Hello everyone.
So i’m using @frank-w 's kernel and image repos. Kernel now is 6.12.7-bpi-r4-main. Previous kernel was 6.12.0, same behaviour. I’m having random reboots/panics. Last two, were in a row, 10 minutes apart. Any ideas about this guys? Seems related to mt7925.
user.log
2025-01-21T20:51:11.992009+00:00 banana1 systemd-pstore[2927]: PStore dmesg-ramoops-1 moved to /var/lib/systemd/pstore/dmesg-ramoops-1
2025-01-21T20:51:11.992036+00:00 banana1 systemd-pstore[2927]: PStore dmesg-ramoops-0 moved to /var/lib/systemd/pstore/dmesg-ramoops-0
2025-01-21T20:51:11.992050+00:00 banana1 systemd-pstore[2927]: PStore console-ramoops-0 moved to /var/lib/systemd/pstore/console-ramoops-0
2025-01-22T00:32:52.731713+00:00 banana1 systemd-pstore[2928]: PStore dmesg-ramoops-1 moved to /var/lib/systemd/pstore/dmesg-ramoops-1
2025-01-22T00:32:52.731746+00:00 banana1 systemd-pstore[2928]: PStore dmesg-ramoops-0 moved to /var/lib/systemd/pstore/dmesg-ramoops-0
2025-01-22T00:32:52.731775+00:00 banana1 systemd-pstore[2928]: PStore console-ramoops-0 moved to /var/lib/systemd/pstore/console-ramoops-0
2025-01-23T12:41:39.192347+00:00 banana1 systemd-pstore[2925]: PStore dmesg-ramoops-1 moved to /var/lib/systemd/pstore/dmesg-ramoops-1
2025-01-23T12:41:39.192361+00:00 banana1 systemd-pstore[2925]: PStore dmesg-ramoops-0 moved to /var/lib/systemd/pstore/dmesg-ramoops-0
2025-01-23T12:41:39.192391+00:00 banana1 systemd-pstore[2925]: PStore console-ramoops-0 moved to /var/lib/systemd/pstore/console-ramoops-0
2025-01-24T14:25:59.052248+00:00 banana1 systemd-pstore[2929]: PStore dmesg-ramoops-1 moved to /var/lib/systemd/pstore/dmesg-ramoops-1
2025-01-24T14:25:59.052265+00:00 banana1 systemd-pstore[2929]: PStore dmesg-ramoops-0 moved to /var/lib/systemd/pstore/dmesg-ramoops-0
2025-01-24T14:25:59.052297+00:00 banana1 systemd-pstore[2929]: PStore console-ramoops-0 moved to /var/lib/systemd/pstore/console-ramoops-0
2025-01-24T14:35:22.611356+00:00 banana1 systemd-pstore[2927]: PStore dmesg-ramoops-1 moved to /var/lib/systemd/pstore/dmesg-ramoops-1
2025-01-24T14:35:22.611389+00:00 banana1 systemd-pstore[2927]: PStore dmesg-ramoops-0 moved to /var/lib/systemd/pstore/dmesg-ramoops-0
2025-01-24T14:35:22.611423+00:00 banana1 systemd-pstore[2927]: PStore console-ramoops-0 moved to /var/lib/systemd/pstore/console-ramoops-0
Oops#1 Part1
<6>[    8.030083] lanbr0: port 3(lan2) entered disabled state
<6>[    8.035359] mt7530-mmio 15020000.switch lan2: entered allmulticast mode
<6>[    8.042230] mt7530-mmio 15020000.switch lan2: entered promiscuous mode
<6>[    8.049293] lanbr0: port 4(lan3) entered blocking state
<6>[    8.054544] lanbr0: port 4(lan3) entered disabled state
<6>[    8.054587] mt7530-mmio 15020000.switch lan3: entered allmulticast mode
<6>[    8.066672] mt7530-mmio 15020000.switch lan3: entered promiscuous mode
<6>[    8.110237] mtk_soc_eth 15100000.ethernet eth2: configuring for inband/10gbase-r link mode
<4>[    8.115189] mtdblock: MTD device 'ubi' is NAND, please consider using UBI block devices instead.
<6>[    8.140744] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
<6>[    8.149081] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
<6>[    8.149684] mt7530-mmio 15020000.switch lan2: configuring for phy/internal link mode
<6>[    8.168991] mt7530-mmio 15020000.switch lan3: configuring for phy/internal link mode
<6>[    8.177862] mt7530-mmio 15020000.switch lan1: configuring for phy/internal link mode
<4>[    8.192919] mtdblock: MTD device 'bl2' is NAND, please consider using UBI block devices instead.
<6>[    8.236372] mtk_soc_eth 15100000.ethernet eth2: Link is Up - 10Gbps/Full - flow control off
<6>[    8.250699] lanbr0: port 1(eth2) entered blocking state
<6>[    8.255957] lanbr0: port 1(eth2) entered forwarding state
<6>[    8.311051] mt7530-mmio 15020000.switch wan: configuring for phy/internal link mode
<6>[    8.332582] mt7530-mmio 15020000.switch wan: Link is Up - 1Gbps/Full - flow control rx/tx
<6>[    8.382604] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/10gbase-r link mode
<6>[    8.514554] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 10Gbps/Full - flow control off
<5>[    8.696269] cfg80211: Loading compiled-in X.509 certificates for regulatory database
<5>[    8.715595] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
<5>[    8.721850] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
<7>[    8.919486] mt7925e 0001:01:00.0: vgaarb: pci_notify
<7>[    8.925310] mt7925e 0001:01:00.0: assign IRQ: got 111
<6>[    8.931796] mt7925e 0001:01:00.0: enabling device (0000 -> 0002)
<7>[    8.939138] mt7925e 0001:01:00.0: enabling bus mastering
<7>[    8.945799] mtk-pcie-gen3 11310000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11310c00 data 1
<6>[    8.964604] mt7925e 0001:01:00.0: ASIC revision: 79250000
<4>[    9.032772] FAT-fs (mmcblk0p5): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
<7>[    9.060116] mt7925e 0001:01:00.0: vgaarb: pci_notify
<6>[    9.070844] mt7925e 0001:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20241104132949a
<6>[    9.070844]
<6>[    9.420255] mt7925e 0001:01:00.0: WM Firmware Version: ____000000, Build Time: 20241104133053
<6>[   10.030908] mt7925e 0001:01:00.0 wlP1p1s0: renamed from wlan0
<6>[   11.445637] lanbr0: port 5(wlP1p1s0) entered blocking state
<6>[   11.451248] lanbr0: port 5(wlP1p1s0) entered disabled state
<6>[   11.456897] mt7925e 0001:01:00.0 wlP1p1s0: entered allmulticast mode
<6>[   11.463455] mt7925e 0001:01:00.0 wlP1p1s0: entered promiscuous mode
<6>[   12.035883] wireguard: allowedips self-tests: pass
<6>[   12.043113] wireguard: nonce counter self-tests: pass
<6>[   12.295569] wireguard: ratelimiter self-tests: pass
<6>[   12.480146] lanbr0: port 5(wlP1p1s0) entered blocking state
<6>[   12.480164] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
<6>[   12.485723] lanbr0: port 5(wlP1p1s0) entered forwarding state
<6>[   12.493534] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <[email protected]>. All Rights Reserved.
<7>[   12.510304] wireguard: wg0: Interface created
<7>[   12.520981] wireguard: wg0: Peer 1 created
<7>[   12.525423] wireguard: wg0: Peer 2 created
<7>[   12.529918] wireguard: wg0: Peer 3 created
<7>[   12.534330] wireguard: wg0: Peer 4 created
<46>[   44.115165] systemd-journald[1595]: Time jumped backwards, rotating.
<1>[  546.387050] Unable to handle kernel paging request at virtual address ffffffffffffffa0
<1>[  546.394992] Mem abort info:
<1>[  546.397775]   ESR = 0x0000000096000006
<1>[  546.401525]   EC = 0x25: DABT (current EL), IL = 32 bits
<1>[  546.406826]   SET = 0, FnV = 0
<1>[  546.409870]   EA = 0, S1PTW = 0
<1>[  546.413012]   FSC = 0x06: level 2 translation fault
<1>[  546.417880] Data abort info:
<1>[  546.420750]   ISV = 0, ISS = 0x00000006, ISS2 = 0x00000000
<1>[  546.426229]   CM = 0, WnR = 0, TnD = 0, TagAccess = 0
<1>[  546.431275]   GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
<1>[  546.436576] swapper pgtable: 4k pages, 39-bit VAs, pgdp=000000004517d000
<1>[  546.443272] [ffffffffffffffa0] pgd=0000000045894003, p4d=0000000045894003, pud=0000000045894003, pmd=0000000000000000
<0>[  546.453886] Internal error: Oops: 0000000096000006 [#1] SMP
<7>[  546.459449] Modules linked in: wireguard libchacha20poly1305 chacha_neon libchacha poly1305_neon ip6_udp_tunnel udp_tunnel libcurve25519_generic nft_masq nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 ip_set nf_tables libcrc32c mt7925e mt7925_common mt792x_lib mt76_connac_lib mt76 mac80211 libarc4 cfg80211 fuse ip_tables x_tables
<7>[  546.499788] CPU: 3 UID: 0 PID: 3203 Comm: hostapd Not tainted 6.12.7-bpi-r4-main #3
<7>[  546.507434] Hardware name: Banana Pi BPI-R4 (DT)
<7>[  546.512040] pstate: 60400005 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
<7>[  546.518990] pc : mt7925_sta_set_decap_offload+0xb4/0x178 [mt7925_common]
<7>[  546.525690] lr : mt7925_sta_set_decap_offload+0x50/0x178 [mt7925_common]
<7>[  546.532382] sp : ffffffc082213550
<7>[  546.535686] x29: ffffffc082213550 x28: ffffff80cba9acb0 x27: 0000000000000000
<7>[  546.542813] x26: 0000000000000001 x25: 0000000000000001 x24: 0000000000000001
<7>[  546.549939] x23: ffffff80ce6ae8c8 x22: ffffff80ce6a26f0 x21: ffffff80cba9aa80
<7>[  546.557066] x20: ffffff80ce0f9de0 x19: ffffff80ce6a2000 x18: 0000000000000000
<7>[  546.564191] x17: 0000000000000000 x16: 0000000000000000 x15: 000000558392a300
<7>[  546.571318] x14: 0000000000000000 x13: 0000000000000000 x12: 0000000000000000
<7>[  546.578443] x11: 0000000000000040 x10: ffffffc081639e28 x9 : ffffffc081639e20
<7>[  546.585570] x8 : ffffff80c0400028 x7 : 0000000000000000 x6 : 0000000000000000
<7>[  546.592695] x5 : ffffff80c0400000 x4 : ffffff80c04000a8 x3 : 0000000000000000
<7>[  546.599821] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffffff80cba9acb0
<7>[  546.606948] Call trace:
<7>[  546.609385]  mt7925_sta_set_decap_offload+0xb4/0x178 [mt7925_common]
<7>[  546.615730]  ieee80211_check_fast_rx+0x1c8/0x504 [mac80211]
<7>[  546.621331]  _sta_info_move_state+0xd8/0x4ac [mac80211]
<7>[  546.626577]  sta_info_move_state+0x14/0x20 [mac80211]
<7>[  546.631649]  sta_apply_auth_flags.constprop.0+0x88/0x19c [mac80211]
<7>[  546.637937]  sta_apply_parameters+0x214/0x3d4 [mac80211]
<7>[  546.643268]  ieee80211_add_station+0xd4/0x180 [mac80211]
<7>[  546.648600]  nl80211_new_station+0x45c/0x624 [cfg80211]
<7>[  546.653852]  genl_family_rcv_msg_doit+0xc0/0x128
<7>[  546.658466]  genl_rcv_msg+0x1e4/0x26c
<7>[  546.662118]  netlink_rcv_skb+0x5c/0x128
<7>[  546.665945]  genl_rcv+0x38/0x50
<7>[  546.669077]  netlink_unicast+0x2e4/0x33c
<7>[  546.672990]  netlink_sendmsg+0x17c/0x3b4
<7>[  546.676904]  ____sys_sendmsg+0x18c/0x2f8
<7>[  546.680820]  ___sys_sendmsg+0x80/0xdc
<7>[  546.684473]  __sys_sendmsg+0x68/0xc8
<7>[  546.688038]  __arm64_sys_sendmsg+0x24/0x30
<7>[  546.692124]  invoke_syscall+0x48/0x110
<7>[  546.695867]  el0_svc_common.constprop.0+0x40/0xe0
<7>[  546.700561]  do_el0_svc+0x1c/0x28
<7>[  546.703869]  el0_svc+0x30/0xd0
<7>[  546.706915]  el0t_64_sync_handler+0x100/0x12c
<7>[  546.711262]  el0t_64_sync+0x194/0x198
<0>[  546.714916] Code: d280003a f9420381 12001c7b aa1c03e0 (785a0021)
<4>[  546.720997] ---[ end trace 0000000000000000 ]---
Panic#2 Part1
<6>[    9.070844]
<3>[  546.727169] pstore: backend (ramoops) writing error (-28)
<0>[  546.732558] Kernel panic - not syncing: Oops: Fatal exception
<2>[  546.738293] SMP: stopping secondary CPUs
<0>[  546.742208] Kernel Offset: disabled
<0>[  546.745686] CPU features: 0x00,00000102,00200000,4200420b
<0>[  546.751073] Memor
