 : ffffffffffff2460
> [2025-02-24 13:32:32] [   53.174933] x5 : ffffffc080f8bc68 x4 : 0000000000000000 x3 : ffffff8008d32010
> [2025-02-24 13:32:32] [   53.182049] x2 : 0000000000000000 x1 : 0000000000000000 x0 : 0000000000000000
> [2025-02-24 13:32:32] [   53.189165] Call trace:
> [2025-02-24 13:32:32] [   53.191596]  0xffffffc078eb5c30 [mt76@00000000e89e6d79+0xd000]
> [2025-02-24 13:32:32] [   53.197411]  0xffffffc078eb61f8 [mt76@00000000e89e6d79+0xd000]
> [2025-02-24 13:32:32] [   53.203225]  0xffffffc078ee397c [mt7915e@0000000092e9bdf4+0x1a000]
> [2025-02-24 13:32:32] [   53.209385]  0xffffffc0800570d8
> [2025-02-24 13:32:32] [   53.212510]  0xffffffc080057534
> [2025-02-24 13:32:32] [   53.215636]  0xffffffc08005ebe4
> [2025-02-24 13:32:32] [   53.218760]  0xffffffc080013024
> [2025-02-24 13:32:32] [   53.221888] Code: f94037e3 eb00007f 54000120 a94306c2 (f900045c)
> [2025-02-24 13:32:32] [   53.227961] ---[ end trace 0000000000000000 ]---
> [2025-02-24 13:32:32] [   53.235419] pstore: backend (ramoops) writing error (-28)
> [2025-02-24 13:32:32] [   53.240800] Kernel panic - not syncing: Oops: Fatal exception in interrupt
> [2025-02-24 13:32:32] [   53.247653] SMP: stopping secondary CPUs
> [2025-02-24 13:32:32] [   53.251560] Kernel Offset: disabled
> [2025-02-24 13:32:32] [   53.255031] CPU features: 0x0,00000000,00000000,1000400b
> [2025-02-24 13:32:32] [   53.260325] Memory Limit: none
> [2025-02-24 13:32:32] [   53.266114] Rebooting in 1 seconds..
Which UART are you using?
I’m using the one with three gold pins close to the BootStrap configuration switch.
I should make my question more clear:
Which UART to USB converter are you using?
Oh, I’m using PL2303 UART2USB converter.
Your R3 will boot fine, if you disconnect the usb to uart converter from the board.
Use a FT232RL (switched to 3.3V !!!) converter to boot with converter connected.
Hm… that’s interesting. Does the PL2303 controller make such an issues? I don’t have any converter based on FT232RL so I used another one for which “ch341” Linux driver is needed and now it seems that Linux on BPI R3 is working fine.
Thanks for your help @ericwoud!
Hi. Please, did you manage to install OpenWrt with a new UART to USB converter? i’m trying to install OpenWrt 24 on a BPI-R3 and is booting constantly using a CH340 converter. I don’t have this issue with OpenWrt 23. Thanks.
