Slow the cellphone log spam
Are you seeing lots of hostapd log-spam from cell phones which go to sleep, then wake up, connect again, transfer a bit of data, then go back to sleep, rinse and repeat?
You can attempt to set the hostapd / wireless / wpad logging in /etc/config/wireless, but it won’t work. hostapd / wpad bypasses all log_level settings and continues printing its output to the logs.
None of these in /etc/config/wireless work:
config wifi-device 'radio0'
    option log_mlme '0'
    option log_iapp '0'
    option log_driver '0'
    option log_wpa '0'
    option log_radius '0'
    option log_8021x '0'
    option log_80211 '0'
    option log_level '3'
So we’ll disable hostapd / wpad logging. I recommend only doing this once you know everything is working properly.
Issue:
vi /etc/init.d/wpad
Press i to enter editing mode.
Make the following changes:
THIS LINE:	procd_set_param command /usr/sbin/hostapd -s -g /var/run/hostapd/global
CHANGED TO:	procd_set_param command /usr/sbin/hostapd -g /var/run/hostapd/global
THIS LINE:	procd_set_param command /usr/sbin/wpa_supplicant -n -s -g /var/run/wpa_supplicant/global
CHANGED TO:	procd_set_param command /usr/sbin/wpa_supplicant -n -g /var/run/wpa_supplicant/global
IOW, we’re stripping out the ‘-s’ flag, which tells hostapd and wpa_supplicant to log.
Press Esc to exit editing mode, then :wq to save and exit.
Issue:
/etc/init.d/wpad restart
Now your logs will be quieter.
To make it survive firmware updates, put:
/etc/init.d/wpad
in the list at System >> Backup / Flash firmware >> Configuration tab, then click the Save button.
