@moore & others at mediatek. There are a number of patches for 5.4 mt76 are you creating any for 6.6 tackling this issue ? or if these already exist could you point me to them ? thank you
did some more debugging and interestingly the crash on mt76_wed_offload_disable only happens if connected to the radio2 (at the moment setup as eht 320mhz) … the other two radios are setup as AX (2 and 5 GHz)
i feel it is related to the WO2 and the mtk_wed code … for instance mtk_wed_wo.h is missing
#define MT7988_FIRMWARE_WO2 “mediatek/mt7988_wo_2.bin” if I follow the preceding code
equally some parts of the code where there’s WO1/WO0 there’s no WO2 …
I hope the devs catchup to this soon … but it seems at least the radio 0 & 1 are working with WO & WED as per what I can see on /sys/kernel/debug/wed[0-1]
Hello @rmandrad ! I have BPI R4 equipped with a MT7916 NPD PCIE and is working as expected without wireless offloading. However once I enable WED, although I see the binds for the offloading @/sys/kernel/debug/pp*/bind downlink is capped at 6 Mbps. I am on OpenWrt 24.10.5 / r29087-d9c5716d1d. Also tried latest Snapshot with same behavior.
Station 0e:06:45:5b:33:f0 (on phy1-ap0)
inactive time: 890 ms
rx bytes: 14589
rx packets: 211
tx bytes: 14180
tx packets: 81
tx retries: 43
tx failed: 43
rx drop misc: 1
signal: -77 [-84, -78] dBm
signal avg: -77 [-82, -79] dBm
tx bitrate: 6.0 MBit/s
tx duration: 21216 us
rx bitrate: 12.0 MBit/s 80MHz
rx duration: 48769 us
last ack signal:-78 dBm
avg ack signal: -76 dBm
airtime weight: 256
authorized: yes
authenticated: yes
associated: yes
preamble: long
WMM/WME: yes
MFP: no
TDLS peer: no
DTIM period: 2
beacon interval:100
short slot time:yes
connected time: 13 seconds
associated at [boottime]: 4156.751s
associated at: 1770477873146 ms
current time: 1770477886020 ms
Do you know if WED should be working and/or if there is a workaround for this behavior? I was not able to find anything in the forum. Please let me know if I should grab any set of logs. Thank you!
i am afraid i don’t as i don’t use wed… there are a number of people complaining of low txpower but that is on the mt7996e and i don’t think it is related to wed
Thanks for taking the time to respond. Sorry, from the subject I thought you guys had WED set up. I might open a separate threat then to see if someone was able to get it working.
