BPI R2 has 2 sata power, sata power 1 has two pins meanwhile sata power 2 has four. Does it mean wich only * sata power 2* I can power two sata disks ? would it be enough to power up two 2.5" sata disks ?
where can I buy cables with sata and wire to board system ?
The 2-pin-power-cable can be buyed in stores like ebay or ali express. i did not found a 4-pin one…these have to be done manually. The 4pin have a 12v-powering,but i’m not sure it’s powerful enough to power a 3.5" hdd
