Need help w/ BPI-R4 4GB SD card image
Im getting the below issue when booting up my BPI R4 and i read through some forum posts, it sounds like it is related to BL2 and FIP files needing to be overwritten with custom configs due to a hardware issue? either a dead CPU core? or something else im not 100% sure on the issue?
NOTICE:  BL2: v2.13.0(release):OpenWrt v2025.07.11~78a0dfd9-1 (mt7988-sdmmc-comb-4bg)
NOTICE:  BL2: Built : 09:15:21, Mar  4 2026
NOTICE:  WDT: Cold boot
NOTICE:  WDT: disabled
NOTICE:  CPU: MT7988
NOTICE:  EMI: DDR4 4BG mode
NOTICE:  EMI: Detected DRAM size: 0 MB
Moved into the right category and added code-tags.
This is the 8G image…do you have 4GB or 8GB RAM?
If you’re booting from an SD card, then you don’t need to worry about replacing the BL2 file. It’s likely a matter of the image size (4GB or 8GB). Since you have the 4GB version of R4, you’ll need to download the corresponding 4GB image.
If you’re worried it might be a DDR hardware issue, try booting from NAND and eMMC.
