[Software Release] Next-Gen Firewall Build v26.1.1 for OpenWrt One (MT7981B)
Hi BPI Team and community,
I’m happy to share that we have optimized and compiled a Next-Gen Firewall (NGFW) build (v26.1.1) natively for the OpenWrt One board (MediaTek MT7981B / Filogic 830), respecting the hardware layout guidelines from the Banana Pi and OpenWrt teams.
:floppy_disk: Hardware, RAM & Partition Integrity
  • Safe Recovery Layout: Preserves the stock 16 MiB SPI NOR flash recovery partition (full backups recommended before deployment).
  • NVMe Storage Integration: Offloads heavier tasks (threat logs, proxy cache, charts, category lists) to the M.2 NVMe slot to protect onboard flash wear.
  • 1 GiB SoC Optimization: Tailored for the MT7981B and 1 GiB RAM, keeping active usage around 500–800 MB with Web Proxy (SSL inspection), Netify, and Snort running (ClamAV excluded for stability).
:shield: Features Included & Design Philosophy
Transforms the board into a visual NGFW focusing on simplicity and core principles:
  • Zero-Complexity Startup Wizard & Security Profiles: Pre-tuned Home, School, and Work profiles that auto-apply Application Control and content filtering.
  • Active Security & Visibility: Web Proxy with SSL inspection, Netify DPI, Snort IPS, DNS and Geo-IP filtering, real-time charts, and connection tracking.
  • Enterprise VPNs & Networking: WireGuard, OpenVPN, IPsec, SD-WAN, QoS, and zone policies.
:key: First-Boot & Accessing the Box
  • LAN & Web Wizard: Access https://192.168.1.1 (eth1 bridged with Wi-Fi, DHCP enabled) to run the wizard and update passwords.
  • Default Credentials: Web UI (admin / nexwall) and CLI/SSH (root / nexwall).
  • Default Wi-Fi: SSID Internet_segura / WPA2 internetinternet (please change on first boot).
The image assets (snand-factory.bin, nor-factory.bin, and sysupgrade.itb) and documentation are available via GitHub:
:point_right: Get the Files (GitHub Release): Release Next-Gen Firewall Build v26.1.1 for OpenWrt One · nexwall/nexwall-openwrt-one-fw · GitHub
:point_right: Administrative Docs: https://docs.nexwall.com.br
:point_right: Release Notes: https://releasenotes.nexwall.com.br
Testbench feedback regarding benchmarks, thermals, and operational stability is greatly appreciated.
very good,thank your share it. we have set your ID as a member, you can free post on this forum.
Thank you! we will be improving the firmware and the build with new features and reporting here!
After all testing performed if you consider to refer to the Openwrt One as a router or a firewall for home or enterprise users in the web page we greatly appretiate! https://www.aliexpress.com/store/1101951077
