OpenHarmony 5.0.0.71 bm install failing with code 9568266 install permission denied
Hi Team,
I built OpenHarmony 5.0.0.71 image successfully for Banana Pi-F3 board. Board boots properly and bm command is available. But while installing a .hap file using bm tool, installation fails with below error:
bm install -p ActsMindsporeJSTest.hap
error: failed to install bundle. code:9568266 error: install permission denied.
Environment:
  1. OpenHarmony version: 5.0.0.71
  2. Board: Banana Pi
  3. Installation method: bm install
  4. HAP: ActsMindsporeJSTest.hap
Things checked:
  1. Board boot successful
  2. bm tool working
  3. HAP transferred correctly
  4. Tried reinstall
  5. The bm help command is working, but I am encountering a permission issue when trying to install the .hap application.
Questions:
  • Does OpenHarmony 5.0.0.71 restrict bm install for release signed HAPs?
  • Is there any additional permission/configuration needed for bm install?
  • Should persist.hdc.install.mode be enabled?
  • Any specific SELinux/APL/signature requirement for Banana Pi build?
Any guidance would help.
Thanks. vitthal.
