I have two questions about the OTG USB port:
Will it work with this little board: https://www.olimex.com/Products/USB-Modules/USB-SATA/open-source-hardware
Will it work with a powered USB hub?
As per the chip used JM20329
which should work as long as there is linux driver for this chip. AFAIK This chip is also used at some NAS Dock Kit by other manufacturer which explains that it must have Linux Driver.
Should work as long as this USB2SATA controller can handle the power correctly from the Powered usb hub. But please check if the USB Powered Hub works fine with the BPI-M64 as We were having issues in booting with usb hub connected.
Maybe @avaf will be able to answer the question of USB Hub support on M64.
