Random mac-adress on eth0, eth1 not visible
Hi, i have first boot-up my R2 using debian-jessie-line-image. first thing i noticed…everytime i boot-up i have another mac-adress on eth0 (wan-port), how to change that? second, i see no eth1 (lan-Ports), any idea?
regards Frank
Hello Frank,
you can assign static MAC addresses using the instructions from Static MAC-Address for Bananapi
EDIT: Or you can use my ruleset from udev aswell:
cat /etc/udev/rules.d/69-static-mac.rules
# MAC address for eth0 / WAN
ACTION=="add", SUBSYSTEM=="net", ATTR{dev_id}=="0x0", ATTR{ifindex}=="6" RUN+="/sbin/ip link set dev %k address 26:bf:b5:59:15:d0"
# MAC address for eth1 / LAN
ACTION=="add", SUBSYSTEM=="net", ATTR{dev_id}=="0x0", ATTR{ifindex}=="5" RUN+="/sbin/ip link set dev %k address 26:bf:b5:59:15:d1"
You can determine ATTR{ifindex} using cat /sys/class/net/eth0/ifindex
Do you see any other interfaces than eth0 if you run cat /proc/net/dev ?
Regards, Daniel
in proc i see also eth1
ok, i see eth1 is not auto in /etc/network/interfaces…
how to change that mac also (difference in udev-rule)?
i see also in /etc/network/interfaces an hint for changing the HW-Adress:
iface eth0 inet dhcp
hwaddress ether # if you want to set MAC manually
setting MAC via /etc/network/interfaces seems not to work tried that way:
iface eth0 inet static hwaddress ether DE:AD:BE:EF:69:01
i’ve tried setting the mac via udev-rule (but don’t know if udev is running in the boot-process):
(how to create aa code-block here to make it readable??)
nano /etc/udev/rules.d/75-static-mac.rules
#######eth0 ACTION==“add”, SUBSYSTEM==“net”, ATTR{dev_id}==“0x0”, ATTR{ifindex}==“3”, RUN+="/usr/bin/ip link set dev %k address 72:29:3c:06:d0:17" #######eth1 ACTION==“add”, SUBSYSTEM==“net”, ATTR{dev_id}==“0x0”, ATTR{ifindex}==“4”, RUN+="/usr/bin/ip link set dev %k address 8a:df:d4:39:f3:8b"
udevadm info -q all --path /sys/class/net/eth0 | less
P: /devices/platform/1b100000.ethernet/net/eth0
E: DEVPATH=/devices/platform/1b100000.ethernet/net/eth0
E: ID_NET_DRIVER=mtk_eth_soc
E: ID_PATH=platform-1b100000.ethernet
E: ID_PATH_TAG=platform-1b100000_ethernet
E: IFINDEX=3
E: INTERFACE=eth0
E: MATCHDEVID=0x0
E: MATCHIFTYPE=1
E: SUBSYSTEM=net
E: SYSTEMD_ALIAS=/sys/subsystem/net/devices/eth0
E: TAGS=:systemd:
E: UDEV_LOG=6
E: USEC_INITIALIZED=785847
udevadm info -q all --path /sys/class/net/eth1 | less
P: /devices/platform/1b100000.ethernet/net/eth1
E: DEVPATH=/devices/platform/1b100000.ethernet/net/eth1
E: IFINDEX=4
E: INTERFACE=eth1
E: MATCHDEVID=0x0
E: MATCHIFTYPE=1
E: SUBSYSTEM=net
E: SYSTEMD_ALIAS=/sys/subsystem/net/devices/eth1
E: TAGS=:systemd:
E: UDEV_LOG=6
E: USEC_INITIALIZED=788285
3
cat /sys/class/net/eth1/ifindex
4
udev_eth1.txt (5.1 KB)
i tried now to set MAC with the hwaddress-param in /etc/network/interfaces for eth1, that worked, but not for eth0…also static instead of dhcp/manual works…seems my problem was the appended Comment (# if you want to set MAC manually ) that MUST be removed, else that line creates error and the interface does not get created
that works:
auto eth0
  hwaddress ether 08:00:00:00:00:00
  address 192.168.0.10
  netmask 255.255.255.0
  gateway 192.168.0.5
auto eth1
    iface eth1 inet static
    address 192.168.50.1
    hwaddress ether 08:00:00:00:00:01
What solution did you go with to control static MAC?
This is the old ifupdown way…newer images using systemd-networkd
https://wiki.fw-web.de/doku.php?id=en:bpi-r2:network:start#using_systemd
Thank you
For the WAN MAC… /etc/systemd/network/10-wan.link
yes, in the images created by my BPI-Router-Images repo it is prepared here:
