@frank-w It gets to 80 degree, I dont use any heatsink (I only get it power on for testing for now until I DIY somthing for the wifi chip and I live outside the US so it’s hard to get heatsinks in custom sizes, also I use the 2.5 port version so I didn’t buy the metal case)
@frank-w I didn’t understand your answer, so if it does exceed 70 c, it should throttle? Because I can’t find reference for that behavior (it makes sense, just want to be sure)
I do not know exact temperature,but 70°C is mostly near the point where so action is needed for lowering temp. We could look in driver if there is something,but till now it was a guess
I would start at
The const used as max is set to 100 in mt7996.h, but there is some calculation in the functions.
