Python RPi and GPIO on M5
Hello,
It looks like that the repository for RPGPIO doesn’t support bananapi m5
After installing, it gives: $ python3 import RPi.GPIO as GPIO BPI: gpioLayout(-1) Traceback (most recent call last): File “”, line 1, in File “/usr/local/lib/python3.8/dist-packages/RPi/GPIO/init.py”, line 23, in from RPi._GPIO import * RuntimeError: This module can only be run on a Raspberry Pi!
I see that there is support for other boards including M3:
Can you add support for M5 too ?
Thank you, Roberto
there is also no support for the m2-pro. T_T
please see here : https://wiki.banana-pi.org/Getting_Started_with_BPI-M5#RPi.GPIO
GPIO in python did’t work… How do I fix?
import RPi.GPIO as GPIO Traceback (most recent call last): File “”, line 1, in File “/usr/local/lib/python3.9/dist-packages/RPi.GPIO-0.7.1-py3.9-linux-aarch64.egg/RPi/GPIO/init.py”, line 23, in from RPi._GPIO import * ImportError: /usr/local/lib/python3.9/dist-packages/RPi.GPIO-0.7.1-py3.9-linux-aarch64.egg/RPi/_GPIO.cpython-39-aarch64-linux-gnu.so: undefined symbol: gpio_direction
Compiling RPi.GPIO as suggested here : https://wiki.banana-pi.org/Getting_Started_with_BPI-M5#RPi.GPIO just fails with a zillion ERRORS
RPi.GPIO-Amlogic/source/common.h:35: multiple definition of `pin_to_gpio_rev1’; build/temp.linux-aarch64-2.7/source/py_gpio.o:/home/*/RPi.GPIO-Amlogic/source/common.h:35: first defined here …
I guess nobody is interested anymore in this, but in case anyone is passing by :
With Bookworm armbian it is possible to make gpios works with RPi.GPIO and WiringPi-Python, I can help, I followed some guidelines from this webpage.
BUT, if you need to use this without sudo/root user, then you’re kinda stuck like me, it’s been a week and I still can’t find any solution right now.
This is what you can read on RPi.GPIO git page : Apps require root (eg ‘sudo python testapp.py’) :
When using BCM mode, RPi BCM numbers are passed to GPIO.xxx and translated internally to Bananapi GPIO numbers
Compare RPi connector pinout / BCM chart and Bananapi pinout to match RPi BCM with Bananapi pins
No mentions about root/sudo on WiringPi-Python.
And no mater what I do I have :
./venv/bin/python3 main.py
pygame-ce 2.5.6 (SDL 2.32.10, Python 3.11.2)
wiringPiSetupAml: Must be root. (Did you forget sudo?)
I really need my python app to be run as normal user, or else I won’t be able to use different stuff within my project. Is there anyone who would know what I could do ?
Some people says stuff about WiringPi but I don’t get it : You could switch to a library that can use the kernel gpio interface, such as WiringPi with Python wrappers. Then you can set the permissions within /sys/class/gpio so that non-root users can access the files.
Other thread here but again, I don’t understand all the ins & outs (litterally ahah).
Last but not least, I made an issue about this here too.
Thanks a lot to anyone reading or involved in any way in BPI and helping, I hope I won’t be needing to buy another hardware :crossed_fingers:
Cheers,
Just for anyone looking for a solution here, Dangku answered here :
« You can try using python3-libgpiod, python3-periphery, or Adafruit_Blinka »
I didn’t try those for the moment and will try come back here to say what it does. Cheers
