QMI on Image BPI-R4Pro-8X-BE14-MT76-OpenWRT24.10-DSA-251229
Hello Community and a happy new year,
I have tested the new image 251229 for R4-Pro but I have a problem with the qmi protocol.
When configuring the qmi, the inteface comes online for a couple of seconds and for some unexplained reason it releases the IP and the interface goes down. Log writes permission denied… I cann’t find out what is going on
Can anyone help?
Please post complete dmesg…i guess it is an underlying issue (card reset due to temp/power).
  • I can’t get my 5G modem to be recognized by my Banana Pi R4 Pro (OpenWrt). Thank you
system log.txt (108.6 KB) dmesg.txt (54.7 KB)
hi Frank
attached please find the system logs (see line 947 onwards) and dmesg
modem is RM520n-gl
what do you mean card reset due to temp/power. the unit is almost cold, no high temp
Good afternoon, I need to know if the images I uploaded and those in the official repository work correctly. My motherboard arrived defective and I’m still waiting for a replacement; I haven’t received them yet.
I haven’t been able to test them.
Please test the three images I uploaded, as the last one combined the xgs-pon patches into a single patch. I want to work with the ones that work correctly and add new applications for 4G and 5G modems.
If someone could please tell me if they work, I’d appreciate it, as I haven’t been able to test them due to the problem with my motherboard.
I can create a new image and upload the new packages to my repository, but without knowing if it works correctly, I don’t know which of the three versions to use.
I’m sharing the links again. I’ll work on the one you recommend that works perfectly, add support, and upload the new packages to my repository: brudalevante (brudalevante) / Repositories · GitHub
My colleague @5gfreak already told me privately that I asked him to please test version 6.6.93. Answered
I have tested version 6.6.93. The QMI is working, with some DNS resolution delays, but it is working.
What I haven’t tested is BE14; I’m waiting for the card in the next few days.
I couldn’t test the other images; I left home to go out, so I may check them tomorrow.
I have the impression that version 6.6.93 is a good one.
However, I’ve noticed that there are some things missing that I think I can fix, improve by adding new packages for 4G and 5G, and try to ensure that the DNS delay works correctly.
Thank you very much for your help.
I see no temp alarms or similar,but for users with more knowlege in openwrt and modems related parts of log
Seems link was active from 05:58:27 till 15:36:17,maybe ISP/radio issue?
Only permission denied is strange…but this is after link loss.
Thu Jan  8 15:36:17 2026 daemon.notice netifd: 5g1_4 (6252): Command failed: ubus call network.interface notify_proto { "action": 0, "link-up": false, "keep": false, "interface": "5g1_4" } (Permission denied)
Thu Jan  8 15:36:17 2026 daemon.notice netifd: Interface '5g1_4' is now down
I have resolved the issue by removed qmi and configuring modemmanager. At least for the moment till openwrt images are available for this model
So you have modem manager installed but not using QIM mode? What does your configuration look like? I have the same modem card.
config interface 'qmi'
        option proto 'qmi'
        option device '/dev/cdc-wdm0'
        option apn 'fast.t-mobile.com'
        option auth 'none'
        option pdptype 'ipv4v6'
        option plmn '310260'
        option modes '5gnr,lte,umts'
        option dhcp '1'
        option autoconnect '1'
Good morning,
I don’t use this image anymore
you may clone this rep and create your image, Frank has done an excellent job, at least until the r4pro is available on selector GitHub - frank-w/openwrt at R4Pro_PR8 · GitHub
bes
