R3 - thermal sensor went crazy after the kernel update
Hi all,
After updating the kernel version to 6.4 the CPU thermal sensor shows -274 C while on the previous kernel ( stock [BPI-R3] Debian Bullseye Image kernel) it was ok.
bpi-r3 ~ # cat /sys/class/thermal/thermal_zone0/temp
-274000
bpi-r3 ~ # uname -r
6.4.0-bpi-r3-main
I used the default config + some network-related stuff was added.
Does anyone have similar behavior?
Thak You!
Can you revert to the old kernel to check for hardware issue?
And if it works pls try kernels between…i try to find some time to check with 6.5-rc on my device
bpi-r3 ~ # uname -r
6.1.0-bpi-r3-main
45395
bpi-r3 ~ #
this is the original prebuilt kernel from the bpi-r3_sdmmc_bullseye.img.gz
Sure, it will take some time
6.5.0-rc7-next-20230823
shows same behaviour on my device
root@bpi-r3:~# cat /sys/class/thermal/thermal_zone0/temp
-274000
back to 6.4:
bpi-r3 ~ # uname -r
6.4.0-bpi-r3-main
-274000
Another issue with the 6.4 kernel - after reboot u-boot is unable access SD-card:
F0: 102B 0000
FA: 1040 0000
FA: 1040 0000 [0200]
F9: 103F 0000
F3: 1001 0000 [0200]
F3: 1001 0000
F6: 300C 0028
F5: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
BP: 2400 0041 [0000]
G0: 1190 0000
EC: 0000 0000 [3000]
T0: 0000 01B7 [010F]
Jump to BL
NOTICE:  BL2: v2.6(release):v2.6-897-gc30a1caf8274 sdmmc
NOTICE:  BL2: Built : 09:39:42, Dec 16 2022
NOTICE:  WDT: disabled
NOTICE:  CPU: MT7986 (2000MHz)
NOTICE:  EMI: Using DDR4 settings
NOTICE:  EMI: Detected DRAM size: 2048MB
NOTICE:  BL2: Booting BL31
NOTICE:  BL31: v2.6(release):v2.6-897-gc30a1caf8274 sdmmc
NOTICE:  BL31: Built : 09:39:44, Dec 16 2022
U-Boot 2022.10-00039-g2d6f3964e104-dirty (Dec 16 2022 - 09:35:59 +0100)
CPU:   MediaTek MT7986
Model: mt7986-rfb
DRAM:  2 GiB
Core:  44 devices, 20 uclasses, devicetree: separate
MMC:   mmc@11230000: 0
Loading Environment from MMC... unable to read ssr
*** ERROR: Can't read GPT header ***
find_valid_gpt: *** ERROR: Invalid GPT ***
*** ERROR: Can't read GPT Entries ***
find_valid_gpt: *** ERROR: Invalid Backup GPT ***
boot menu after ~x20 repeated messages
* No partition table - mmc 0 **
Couldn't find partition mmc 0:5
## Error: "initrd" not defined
mmc - MMC sub system
Usage:
mmc info - display info of the current MMC device
mmc read addr blk# cnt
mmc write addr blk# cnt
mmc erase blk# cnt
mmc rescan [mode]
mmc part - lists available partition on current mmc device
mmc dev [dev] [part] [mode] - show or set current mmc device [partition] and set mode
  - the required speed mode is passed as the index from the following list
    [MMC_LEGACY, MMC_HS, SD_HS, MMC_HS_52, MMC_DDR_52, UHS_SDR12, UHS_SDR25,
    UHS_SDR50, UHS_DDR50, UHS_SDR104, MMC_HS_200, MMC_HS_400, MMC_HS_400_ES]
mmc list - lists available devices
mmc wp [PART] - power on write protect boot partitions
  arguments:
   PART - [0|1]
       : 0 - first boot partition, 1 - second boot partition
         if not assigned, write protect all boot partitions
mmc hwpartition <USER> <GP> <MODE> - does hardware partitioning
  arguments (sizes in 512-byte blocks):
   USER - <user> <enh> <start> <cnt> <wrrel> <{on|off}>
        : sets user data area attributes
   GP - <{gp1|gp2|gp3|gp4}> <cnt> <enh> <wrrel> <{on|off}>
        : general purpose partition
   MODE - <{check|set|complete}>
        : mode, complete set partitioning completed
  WARNING: Partitioning is a write-once setting once it is set to complete.
  Power cycling is required to initialize partitions after set to complete.
mmc setdsr <value> - set DSR register value
sd available
jedec_spi_nor spi_nor@0: unrecognized JEDEC id bytes: 00, ef, aa
Failed to initialize SPI flash at 0:0 (error 0)
NAND available
sd nand
fit=bpi-r3.itb
** No partition table - mmc 0 **
Can't set block device
BPI-R3>
the 6.1 always reboots correctly. 1st boot after a cold start to any kernel is always good.
uboot -> linux-6.1 -> reboot -> uboot -> linux 6.4 -> reboot -> uboot -> linux-6.4 .... always works unlil cold boot
uboot -> linux-6.4 -> reboot -> uboot-error as described
I’ll try to update u-boot and test again
P.S. u-boot is a stock image version
UPD:
BPI-R3> mmc info
Device: mmc@11230000
Manufacturer ID: 12
OEM: 3456
Name: SDBus Speed: 50000000
Mode: SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 58.2 GiB
Bus Width: 1-bit
Erase Group Size: 512 Bytes
BPI-R3> mmc rescan
unable to read ssr
unable to read ssr
BPI-R3>
cold boot:
BPI-R3> mmc info
Manufacturer ID: 12
OEM: 3456
Name: SDBus Speed: 25000000
Mode: MMC legacy
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 58.2 GiB
Bus Width: 4-bit
bus-width is different
UPD: sometimes 6.4 reboots correctly.
6.1 -> warm reboot > 6.4 -> warm reboot > … i’ve tested it with 5x 6.4 reboots in a row
a bit another output beginning is the same:
BPI-R3>
BPI-R3> mmc rescan
mmc_init: -95, time 2315
BPI-R3> mmc info
unable to read ssr
unable to read ssr
Manufacturer ID: 12
OEM: 3456
Mode: MMC legacy
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 58.2 GiB
Bus Width: 4-bit
BPI-R3> mmc rescan
unable to read ssr
unable to read ssr
after reset command the kernel was able to boot from SD
4bit is right, wonder about the 1bit bus, but this is unrelated to kernel…made some similar experiences in past where sdcard was not recognized some times, but had no idea what may be the cause, maybe try to update ATF/uboot to newer version (mtk-atf-r4 +2023-07-bpi in my uboot-repo)
but sometimes the sd cannot be read on cold boot…a reset in uboot solves this
i have also the “unable to read ssr” message, but only 1x and boot works
with 6.3.0-rc6 the temp works for me…so it is problem between this and 6.4
made a diff and log (combined in one file so not usable for patch, only for manual looking)
thermal_6.3rc6-6.4.diff (11,3 KB)
i reverted “Add temperature constraints to validate read” and i get 0…so something involved here, but should only target v1 where mt7986 is v3
breaking commit is “thermal/drivers/mediatek: Control buffer enablement tweaks”
after reverting this and fixing some build-issues i can read the temp again with 6.5-rc7
root@bpi-r3:~# uname -a
Linux bpi-r3 6.5.0-rc7-next-20230824-bpi-r3-2g5 #6 SMP Thu Aug 31 10:59:43 CEST 2023 aarch64 GNU/Linux
33013
see changes in https://github.com/frank-w/BPI-Router-Linux/tree/6.5-2g5
sent a regression report to mailinglist and authors/maintainers of the breaking patch
https://lkml.org/lkml/2023/8/31/265
I had the same on R64, some cards U-Boot can’t handle. You may find that another type SD card works fine… It is why I have started to boot from ATF directly in to kernel.
for thermal issue:
it looks like only the additional member fields were missing for mt7986, if i add the same used for mt7622, i get a temperature (before the values were fixed and now the read did not happen because they are missing)
--- a/drivers/thermal/mediatek/auxadc_thermal.c
+++ b/drivers/thermal/mediatek/auxadc_thermal.c
@@ -690,6 +690,9 @@ static const struct mtk_thermal_data mt7986_thermal_data = {
        .adcpnp = mt7986_adcpnp,
        .sensor_mux_values = mt7986_mux_values,
        .version = MTK_THERMAL_V3,
+       .apmixed_buffer_ctl_reg = APMIXED_SYS_TS_CON1,
+       .apmixed_buffer_ctl_mask = GENMASK(31, 6) | BIT(3),
+       .apmixed_buffer_ctl_set = BIT(0),
@DeadMeat can you confirm this?
for mmc-issue…i ran again into it, and it looks like same like yours…1bit width and no access to mmc, but size is correctly read…i guess this is some kind of clock issue
on this card i have an older uboot installed (2023.01, so no r4 patches)
after some time 4bit-bus is visible in mmc info and some time after the read works
@hackpascal any idea here?
I’ve applied the patch to 6.4-main. Will update after testing
UPD:
It works
bpi-r3 ~ # uname -r
6.4.0-bpi-r3-main
48113
Thanks Frank :slight_smile:
ok, sent out official patch to ML
https://patchwork.kernel.org/project/linux-mediatek/patch/[email protected]/
