Can you tell me what heatsink and fan can be used with the R2 Pro?
Thanks,
rah
Thanks,
rah
The R2Pro does not have a built-in cooling fan or heat sink. Perhaps it can only be cooled by installing external components available on the market.
I’m asking what the specifications are for such components. What size heat sink should one use? What are the dimensions of the mounting holes? What connector is used for the fan? Are there any specific heatsinks or heatsink/fan combos that SinoVoip recommend?
Perhaps you could make a plan based on the DXF diagram to make your choice.
Of course but it would be much easier and better if the designers of the device, who presumably have that information, told me what I need to know about the device. That’s what I’m here for.
