Hi, I think I messed up the OpenWRT setup, before I was pretty sure I had mounted the SD card (the SD card is recognized by Windows, and I tried both ntfs and exfat), but after messing up the setup I think I lost the connection to the SD card. I tried to re-flash the emmc via nand, but it seems that the emmc was not cleared, and the files that existed were still present after re-flash. Is there a chance that I messed up the setup? If so, can I clear the emmc to do a clean install of OpenWRT via nand? Or can I just make the SD card work again?
And if you ask me why I need the SD card so badly: I want to install docker on OpenWRT, and then a few other things like portainer, homeassistant, adguard etc., but 8gb emmc is not enough, I will definitely buy an nvme drive, but not now
