[Software Release] Next-Gen Firewall Build v26.2.1 for Banana Pi BPI-R3 (MT7986 / Kernel 6.12)
Hi BPI Team and community,
Following our release for the OpenWrt One, I’m excited to share that we have now compiled and optimized a Next-Gen Firewall (NGFW) build (v26.2.1) natively for the Banana Pi BPI-R3 (MediaTek MT7986 / Filogic 830, aarch64_cortex-a53), running on Linux Kernel 6.12.94 (OpenWrt v25.12.5) with full hardware support for SFP cages, Wi-Fi 6 (mt7915e), PWM fan control, hardware crypto (safexcel), and storage.
:floppy_disk: Hardware, RAM & Storage Optimization
  • Full Module Suite on 2 GiB RAM: Leveraging the BPI-R3’s 2 GiB RAM to run all security and inspection modules simultaneously, peaking at ~1.6–1.8 GiB under heavy load.
  • Flexible Boot & Multi-Flash: Full support for SD Card, eMMC, SPI-NAND, and SPI-NOR architectures using standard OpenWrt boot-switch workflows.
  • Heavy I/O Offloading: Uses external storage (M.2 NVMe / USB3 / eMMC) at /mnt/data for logs, feeds, caching, and analytics.
:shield: Features Included & Design Philosophy
  • Setup & Profiles: Features a Zero-Complexity Startup Wizard and environment security profiles (School, Work, Home) with pre-tuned application and content rules.
  • Active Security & Visibility: Includes deep traffic analytics, Netify Application Control, Squid Proxy with SSL Inspection, ClamAV/YARA Antivirus, Cloud Sandbox, Snort 3 IPS, DNS filtering, and automated IP/country blocking.
  • Enterprise Connectivity: Built-in WireGuard, OpenVPN, IPsec, and a simplified policy engine (NAT, QoS, SD-WAN).
  • Wireless: Enabled out of the box, bridged to LAN, with a dedicated local settings page at https://192.168.1.1/wifi (plus CLI commands in the attached KBA).
:key: First-Boot & Accessing the Box
  • Web UI & Wizard: Access https://192.168.1.1 via eth1 (LAN/Wi-Fi bridge with DHCP) to run the wizard and select your security profile.
  • Default Credentials: Web UI and CLI/SSH (root / admin) use username admin / nexwall (note that SSH/Web Admin are active on both eth1 LAN and eth2 WAN by default in this build).
  • Default Wi-Fi: SSID Internet_segura, WPA2 password internetinternet (please change upon first boot).
:package: Available Release Assets
(Note: Do not flash BPI-R3 images on BPI-R4; a dedicated BPI-R4 release is available separately).
  • nexwall-26.2.1-mediatek-filogic-bananapi_bpi-r3-sdcard.img.gz (SD card image)
  • nexwall-26.2.1-mediatek-filogic-bananapi_bpi-r3-squashfs-sysupgrade.itb (Sysupgrade / eMMC & NAND)
  • sha256sums (Preloader & bl31-uboot FIP files included)
:point_right: GitHub Release v26.2.1-bpi-r3: Release Next-Gen Firewall Build v26.2.1 for Banana Pi BPI-R3 · nexwall/nexwall-bananapi-fw · GitHub
:point_right: Administrative Docs: https://docs.nexwall.com.br
:point_right: Release Notes: https://releasenotes.nexwall.com.br
Feedback on SFP throughput, Wi-Fi 6 stability, and thermals is welcome!
KBA-WIFI-CLI.en.md (8,2,KB)
This looks well-done.
