RM520N-GLAP doesn't show on either slot on BPI-R64
Recently picked up an R64 with the intent of trying to use it with a couple of 5G cards I have on hand. Both are M.2 based but I do have an M.2>mPCIe adapter that passes through both PCI and USB as well as having its own SIM slots ready to go.
Right now I’m running the OpenWRT snapshots on this board and it is configured for CN8 to be PCI instead of SATA.
The two 5G cards I have are a Fibocom FM350-GL and the other is a Quectel RM520N-GLAP. Important note on the Quectel is the AP version is PCI only. No USB.
So far I’ve been able to get the FM350 working on this board in both slots in PCI mode. On the other end I have been able to have the RM520 show up in other devices in PCI mode using this adapter. However in the R64 it does not. Nothing in lspci and glancing over the kernel logs there’s no mention of the card.
Curious if anyone has any input on this? Any other tests or checks I can do?
Thanks!
Afair there were some incompatibilities (especially with atheros cards),maybe you hit some of this or the power of slot is not enough…
Any hints in bootlog (dmesg)?
Here’s my entire dmesg log:
root@OpenWrt:~# dmesg
[    0.000000] Linux version 6.6.44 (builder@buildhost) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 13.3.0 r27100-21a5b3b540) 13.3.0, GNU ld (GNU Binutils) 2.42) #0 SMP Wed Aug  7 18:40:11 2024
[    0.000000] Machine model: Bananapi BPI-R64
[    0.000000] OF: reserved mem: 0x0000000042ff0000..0x0000000042ffffff (64 KiB) map non-reusable ramoops@42ff0000
[    0.000000] OF: reserved mem: 0x0000000043000000..0x000000004302ffff (192 KiB) nomap non-reusable secmon@43000000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000]   node   0: [mem 0x0000000040000000-0x0000000042ffffff]
[    0.000000]   node   0: [mem 0x0000000043000000-0x000000004302ffff]
[    0.000000]   node   0: [mem 0x0000000043030000-0x000000007fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 18 pages/cpu s35112 r8192 d30424 u73728
[    0.000000] pcpu-alloc: s35112 r8192 d30424 u73728 alloc=18*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] CPU features: detected: ARM erratum 843419
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: ubi.block=0,fit root=/dev/fit0 rootwait
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 258048
[    0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 1MB
[    0.000000] software IO TLB: area num 2.
[    0.000000] software IO TLB: mapped [mem 0x000000007eb00000-0x000000007ec00000] (1MB)
[    0.000000] Memory: 1013684K/1048576K available (8896K kernel code, 912K rwdata, 2572K rodata, 384K init, 309K bss, 34892K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 12.50MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049cda, max_idle_ns: 440795202628 ns
[    0.000000] sched_clock: 56 bits at 13MHz, resolution 80ns, wraps every 4398046511080ns
[    0.000254] Calibrating delay loop (skipped), value calculated using timer frequency.. 25.00 BogoMIPS (lpj=125000)
[    0.000264] pid_max: default: 32768 minimum: 301
[    0.003076] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.003088] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.005800] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[    0.005960] rcu: Hierarchical SRCU implementation.
[    0.005963] rcu:     Max phase no-delay instances is 1000.
[    0.006516] smp: Bringing up secondary CPUs ...
[    0.006904] Detected VIPT I-cache on CPU1
[    0.006916] CPU features: SANITY CHECK: Unexpected variation in SYS_CNTFRQ_EL0. Boot CPU: 0x00000000bebc20, CPU1: 0x00000000000000
[    0.006938] CPU features: Unsupported CPU feature variation detected.
[    0.007002] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.007080] smp: Brought up 1 node, 2 CPUs
[    0.007086] SMP: Total of 2 processors activated.
[    0.007089] CPU features: detected: 32-bit EL0 Support
[    0.007092] CPU features: detected: CRC32 instructions
[    0.007125] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[    0.007129] CPU: All CPU(s) started at EL2
[    0.007131] alternatives: applying system-wide alternatives
[    0.011852] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.011872] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.013092] pinctrl core: initialized pinctrl subsystem
[    0.014218] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.014826] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[    0.014857] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.014880] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.015329] thermal_sys: Registered thermal governor 'fair_share'
[    0.015334] thermal_sys: Registered thermal governor 'bang_bang'
[    0.015336] thermal_sys: Registered thermal governor 'step_wise'
[    0.015339] thermal_sys: Registered thermal governor 'user_space'
[    0.015414] ASID allocator initialised with 65536 entries
[    0.016120] pstore: Using crash dump compression: deflate
[    0.016124] pstore: Registered ramoops as persistent store backend
[    0.016127] ramoops: using 0x10000@0x42ff0000, ecc: 0
[    0.027333] Modules: 29456 pages in range for non-PLT usage
[    0.027343] Modules: 520976 pages in range for PLT usage
[    0.028228] cryptd: max_cpu_qlen set to 1000
[    0.029394] SCSI subsystem initialized
[    0.029613] libata version 3.00 loaded.
[    0.031268] clocksource: Switched to clocksource arch_sys_counter
[    0.033446] NET: Registered PF_INET protocol family
[    0.033588] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.035324] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[    0.035343] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.035354] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.035405] TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.035619] TCP: Hash tables configured (established 8192 bind 8192)
[    0.035744] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.035772] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.036078] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.036119] PCI: CLS 0 bytes, default 64
[    0.037601] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[    0.042307] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.042316] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.074426] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.088179] mt-pmic-pwrap 10001000.pwrap: unexpected interrupt int=0x1
[    0.101963] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    0.111963] printk: console [ttyS0] disabled
[    0.132437] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 118, base_baud = 1562500) is a ST16650V2
[    0.132488] printk: console [ttyS0] enabled
[    0.804491] mtk_rng 1020f000.rng: registered RNG driver
[    0.810221] random: crng init done
[    0.817209] loop: module loaded
[    0.821180] mtk-ecc 1100e000.ecc: probed
[    0.827923] spi-nand spi1.0: Winbond SPI NAND was found.
[    0.833302] spi-nand spi1.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[    0.841465] mtk-snand 1100d000.spi: ECC strength: 4 bits per 512 bytes
[    0.848333] 2 fixed-partitions partitions found on MTD device spi1.0
[    0.854767] OF: Bad cell count for /spi@1100d000/flash@0/partitions
[    0.861044] OF: Bad cell count for /spi@1100d000/flash@0/partitions
[    0.867661] Creating 2 MTD partitions on "spi1.0":
[    0.872489] 0x000000000000-0x000000080000 : "bl2"
[    0.878221] 0x000000080000-0x000008000000 : "ubi"
[    1.015113] ubi0: default fastmap pool size: 50
[    1.019652] ubi0: default fastmap WL pool size: 25
[    1.024460] ubi0: attaching mtd1
[    1.304917] ubi0: scanning is finished
[    1.313409] ubi0: attached mtd1 (name "ubi", size 127 MiB)
[    1.318913] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[    1.325799] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[    1.332587] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[    1.339540] ubi0: good PEBs: 1018, bad PEBs: 2, corrupted PEBs: 0
[    1.345628] ubi0: user volume: 6, internal volumes: 1, max. volumes count: 128
[    1.352845] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[    1.361188] ubi0: available PEBs: 0, total reserved PEBs: 1018, PEBs reserved for bad PEB handling: 18
[    1.370502] ubi0: background thread "ubi_bgt0d" started, PID 277
[    1.370653] OF: Bad cell count for /spi@1100d000/flash@0/partitions
[    1.382976] OF: Bad cell count for /spi@1100d000/flash@0/partitions
[    1.389876] block ubiblock0_4: created from ubi0:4(fit)
[    1.522599] mtk_soc_eth 1b100000.ethernet: generated random MAC address 65:74:68:25:64:00
[    1.533338] mtk_soc_eth 1b100000.ethernet eth0: mediatek frame engine at 0xffffffc0815a0000, irq 124
[    1.543319] mtk_soc_eth 1b100000.ethernet eth1: mediatek frame engine at 0xffffffc0815a0000, irq 124
[    1.553232] i2c_dev: i2c /dev entries driver
[    1.560632] mtk-wdt 10212000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[    1.571100] NET: Registered PF_INET6 protocol family
[    1.572960] mtk-msdc 11240000.mmc: Got CD GPIO
[    1.577606] Segment Routing with IPv6
[    1.584268] In-situ OAM (IOAM) with IPv6
[    1.588259] NET: Registered PF_PACKET protocol family
[    1.593387] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.608042] 8021q: 802.1Q VLAN Support v1.8
[    1.636276] mtk-pcie 1a143000.pcie: host bridge /pcie@1a143000 ranges:
[    1.642898] mtk-pcie 1a143000.pcie: Parsing ranges property...
[    1.648758] mtk-pcie 1a143000.pcie:      MEM 0x0020000000..0x0027ffffff -> 0x0020000000
[    1.713217] mmc0: new HS200 MMC card at address 0001
[    1.719988] mmcblk0: mmc0:0001 008G30 7.28 GiB
[    1.727412] mmcblk0boot0: mmc0:0001 008G30 4.00 MiB
[    1.734161] mmcblk0boot1: mmc0:0001 008G30 4.00 MiB
[    1.739696] mmcblk0rpmb: mmc0:0001 008G30 4.00 MiB, chardev (249:0)
[    1.766404] mmc1: host does not support reading read-only switch, assuming write-enable
[    1.776339] mmc1: new high speed SDHC card at address 5048
[    1.783262] mmcblk1: mmc1:5048 SD32G 28.9 GiB
[    1.790786] Alternate GPT is invalid, using primary GPT.
[    1.796173]  mmcblk1: p1 p2 p3 p4 p5 p6 p128
[    1.991324] mtk-pcie 1a143000.pcie: Port0 link down
[    1.996650] mtk-pcie 1a143000.pcie: PCI host bridge to bus 0000:00
[    2.002868] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.008356] pci_bus 0000:00: root bus resource [mem 0x20000000-0x27ffffff]
[    2.015234] pci_bus 0000:00: scanning bus
[    2.020969] pci_bus 0000:00: fixups for bus
[    2.025159] pci_bus 0000:00: bus scan returning with max=00
[    2.031458] mtk-pcie 1a145000.pcie: host bridge /pcie@1a145000 ranges:
[    2.038013] mtk-pcie 1a145000.pcie: Parsing ranges property...
[    2.043853] mtk-pcie 1a145000.pcie:      MEM 0x0028000000..0x002fffffff -> 0x0028000000
[    2.391317] mtk-pcie 1a145000.pcie: Port1 link down
[    2.396416] mtk-pcie 1a145000.pcie: PCI host bridge to bus 0001:00
[    2.402627] pci_bus 0001:00: root bus resource [bus 00-ff]
[    2.408116] pci_bus 0001:00: root bus resource [mem 0x28000000-0x2fffffff]
[    2.414995] pci_bus 0001:00: scanning bus
[    2.420736] pci_bus 0001:00: fixups for bus
[    2.424926] pci_bus 0001:00: bus scan returning with max=00
[    2.431231] mtk_hsdma 1b007000.dma-controller: MediaTek HSDMA driver registered
[    2.439430] FIT: Detected U-Boot 2024.07-OpenWrt-r27100-21a5b3b540
[    2.445635] FIT: Selected configuration: "config-1" (OpenWrt bananapi_bpi-r64)
[    2.452867] FIT:           kernel sub-image 0x00001000..0x0059e5c2 "kernel-1" (ARM64 OpenWrt Linux-6.6.44)
[    2.462626] FIT:          flat_dt sub-image 0x0059f000..0x005a86db "fdt-1" (ARM64 OpenWrt bananapi_bpi-r64 device tree blob)
[    2.473942] FIT:          flat_dt sub-image 0x005a9000..0x005a911a "fdt-mt7622-bananapi-bpi-r64-pcie1" (ARM64 OpenWrt bananapi_bpi-r64 device tree overlay mt7622-bananapi-bpi-r64-pcie1)
[    2.490553] FIT:          flat_dt sub-image 0x005aa000..0x005aa20f "fdt-mt7622-bananapi-bpi-r64-sata" (ARM64 OpenWrt bananapi_bpi-r64 device tree overlay mt7622-bananapi-bpi-r64-sata)
[    2.506985] FIT:       filesystem sub-image 0x005ab000..0x00bd4fff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r64 rootfs)
[    2.518167] block ubiblock0_4: mapped 1 uImage.FIT filesystem sub-image as /dev/fit0
[    2.585355] mt7530-mdio mdio-bus:1f: configuring for fixed/2500base-x link mode
[    2.594532] mt7530-mdio mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
[    2.603491] mt7530-mdio mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=134)
[    2.624059] mt7530-mdio mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=135)
[    2.644630] mt7530-mdio mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=136)
[    2.665085] mt7530-mdio mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=137)
[    2.685541] mt7530-mdio mdio-bus:1f lan4 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=138)
[    2.697019] mtk_soc_eth 1b100000.ethernet eth0: entered promiscuous mode
[    2.703809] DSA: tree 0 setup
[    2.707254] clk: Disabling unused clocks
[    2.714522] VFS: Mounted root (squashfs filesystem) readonly on device 259:1.
[    2.721853] Freeing unused kernel memory: 384K
[    2.726353] Run /sbin/init as init process
[    2.730440]   with arguments:
[    2.733406]     /sbin/init
[    2.736104]   with environment:
[    2.739234]     HOME=/
[    2.741599]     TERM=linux
[    2.901480] init: Console is alive
[    2.905029] init: - watchdog -
[    3.416169] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    3.446010] usbcore: registered new interface driver usbfs
[    3.451596] usbcore: registered new interface driver hub
[    3.456976] usbcore: registered new device driver usb
[    3.462839] gpio_button_hotplug: loading out-of-tree module taints kernel.
[    3.479180] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[    3.484528] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 1
[    3.493646] xhci-mtk 1a0c0000.usb: hcc params 0x01403198 hci version 0x96 quirks 0x0000000000200010
[    3.502838] xhci-mtk 1a0c0000.usb: irq 139, io mem 0x1a0c0000
[    3.508707] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[    3.513949] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 2
[    3.521363] xhci-mtk 1a0c0000.usb: Host supports USB 3.0 SuperSpeed
[    3.528221] hub 1-0:1.0: USB hub found
[    3.532049] hub 1-0:1.0: 2 ports detected
[    3.536497] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.545071] hub 2-0:1.0: USB hub found
[    3.548871] hub 2-0:1.0: 1 port detected
[    3.558255] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    3.573872] init: - preinit -
[    3.874380] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[    3.882898] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[    3.890889] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
[    5.265836] mt7530-mdio mdio-bus:1f lan1: Link is Up - 1Gbps/Full - flow control rx/tx
[    6.053701] UBIFS (ubi0:5): Mounting in unauthenticated mode
[    6.059482] UBIFS (ubi0:5): background thread "ubifs_bgt0_5" started, PID 816
[    6.083727] UBIFS (ubi0:5): recovery needed
[    6.157192] UBIFS (ubi0:5): recovery completed
[    6.161745] UBIFS (ubi0:5): UBIFS: mounted UBI device 0, volume 5, name "rootfs_data"
[    6.169576] UBIFS (ubi0:5): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[    6.179509] UBIFS (ubi0:5): FS size: 100945920 bytes (96 MiB, 795 LEBs), max 806 LEBs, journal size 5079040 bytes (4 MiB, 40 LEBs)
[    6.191264] UBIFS (ubi0:5): reserved for root: 4767925 bytes (4656 KiB)
[    6.197876] UBIFS (ubi0:5): media format: w5/r0 (latest is w5/r0), UUID AFD3124B-46E3-4F5E-8680-ABA271D45030, small LPT model
[    6.211344] mount_root: switching to ubifs overlay
[    6.219189] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[    6.233321] urandom-seed: Seeding with /etc/urandom.seed
[    6.294774] mt7530-mdio mdio-bus:1f lan1: Link is Down
[    6.306387] procd: - early -
[    6.309359] procd: - watchdog -
[    6.877621] procd: - watchdog -
[    6.881974] procd: - ubus -
[    7.039003] procd: - init -
[    7.379627] kmodloader: loading kernel modules from /etc/modules.d/*
[    7.415238] hid: raw HID events driver (C) Jiri Kosina
[    7.433423] Bluetooth: Core ver 2.22
[    7.437103] NET: Registered PF_BLUETOOTH protocol family
[    7.442452] Bluetooth: HCI device and connection manager initialized
[    7.448807] Bluetooth: HCI socket layer initialized
[    7.453707] Bluetooth: L2CAP socket layer initialized
[    7.458763] Bluetooth: SCO socket layer initialized
[    7.465443] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    7.470767] Bluetooth: BNEP filters: protocol multicast
[    7.476029] Bluetooth: BNEP socket layer initialized
[    7.487711] usbcore: registered new interface driver btusb
[    7.494107] Loading modules backported from Linux version v6.9.9-0-g28fdf4518483
[    7.501570] Backport generated by backports.git v6.1.97-1-29-gf1d24a3683b2
[    7.509665] Bluetooth: HCI UART driver ver 2.3
[    7.514175] Bluetooth: HCI UART protocol H4 registered
[    7.519307] Bluetooth: HCI UART protocol BCSP registered
[    7.524632] Bluetooth: HCI UART protocol ATH3K registered
[    7.531633] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    7.537578] Bluetooth: HIDP socket layer initialized
[    7.552384] Bluetooth: RFCOMM TTY layer initialized
[    7.557293] Bluetooth: RFCOMM socket layer initialized
[    7.562485] Bluetooth: RFCOMM ver 1.11
[    7.597930] urngd: v1.0.2 started.
[    7.642582] mt7622-wmac 18000000.wmac: Invalid MAC address, using random address 86:ce:1f:7d:31:df
[    7.681701] mt7622-wmac 18000000.wmac: registering led 'mt76-phy0'
[    7.688437] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[    7.747932] mt7622-wmac 18000000.wmac: HW/SW Version: 0x8a108a10, Build Time: 20190801210006a
[    7.747932]
[    7.806071] PPP generic driver version 2.4.2
[    7.832545] NET: Registered PF_PPPOX protocol family
[    7.851646] kmodloader: done loading kernel modules from /etc/modules.d/*
[    7.899428] mt7622-wmac 18000000.wmac: N9 Firmware Version: _reserved_, Build Time: 20220630094834
[   11.228441] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[   11.244584] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[   11.254898] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[   11.274602] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
[   11.291385] br-lan: port 1(lan1) entered blocking state
[   11.296655] br-lan: port 1(lan1) entered disabled state
[   11.301987] mt7530-mdio mdio-bus:1f lan1: entered allmulticast mode
[   11.308264] mtk_soc_eth 1b100000.ethernet eth0: entered allmulticast mode
[   11.318462] mt7530-mdio mdio-bus:1f lan1: entered promiscuous mode
[   11.340016] mt7530-mdio mdio-bus:1f lan2: configuring for phy/gmii link mode
[   11.355028] br-lan: port 2(lan2) entered blocking state
[   11.360276] br-lan: port 2(lan2) entered disabled state
[   11.365617] mt7530-mdio mdio-bus:1f lan2: entered allmulticast mode
[   11.374284] mt7530-mdio mdio-bus:1f lan2: entered promiscuous mode
[   11.391670] mt7530-mdio mdio-bus:1f lan3: configuring for phy/gmii link mode
[   11.411016] br-lan: port 3(lan3) entered blocking state
[   11.416301] br-lan: port 3(lan3) entered disabled state
[   11.421609] mt7530-mdio mdio-bus:1f lan3: entered allmulticast mode
[   11.432498] mt7530-mdio mdio-bus:1f lan3: entered promiscuous mode
[   11.450369] mt7530-mdio mdio-bus:1f lan4: configuring for phy/gmii link mode
[   11.464339] br-lan: port 4(lan4) entered blocking state
[   11.469585] br-lan: port 4(lan4) entered disabled state
[   11.474955] mt7530-mdio mdio-bus:1f lan4: entered allmulticast mode
[   11.483793] mt7530-mdio mdio-bus:1f lan4: entered promiscuous mode
[   11.506826] mt7530-mdio mdio-bus:1f wan: configuring for phy/gmii link mode
[   14.261764] mt7530-mdio mdio-bus:1f lan1: Link is Up - 1Gbps/Full - flow control rx/tx
[   14.269766] br-lan: port 1(lan1) entered blocking state
[   14.275035] br-lan: port 1(lan1) entered forwarding state
root@OpenWrt:~#
In comparison, here’s the one with the FM350 attached and working:
[    0.003078] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.003091] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.005805] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[    0.005962] rcu: Hierarchical SRCU implementation.
[    0.005966] rcu:     Max phase no-delay instances is 1000.
[    0.006523] smp: Bringing up secondary CPUs ...
[    0.006909] Detected VIPT I-cache on CPU1
[    0.006920] CPU features: SANITY CHECK: Unexpected variation in SYS_CNTFRQ_EL0. Boot CPU: 0x00000000bebc20, CPU1: 0x00000000000000
[    0.006942] CPU features: Unsupported CPU feature variation detected.
[    0.007006] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.007084] smp: Brought up 1 node, 2 CPUs
[    0.007089] SMP: Total of 2 processors activated.
[    0.007093] CPU features: detected: 32-bit EL0 Support
[    0.007096] CPU features: detected: CRC32 instructions
[    0.007130] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[    0.007134] CPU: All CPU(s) started at EL2
[    0.007136] alternatives: applying system-wide alternatives
[    0.011866] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.011885] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.013106] pinctrl core: initialized pinctrl subsystem
[    0.014230] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.014845] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[    0.014876] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.014899] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.015351] thermal_sys: Registered thermal governor 'fair_share'
[    0.015356] thermal_sys: Registered thermal governor 'bang_bang'
[    0.015359] thermal_sys: Registered thermal governor 'step_wise'
[    0.015361] thermal_sys: Registered thermal governor 'user_space'
[    0.015437] ASID allocator initialised with 65536 entries
[    0.016145] pstore: Using crash dump compression: deflate
[    0.016150] pstore: Registered ramoops as persistent store backend
[    0.016153] ramoops: using 0x10000@0x42ff0000, ecc: 0
[    0.027395] Modules: 29456 pages in range for non-PLT usage
[    0.027405] Modules: 520976 pages in range for PLT usage
[    0.028299] cryptd: max_cpu_qlen set to 1000
[    0.029457] SCSI subsystem initialized
[    0.029672] libata version 3.00 loaded.
[    0.031308] clocksource: Switched to clocksource arch_sys_counter
[    0.033472] NET: Registered PF_INET protocol family
[    0.033623] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.035356] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[    0.035372] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.035383] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.035434] TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.035644] TCP: Hash tables configured (established 8192 bind 8192)
[    0.035771] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.035799] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.036111] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.036153] PCI: CLS 0 bytes, default 64
[    0.037465] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[    0.042215] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.042225] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.074186] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.087375] mt-pmic-pwrap 10001000.pwrap: unexpected interrupt int=0x1
[    0.100980] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    0.108654] printk: console [ttyS0] disabled
[    0.129075] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 118, base_baud = 1562500) is a ST16650V2
[    0.129128] printk: console [ttyS0] enabled
[    0.800487] mtk_rng 1020f000.rng: registered RNG driver
[    0.800664] random: crng init done
[    0.814156] loop: module loaded
[    0.818102] mtk-ecc 1100e000.ecc: probed
[    0.824851] spi-nand spi1.0: Winbond SPI NAND was found.
[    0.830172] spi-nand spi1.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[    0.838332] mtk-snand 1100d000.spi: ECC strength: 4 bits per 512 bytes
[    0.845184] 2 fixed-partitions partitions found on MTD device spi1.0
[    0.851597] OF: Bad cell count for /spi@1100d000/flash@0/partitions
[    0.857872] OF: Bad cell count for /spi@1100d000/flash@0/partitions
[    0.864367] Creating 2 MTD partitions on "spi1.0":
[    0.869166] 0x000000000000-0x000000080000 : "bl2"
[    0.874924] 0x000000080000-0x000008000000 : "ubi"
[    1.011227] ubi0: default fastmap pool size: 50
[    1.015794] ubi0: default fastmap WL pool size: 25
[    1.020586] ubi0: attaching mtd1
[    1.299008] ubi0: scanning is finished
[    1.307260] ubi0: attached mtd1 (name "ubi", size 127 MiB)
[    1.312784] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[    1.319660] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[    1.326445] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[    1.333402] ubi0: good PEBs: 1018, bad PEBs: 2, corrupted PEBs: 0
[    1.339487] ubi0: user volume: 6, internal volumes: 1, max. volumes count: 128
[    1.346703] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[    1.355051] ubi0: available PEBs: 0, total reserved PEBs: 1018, PEBs reserved for bad PEB handling: 18
[    1.364362] ubi0: background thread "ubi_bgt0d" started, PID 274
[    1.364511] OF: Bad cell count for /spi@1100d000/flash@0/partitions
[    1.376829] OF: Bad cell count for /spi@1100d000/flash@0/partitions
[    1.383775] block ubiblock0_4: created from ubi0:4(fit)
[    1.522655] mtk_soc_eth 1b100000.ethernet: generated random MAC address 65:74:68:25:64:00
[    1.533416] mtk_soc_eth 1b100000.ethernet eth0: mediatek frame engine at 0xffffffc0815e0000, irq 124
[    1.543423] mtk_soc_eth 1b100000.ethernet eth1: mediatek frame engine at 0xffffffc0815e0000, irq 124
[    1.553339] i2c_dev: i2c /dev entries driver
[    1.560737] mtk-wdt 10212000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[    1.571350] NET: Registered PF_INET6 protocol family
[    1.572983] mtk-msdc 11240000.mmc: Got CD GPIO
[    1.578225] Segment Routing with IPv6
[    1.584519] In-situ OAM (IOAM) with IPv6
[    1.588510] NET: Registered PF_PACKET protocol family
[    1.593639] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.607901] 8021q: 802.1Q VLAN Support v1.8
[    1.636554] mtk-pcie 1a143000.pcie: host bridge /pcie@1a143000 ranges:
[    1.643208] mtk-pcie 1a143000.pcie: Parsing ranges property...
[    1.649058] mtk-pcie 1a143000.pcie:      MEM 0x0020000000..0x0027ffffff -> 0x0020000000
[    1.700395] mmc0: new HS200 MMC card at address 0001
[    1.707526] mmcblk0: mmc0:0001 008G30 7.28 GiB
[    1.715223] mmcblk0boot0: mmc0:0001 008G30 4.00 MiB
[    1.722195] mmcblk0boot1: mmc0:0001 008G30 4.00 MiB
[    1.727898] mmcblk0rpmb: mmc0:0001 008G30 4.00 MiB, chardev (249:0)
[    1.741531] mmc1: host does not support reading read-only switch, assuming write-enable
[    1.751438] mmc1: new high speed SDHC card at address 5048
[    1.758280] mmcblk1: mmc1:5048 SD32G 28.9 GiB
[    1.765680] Alternate GPT is invalid, using primary GPT.
[    1.771027]  mmcblk1: p1 p2 p3 p4 p5 p6 p128
[    1.991378] mtk-pcie 1a143000.pcie: Port0 link down
[    1.996707] mtk-pcie 1a143000.pcie: PCI host bridge to bus 0000:00
[    2.002925] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.008414] pci_bus 0000:00: root bus resource [mem 0x20000000-0x27ffffff]
[    2.015292] pci_bus 0000:00: scanning bus
[    2.021028] pci_bus 0000:00: fixups for bus
[    2.025218] pci_bus 0000:00: bus scan returning with max=00
[    2.031599] mtk-pcie 1a145000.pcie: host bridge /pcie@1a145000 ranges:
[    2.038155] mtk-pcie 1a145000.pcie: Parsing ranges property...
[    2.043996] mtk-pcie 1a145000.pcie:      MEM 0x0028000000..0x002fffffff -> 0x0028000000
[    2.379504] mtk-pcie 1a145000.pcie: PCI host bridge to bus 0001:00
[    2.385727] pci_bus 0001:00: root bus resource [bus 00-ff]
[    2.391220] pci_bus 0001:00: root bus resource [mem 0x28000000-0x2fffffff]
[    2.398110] pci_bus 0001:00: scanning bus
[    2.402349] pci 0001:00:01.0: [14c3:3258] type 01 class 0x060400
[    2.408390] pci 0001:00:01.0: reg 0x10: [mem 0x00000000-0x1ffffffff 64bit pref]
[    2.418189] pci_bus 0001:00: fixups for bus
[    2.422412] pci 0001:00:01.0: scanning [bus 00-00] behind bridge, pass 0
[    2.429113] pci 0001:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.437136] pci 0001:00:01.0: scanning [bus 00-00] behind bridge, pass 1
[    2.444033] pci_bus 0001:01: scanning bus
[    2.448210] pci 0001:01:00.0: [14c3:4d75] type 00 class 0x0d4000
[    2.454417] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit pref]
[    2.461758] pci 0001:01:00.0: reg 0x18: [mem 0x00000000-0x007fffff 64bit]
[    2.468652] pci 0001:01:00.0: reg 0x20: [mem 0x00000000-0x007fffff 64bit pref]
[    2.476729] pci 0001:01:00.0: supports D1 D2
[    2.480996] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.487640] pci 0001:01:00.0: PME# disabled
[    2.492186] pci 0001:01:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0001:00:01.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[    2.531582] pci_bus 0001:01: fixups for bus
[    2.535784] pci_bus 0001:01: bus scan returning with max=01
[    2.541384] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[    2.548012] pci_bus 0001:00: bus scan returning with max=01
[    2.553618] pci 0001:00:01.0: BAR 0: no space for [mem size 0x200000000 64bit pref]
[    2.561280] pci 0001:00:01.0: BAR 0: failed to assign [mem size 0x200000000 64bit pref]
[    2.569300] pci 0001:00:01.0: BAR 8: assigned [mem 0x28000000-0x293fffff]
[    2.576108] pci 0001:01:00.0: BAR 2: assigned [mem 0x28000000-0x287fffff 64bit]
[    2.583520] pci 0001:01:00.0: BAR 4: assigned [mem 0x28800000-0x28ffffff 64bit pref]
[    2.591373] pci 0001:01:00.0: BAR 0: assigned [mem 0x29000000-0x29007fff 64bit pref]
[    2.599208] pci 0001:00:01.0: PCI bridge to [bus 01]
[    2.604190] pci 0001:00:01.0:   bridge window [mem 0x28000000-0x293fffff]
[    2.611209] pcieport 0001:00:01.0: assign IRQ: got 133
[    2.616378] pcieport 0001:00:01.0: enabling device (0000 -> 0002)
[    2.622507] pcieport 0001:00:01.0: enabling bus mastering
[    2.628030] mtk-pcie 1a145000.pcie: msi#0 address_hi 0x0 address_lo 0x450050c0
[    2.635597] pcieport 0001:00:01.0: PME: Signaling with IRQ 133
[    2.641631] pcieport 0001:00:01.0: save config 0x00: 0x325814c3
[    2.647565] pcieport 0001:00:01.0: save config 0x04: 0x00100006
[    2.653518] pcieport 0001:00:01.0: save config 0x08: 0x06040000
[    2.659443] pcieport 0001:00:01.0: save config 0x0c: 0x00010000
[    2.665377] pcieport 0001:00:01.0: save config 0x10: 0x0000000c
[    2.671309] pcieport 0001:00:01.0: save config 0x14: 0x00000000
[    2.677231] pcieport 0001:00:01.0: save config 0x18: 0x40010100
[    2.683163] pcieport 0001:00:01.0: save config 0x1c: 0x04200000
[    2.689085] pcieport 0001:00:01.0: save config 0x20: 0x29302800
[    2.695016] pcieport 0001:00:01.0: save config 0x24: 0x00000000
[    2.700938] pcieport 0001:00:01.0: save config 0x28: 0x00000000
[    2.706869] pcieport 0001:00:01.0: save config 0x2c: 0x00000000
[    2.712807] pcieport 0001:00:01.0: save config 0x30: 0x00000000
[    2.718731] pcieport 0001:00:01.0: save config 0x34: 0x00000050
[    2.724662] pcieport 0001:00:01.0: save config 0x38: 0x00000000
[    2.730585] pcieport 0001:00:01.0: save config 0x3c: 0x00020185
[    2.737815] mtk_hsdma 1b007000.dma-controller: MediaTek HSDMA driver registered
[    2.746616] FIT: Detected U-Boot 2024.07-OpenWrt-r27100-21a5b3b540
[    2.752851] FIT: Selected configuration: "config-1" (OpenWrt bananapi_bpi-r64)
[    2.760079] FIT:           kernel sub-image 0x00001000..0x0059e5c2 "kernel-1" (ARM64 OpenWrt Linux-6.6.44)
[    2.769830] FIT:          flat_dt sub-image 0x0059f000..0x005a86db "fdt-1" (ARM64 OpenWrt bananapi_bpi-r64 device tree blob)
[    2.781158] FIT:          flat_dt sub-image 0x005a9000..0x005a911a "fdt-mt7622-bananapi-bpi-r64-pcie1" (ARM64 OpenWrt bananapi_bpi-r64 device tree overlay mt7622-bananapi-bpi-r64-pcie1)
[    2.797771] FIT:          flat_dt sub-image 0x005aa000..0x005aa20f "fdt-mt7622-bananapi-bpi-r64-sata" (ARM64 OpenWrt bananapi_bpi-r64 device tree overlay mt7622-bananapi-bpi-r64-sata)
[    2.814204] FIT:       filesystem sub-image 0x005ab000..0x00bd4fff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r64 rootfs)
[    2.825390] block ubiblock0_4: mapped 1 uImage.FIT filesystem sub-image as /dev/fit0
[    2.892939] mt7530-mdio mdio-bus:1f: configuring for fixed/2500base-x link mode
[    2.901872] mt7530-mdio mdio-bus:1f: Link is Up - 2.5Gbps/Full - flow control rx/tx
[    2.911090] mt7530-mdio mdio-bus:1f wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7531 PHY] (irq=135)
[    2.931829] mt7530-mdio mdio-bus:1f lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7531 PHY] (irq=136)
[    2.952287] mt7530-mdio mdio-bus:1f lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7531 PHY] (irq=137)
[    2.972742] mt7530-mdio mdio-bus:1f lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7531 PHY] (irq=138)
[    2.993243] mt7530-mdio mdio-bus:1f lan4 (uninitialized): PHY [mt7530-0:04] driver [MediaTek MT7531 PHY] (irq=139)
[    3.004708] mtk_soc_eth 1b100000.ethernet eth0: entered promiscuous mode
[    3.011507] DSA: tree 0 setup
[    3.014953] clk: Disabling unused clocks
[    3.022175] VFS: Mounted root (squashfs filesystem) readonly on device 259:1.
[    3.029457] Freeing unused kernel memory: 384K
[    3.034063] Run /sbin/init as init process
[    3.038159]   with arguments:
[    3.041117]     /sbin/init
[    3.043828]   with environment:
[    3.046959]     HOME=/
[    3.049308]     TERM=linux
[    3.207021] init: Console is alive
[    3.210582] init: - watchdog -
[    3.726785] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    3.756634] usbcore: registered new interface driver usbfs
[    3.762221] usbcore: registered new interface driver hub
[    3.767579] usbcore: registered new device driver usb
[    3.773423] gpio_button_hotplug: loading out-of-tree module taints kernel.
[    3.789822] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[    3.795103] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 1
[    3.804178] xhci-mtk 1a0c0000.usb: hcc params 0x01403198 hci version 0x96 quirks 0x0000000000200010
[    3.813352] xhci-mtk 1a0c0000.usb: irq 140, io mem 0x1a0c0000
[    3.819212] xhci-mtk 1a0c0000.usb: xHCI Host Controller
[    3.824449] xhci-mtk 1a0c0000.usb: new USB bus registered, assigned bus number 2
[    3.831854] xhci-mtk 1a0c0000.usb: Host supports USB 3.0 SuperSpeed
[    3.838614] hub 1-0:1.0: USB hub found
[    3.842498] hub 1-0:1.0: 2 ports detected
[    3.846991] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.855749] hub 2-0:1.0: USB hub found
[    3.859554] hub 2-0:1.0: 1 port detected
[    3.868919] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    3.886560] init: - preinit -
[    4.204796] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[    4.213968] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[    4.221580] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
[    6.380752] UBIFS (ubi0:5): Mounting in unauthenticated mode
[    6.386567] UBIFS (ubi0:5): background thread "ubifs_bgt0_5" started, PID 824
[    6.410886] UBIFS (ubi0:5): recovery needed
[    6.484945] UBIFS (ubi0:5): recovery completed
[    6.489496] UBIFS (ubi0:5): UBIFS: mounted UBI device 0, volume 5, name "rootfs_data"
[    6.497353] UBIFS (ubi0:5): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[    6.507286] UBIFS (ubi0:5): FS size: 100945920 bytes (96 MiB, 795 LEBs), max 806 LEBs, journal size 5079040 bytes (4 MiB, 40 LEBs)
[    6.519041] UBIFS (ubi0:5): reserved for root: 4767925 bytes (4656 KiB)
[    6.525662] UBIFS (ubi0:5): media format: w5/r0 (latest is w5/r0), UUID AFD3124B-46E3-4F5E-8680-ABA271D45030, small LPT model
[    6.539059] mount_root: switching to ubifs overlay
[    6.546707] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[    6.560498] urandom-seed: Seeding with /etc/urandom.seed
[    6.622671] procd: - early -
[    6.625635] procd: - watchdog -
[    7.194249] procd: - watchdog -
[    7.198486] procd: - ubus -
[    7.356379] procd: - init -
[    7.693810] kmodloader: loading kernel modules from /etc/modules.d/*
[    7.729214] hid: raw HID events driver (C) Jiri Kosina
[    7.747405] Bluetooth: Core ver 2.22
[    7.751085] NET: Registered PF_BLUETOOTH protocol family
[    7.756431] Bluetooth: HCI device and connection manager initialized
[    7.762823] Bluetooth: HCI socket layer initialized
[    7.767696] Bluetooth: L2CAP socket layer initialized
[    7.772762] Bluetooth: SCO socket layer initialized
[    7.779352] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    7.784732] Bluetooth: BNEP filters: protocol multicast
[    7.789966] Bluetooth: BNEP socket layer initialized
[    7.802311] usbcore: registered new interface driver btusb
[    7.808822] Loading modules backported from Linux version v6.9.9-0-g28fdf4518483
[    7.816281] Backport generated by backports.git v6.1.97-1-29-gf1d24a3683b2
[    7.824621] Bluetooth: HCI UART driver ver 2.3
[    7.829080] Bluetooth: HCI UART protocol H4 registered
[    7.834268] Bluetooth: HCI UART protocol BCSP registered
[    7.839576] Bluetooth: HCI UART protocol ATH3K registered
[    7.846402] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    7.852400] Bluetooth: HIDP socket layer initialized
[    7.869147] Bluetooth: RFCOMM TTY layer initialized
[    7.874096] Bluetooth: RFCOMM socket layer initialized
[    7.879247] Bluetooth: RFCOMM ver 1.11
[    7.931992] urngd: v1.0.2 started.
[    7.972769] mt7622-wmac 18000000.wmac: Invalid MAC address, using random address 6e:a9:f3:b0:6b:cf
[    8.031735] mt7622-wmac 18000000.wmac: registering led 'mt76-phy0'
[    8.038463] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[    8.082495] mtk_t7xx 0001:01:00.0: assign IRQ: got 133
[    8.087691] mtk_t7xx 0001:01:00.0: enabling device (0000 -> 0002)
[    8.093899] mtk_t7xx 0001:01:00.0: enabling bus mastering
[    8.101418] mt7622-wmac 18000000.wmac: HW/SW Version: 0x8a108a10, Build Time: 20190801210006a
[    8.101418]
[    8.111600] mtk_t7xx 0001:01:00.0: PM configuration timed out
[    8.117360] mtk_t7xx: probe of 0001:01:00.0 failed with error -110
[    8.153259] PPP generic driver version 2.4.2
[    8.159021] NET: Registered PF_PPPOX protocol family
[    8.168472] kmodloader: done loading kernel modules from /etc/modules.d/*
[    8.206000] mt7622-wmac 18000000.wmac: N9 Firmware Version: _reserved_, Build Time: 20220630094834
[   11.416155] mtk_soc_eth 1b100000.ethernet eth0: Link is Down
[   11.434168] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/2500base-x link mode
[   11.443514] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 2.5Gbps/Full - flow control rx/tx
[   11.472028] mt7530-mdio mdio-bus:1f lan1: configuring for phy/gmii link mode
[   11.485008] br-lan: port 1(lan1) entered blocking state
[   11.490254] br-lan: port 1(lan1) entered disabled state
[   11.495613] mt7530-mdio mdio-bus:1f lan1: entered allmulticast mode
[   11.501929] mtk_soc_eth 1b100000.ethernet eth0: entered allmulticast mode
[   11.512968] mt7530-mdio mdio-bus:1f lan1: entered promiscuous mode
[   11.537301] mt7530-mdio mdio-bus:1f lan2: configuring for phy/gmii link mode
[   11.549557] br-lan: port 2(lan2) entered blocking state
[   11.554906] br-lan: port 2(lan2) entered disabled state
[   11.560187] mt7530-mdio mdio-bus:1f lan2: entered allmulticast mode
[   11.578355] mt7530-mdio mdio-bus:1f lan2: entered promiscuous mode
[   11.595475] mt7530-mdio mdio-bus:1f lan3: configuring for phy/gmii link mode
[   11.611058] br-lan: port 3(lan3) entered blocking state
[   11.616367] br-lan: port 3(lan3) entered disabled state
[   11.621671] mt7530-mdio mdio-bus:1f lan3: entered allmulticast mode
[   11.634728] mt7530-mdio mdio-bus:1f lan3: entered promiscuous mode
[   11.652411] mt7530-mdio mdio-bus:1f lan4: configuring for phy/gmii link mode
[   11.664928] br-lan: port 4(lan4) entered blocking state
[   11.670173] br-lan: port 4(lan4) entered disabled state
[   11.675543] mt7530-mdio mdio-bus:1f lan4: entered allmulticast mode
[   11.685312] mt7530-mdio mdio-bus:1f lan4: entered promiscuous mode
[   11.705081] mt7530-mdio mdio-bus:1f wan: configuring for phy/gmii link mode
[   14.463480] mt7530-mdio mdio-bus:1f lan1: Link is Up - 1Gbps/Full - flow control rx/tx
[   14.471501] br-lan: port 1(lan1) entered blocking state
[   14.476739] br-lan: port 1(lan1) entered forwarding state
Mhm,only “port down”,so i guess r64 does not give enough power to the card…
hi planning to replace my 5g router and im getting my r4 and fm350 from aliexpress…will the 350 pcimode will work with the latest snapshot ? hope you can post a how to . TIA
Yes. The latest OpenWRT snapshots have the kmod-mtk-t7xx package that’s needed for the FM350 to work in PCI mode. From there you can use modemmanager and it will work with the card.
What’s weird is the FM350 works just fine and it’s a power hungry 5G card as well.
Any other suggestions on things I can test or make an attempt at? I’ve been reading up on some other threads surrounding this board including all the power related concerns especially the voltage issues on some of the pins on the PCI slots. But I haven’t been able to get a full grasp on the whole thing and how it may impact this.
I will say with the Quectel card in after booting up the board, it does get warm. Just no signs of life at all.
Hi, I have two questions: you wrote that you managed to get the Quectel GL AP working.
I’ve been able to get the RM520 to show up in other devices in PCI mode using this adapter.
What devices are these?
Were you able to get the GL AP working on the Banana Pi 4?
