wwwing
(wwwing)
Liujie shared a case to me, it was about 5G module not recongnized.
When you use fm350-gl / fm150 or other 5G module via USB mode.
If you turn off pcie2 in dts, then turn on pcie2 using pcie mode, your 5G module will cannot be recongnized.
If someone meet the same problem, hope can help you.
HELLO
Now the module fm350-gl working with Bbi-r4 normally?
wwwing
(wwwing)
3
You can use it via USB mode
zuowei8
(zuowei8)
4
if you want to use PCIe mode, Maybe you need firstly setup the FM350-GL’s mode to PCIe mode.
Hello
How can I setup the FM350-GL’s mode to PCIe mode?
