R4 br-lan can't pppoe?
When I dialed using br-wan, reported an error. (use Official firmware) 当使用官方固件并用br-wan进行拨号时.发生错误,无法正常拨号上网.请问如何修改? 单独使用设备LAN0拨号再次测试也不行。用Br-wan和单独LAN0拨号都不行.但是使用SFP0就是那个WAN口可以正常拨号上网
Sat Apr 27 02:54:30 2024 daemon.warn pppd[8084]: LCP: timeout sending Config-Requests
Sat Apr 27 02:54:30 2024 daemon.notice pppd[8084]: Connection terminated.
Sat Apr 27 02:54:30 2024 daemon.info : 07[KNL] interface pppoe-wan deleted
Sat Apr 27 02:54:30 2024 daemon.info pppd[8084]: Sent PADT
Sat Apr 27 02:54:30 2024 daemon.notice pppd[8084]: Modem hangup
Sat Apr 27 02:54:30 2024 daemon.info pppd[8084]: Exit.
Sat Apr 27 02:54:30 2024 daemon.notice netifd: Interface 'wan' is now down
Sat Apr 27 02:54:30 2024 daemon.notice netifd: Interface 'wan' is setting up now
Sat Apr 27 02:54:30 2024 daemon.info pppd[10203]: Plugin rp-pppoe.so loaded.
Sat Apr 27 02:54:30 2024 daemon.info pppd[10203]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sat Apr 27 02:54:30 2024 daemon.notice pppd[10203]: pppd 2.4.8 started by root, uid 0
Sat Apr 27 02:54:30 2024 daemon.info pppd[10203]: PPP session is 1585
Sat Apr 27 02:54:30 2024 daemon.warn pppd[10203]: Connected to 4c:96:14:6c:eb:c5 via interface br-wan
Sat Apr 27 02:54:30 2024 kern.info kernel: [  118.270798] pppoe-wan: renamed from ppp0
Sat Apr 27 02:54:30 2024 daemon.info pppd[10203]: Renamed interface ppp0 to pppoe-wan
Sat Apr 27 02:54:30 2024 daemon.info pppd[10203]: Using interface pppoe-wan
Sat Apr 27 02:54:30 2024 daemon.notice pppd[10203]: Connect: pppoe-wan <--> br-wan
two:
Sat Apr 27 02:56:57 2024 daemon.info pppd[20313]: Plugin rp-pppoe.so loaded.
Sat Apr 27 02:56:57 2024 daemon.info pppd[20313]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sat Apr 27 02:56:57 2024 daemon.notice pppd[20313]: pppd 2.4.8 started by root, uid 0
Sat Apr 27 02:57:12 2024 daemon.warn pppd[20313]: Timeout waiting for PADO packets
Sat Apr 27 02:57:12 2024 daemon.err pppd[20313]: Unable to complete PPPoE Discovery
Sat Apr 27 02:57:12 2024 daemon.info pppd[20313]: Exit.
Sat Apr 27 02:57:12 2024 daemon.notice netifd: Interface 'wan' is now down
Sat Apr 27 02:57:12 2024 daemon.notice netifd: Interface 'wan' is setting up now
Sat Apr 27 02:57:13 2024 daemon.info pppd[21001]: Plugin rp-pppoe.so loaded.
Sat Apr 27 02:57:13 2024 daemon.info pppd[21001]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Sat Apr 27 02:57:13 2024 daemon.notice pppd[21001]: pppd 2.4.8 started by root, uid 0
Error: Unknown error (NEGOTIATION_FAILED)
Maybe you need to add vlan and connect over this? Here in germany this is a common configuration.
An you should not connect via lan-bridge…
不是br-lan.是单独用lan0设备拨号. 不需要VLAN.
这是原始路由上的配置不用配VLAN
Please english text,also on screenshots…and they show your settings,but not what your ISP expects…some only allow specific mac-adresses
use SFP0 is pppoe OK use lan0 pppoe error.
you try it lan0 to pppoe test it
There are some problems with my description at the beginning. I can confirm that there is no problem with my pppoe settings because the sfp port of eth2 can dial normally. With the same setting, lan0 cannot dial normally.
I formatted the log as code for better readability,but the only problem i see is this:
Which means you send PADI to your access node and got no response. On r4 the 2 sfp are mostly identical (both on mac directly),so i would guess there is a configuration issue on the bridge,but do not know any except vlan-awareness which would affect pppoe.
Which kernel/system do you use? Maybe disable offloading (flow offload,vlan offload).
Why dialin with lan0? Imho this is a very strange setup,as pppoe works on layer2…client sends PADI via broadcast (your full lan if bridged) and then get direct response (PADO with both macs set right) from access-control-node (router). Pppoe handshake then has 2 additional steps to handle ethernet parameters before next protocol (lcp) kicks in,but imho it is unrelated here.
because i have two broadband access to the internet one use sfp0 other use lan0
Have you tried removing lan0 from lanbr0 and use it with pppoe?
lan0 not in br-lan and not in br0 only lan0
see my pic
br-lan : eth1、lan1、lan2、lan3
git from this
Linux OpenWrt 5.4.246 git
Hard to follow if someone (me) cannot read chinese chars and not know the frontend :stuck_out_tongue:
You can try use tcpdump on the interface and look if there is a PADI going out…maybe contact your isp if he sees this packet from your mac…maybe there is a mac filter…lan0 receives mac adress from eth0…maybe a problem is here that the other ports have same mac
:grinning: Now you can learn Chinese. thank you i‘will try it
Try upstream openwrt snapshot
上游的lan0可以拨号
openwrt23.snapshot lan0 pppoe is ok
but mtksdk openwrt21.02 can’t
So I post this problem on here.
then it is up to sinovoip to fix this issue
I had the same problem as him. lan 0 is isolated from brlan and subsequently set to wan intertace for pppoe dialing. Dial-up works normally on sfp0, but cannot be achieved on lan0 in this situation.
I captured packets on lan0 through tcpdump and found that there were PADI, PADO, and PADR packets, but I could not obtain the next stage of PADS packets. Maybe this is a driver problem with the switch that comes with MT7988 in the MTK SDK.
if mainline openwrt works without issues, i would not put work into it
Seems it is reported here too: mediatek: switch to Linux 6.1 and add BananaPi BPi-R4 by dangowrt · Pull Request #14140 · openwrt/openwrt · GitHub
you can try to revert/delete the ppe patch and see if it fixes your issue and report back
You can apply this patch to fix this issue.
https://git01.mediatek.com/plugins/gitiles/openwrt/feeds/mtk-openwrt-feeds/+/20a093d4d6d2bcf41a2db2c1796f0ee6dd04598e
Good,it’s OK The lan0 can PPPOE Now.
Could you please let me know when this patch will be merged? https://git01.mediatek.com/plugins/gitiles/openwrt/feeds/mtk-openwrt-feeds/+/20a093d4d6d2bcf41a2db2c1796f0ee6dd04598e
