NTFS signature is missing
Base on Frank’s Images repo, I ran “./buildimg.sh bpi-r3 noble” in a Linux laptop in order to create Ubuntu sdmmc image as usual.
But it was reported NTFS related error as below capture. I just found out it appeared after mounting the specific loop devices.
It is weird that the filesystem should not be containing any NTFS stuff. Do you have experience on resolving this?
bpi
umounting tmpfs...
-rw-r--r-- 1 michael michael 7.3M Oct  3 19:39 bpi-r3_emmc.img.gz
-rw-r--r-- 1 root root 302M Oct  3 20:19 noble_arm64.tar.gz
unpack imgfile (bpi-r3_noble_6.12.47-main_sdmmc.img.gz)...
setting up imgfile to loopdev...
mounting loopdev...
NTFS signature is missing.
Failed to mount '/dev/loop0p5': Invalid argument
The device '/dev/loop0p5' doesn't seem to have a valid NTFS.
Maybe the wrong device is used? Or the whole disk instead of a
partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around?
mounting BPI-BOOT failed
real	37m43.463s
user	0m47.905s
sys	0m9.244s
> sudo mount /dev/loop0p5 mnt/BPI-BOOT/
> sudo mount /dev/loop0p6 mnt/BPI-ROOT/
Failed to mount '/dev/loop0p6': Invalid argument
The device '/dev/loop0p6' doesn't seem to have a valid NTFS.
> sudo fdisk -l
Disk /dev/loop0: 7.28 GiB, 7818182656 bytes, 15269888 sectors
Disklabel type: gpt
Disk identifier: 32D7F8C7-58A1-47F6-855F-B8ABBCFE18C9
Device        Start      End  Sectors  Size Type
/dev/loop0p1     34     8191     8158    4M Linux filesystem
/dev/loop0p2   8192     9215     1024  512K Linux filesystem
/dev/loop0p3   9216    13311     4096    2M Linux filesystem
/dev/loop0p4  13312    17407     4096    2M Linux filesystem
/dev/loop0p5  17408   222207   204800  100M Linux filesystem
/dev/loop0p6 222208 13739008 13516801  6.4G Linux filesystem
Disk /dev/nvme0n1: 238.47 GiB, 256060514304 bytes, 500118192 sectors
Disk model: WDC PC SN520 SDAPNUW-256G-1006
Disklabel type: gpt
Disk identifier: E76EFAA6-A53D-4B5E-816F-9B0A5D6CE98C
/dev/nvme0n1p1      2048    739327    737280   360M EFI System
/dev/nvme0n1p2    739328   1001471    262144   128M Microsoft reserved
/dev/nvme0n1p3   1001472 442804223 441802752 210.7G Microsoft basic data
/dev/nvme0n1p4 442804224 446431231   3627008   1.7G Windows recovery environment
/dev/nvme0n1p5 446431232 500107263  53676032  25.6G Microsoft basic data
Disk /dev/sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: ST1000LX015-1U71
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0x2dca22c8
Device     Boot      Start        End    Sectors   Size Id Type
/dev/sda1             2048 1661140582 1661138535 792.1G  7 HPFS/NTFS/exFAT
/dev/sda2  *    1661140992 1662191615    1050624   513M ef EFI (FAT-12/16/32)
/dev/sda3       1662193662 1953523711  291330050 138.9G  5 Extended
/dev/sda5       1662193664 1953523711  291330048 138.9G 83 Linux
Partition 3 does not start on physical sector boundary.
> fdisk -l bpi-r3*
Disk bpi-r3_6.12.47-main.tar.gz: 94.68 MiB, 99278848 bytes, 193904 sectors
Disk bpi-r3_emmc.img.gz: 7.24 MiB, 7587840 bytes, 14820 sectors
Disk bpi-r3_noble_6.12.47-main_sdmmc.img: 7.28 GiB, 7818182656 bytes, 15269888 sectors
Disklabel type: gpt
bpi-r3_noble_6.12.47-main_sdmmc.img1     34     8191     8158    4M Linux filesystem
bpi-r3_noble_6.12.47-main_sdmmc.img2   8192     9215     1024  512K Linux filesystem
bpi-r3_noble_6.12.47-main_sdmmc.img3   9216    13311     4096    2M Linux filesystem
bpi-r3_noble_6.12.47-main_sdmmc.img4  13312    17407     4096    2M Linux filesystem
bpi-r3_noble_6.12.47-main_sdmmc.img5  17408   222207   204800  100M Linux filesystem
bpi-r3_noble_6.12.47-main_sdmmc.img6 222208 13739008 13516801  6.4G Linux filesystem
Thanks.
I have no ntfs partition,do you try to build in windows (e.g. wsl)? BPI-BOOT is fat and BPI-ROOT is ext4
The file can only be used for a loopdev if it is unpacked first.
This is kernel package,no image that can be used with losetup
RESOLVED
I built U-boot (especially branch mtk-atf-2025) in native Linux system.
No /dev/loop* related errors being reported.
Then to build the Images repo in native Linux system as usual.
You firat need to build uboot (e.g. 2025-07-bpu) first and then with same settings mtk-atf-2025 which builds atf around the u-boot binary
