Hello! I am running the R4 Pro 8x. I posted earlier in the mainline snapshot discussion that I was experiencing some wifi radio crashes a week ago. Since then, thanks to some great community members I found that the pcie clock fix solved that, but my system is now still losing internet at seemingly random intervals. The router and radio remain on, there is just no internet (could something be wrong with the WAN interface?). I am using the stock power supply and it seems to have zero issues. The router also is not in an area where it is bumped or physically interacted with at all to make things come loose. I am not using SFP for WAN, I am on the RJ45 port with the bootconf edit to enable it. I am assuming troubleshooting this will require me to wait for it to crash again and then when it does inspect some logs somewhere? If anyone has any idea what to do, I’d greatly appreciate it.
Have you looked for temperature on wifi and CPU measurement points? Issues that came after some time are often temperature related.
Have not, I could check what’s going on when something happens? Has not occurred today so far.
You can read temp from cpu with
cat /sys/class/thermal/thermal-zone0/temp
afair there were files for mt76 too
Small correction: the thermal path is likely /sys/class/thermal/thermal_zone0/temp (underscore), and the value is usually millidegrees Celsius. Since the router and radio stay on but internet drops, also log WAN link state and counters before/after a cutout, plus dmesg around the event. Check whether the WAN interface keeps carrier and its DHCP lease. Temperature is worth ruling out, but a WAN-side link/DHCP/NAT issue could produce the same symptoms even if Wi-Fi looks fine.
