Hi BPI Team and community,
Following our releases for the OpenWrt One and the Banana Pi BPI-R3, I’m excited to share that we have now compiled and optimized a Next-Gen Firewall (NGFW) build (v26.2.1) natively for the Banana Pi BPI-R4 (MediaTek MT7988A / Filogic 880, Quad-Core aarch64_cortex-a73), running on Linux Kernel 6.12.94 (OpenWrt v25.12.5) with full hardware support for 10GbE SFP+ cages, 2.5GbE/1GbE switch ports, PWM fan control, hardware crypto (safexcel), PCIe/M.2 NVMe slots, and optional Wi-Fi 7 (mt7996e) modules.
Hardware, RAM & High-Throughput Optimization
- Unconstrained Performance on 4 GiB / 8 GiB RAM: Leveraging the BPI-R4’s 4 GiB / 8 GiB DDR4 RAM and faster Cortex-A73 cores to run every security and inspection engine simultaneously with massive headroom for multi-gigabit routing and VPN throughput.
- Flexible Boot & Multi-Flash: Full support for SD Card, eMMC, and SPI-NAND architectures using standard OpenWrt boot-switch workflows.
- Heavy I/O Offloading: Uses external storage (M.2 NVMe / eMMC / USB3) at
/mnt/datafor logs, feeds, caching, and analytics to protect onboard flash.
Features Included & Design Philosophy
- Setup & Profiles: Features a Zero-Complexity Startup Wizard and environment security profiles (School, Work, Home) with pre-tuned application and content rules.
- Active Security & Visibility: Includes deep traffic analytics, Netify Application Control, Squid Proxy with SSL Inspection, ClamAV / YARA Antivirus, Cloud Sandbox, Snort 3 IPS, DNS filtering, and automated IP/country blocking.
- Enterprise Connectivity: Built-in WireGuard, OpenVPN, IPsec, and a simplified policy engine (NAT, QoS, SD-WAN).
- Wireless Ready: When the optional Wi-Fi 7 module is installed, wireless interfaces are auto-configured, bridged to LAN, and manageable via a dedicated local settings page at
https://192.168.1.1/wifi(plus CLI commands in the attached KBA).
First-Boot & Accessing the Box
- Web UI & Wizard: Access
https://192.168.1.1viaeth1(LAN/Wi-Fi bridge with DHCP) to run the wizard, select your security profile, and disable WAN management access if desired. - Default Credentials: Web UI (
admin/nexwall) and CLI/SSH (root/nexwall). (Note: SSH and Web Admin are active on botheth1LAN andeth2WAN by default in this build, and can be disabled directly inside the wizard). - Default Wi-Fi (When Radio Installed): SSID
Internet_segura(case-sensitive), WPA2 passwordinternetinternet(please change upon first boot).
Available Release Assets
(Note: Do not flash BPI-R4 images on BPI-R3, BPI-R4 PoE 2.5GE, or BPI-R4 Lite).
nexwall-26.2.1-mediatek-filogic-bananapi_bpi-r4-sdcard.img.gz(SD card image)nexwall-26.2.1-mediatek-filogic-bananapi_bpi-r4-squashfs-sysupgrade.itb(Sysupgrade / eMMC & NAND)sha256sums(Preloader, BL31 U-Boot FIP, and*-emmc-gpt.binpartition table included foremmcandsnand)
GitHub Release v26.2.1-bpi-r4: Release Next-Gen Firewall Build v26.2.1 for Banana Pi BPI-R4 · nexwall/nexwall-bananapi-fw · GitHub
Administrative Docs: https://docs.nexwall.com.br
Release Notes: https://releasenotes.nexwall.com.br
Feedback on 10GbE SFP+ throughput, Wi-Fi 7 stability, and thermals is welcome! KBA-WIFI-CLI.en.md (8,2,KB)
