Hello, everyone!
I am running some tests using a Banana Pi BPI-F3, I am facing some issues when trying to profile the cache accesses of my application. I have Bianbu 3.0.1 installed on the board.
For profiling the application I am using perf, the problem is that I am getting a couple of errors that I was not able to solve. For context, here is the perf --version and perf list | grep "Hardware":
perf version 6.6.63.gd5b2ef2c6af4-
branch-instructions OR branches [Hardware event] branch-misses [Hardware event] bus-cycles [Hardware event] cache-misses [Hardware event] cache-references [Hardware event] cpu-cycles OR cycles [Hardware event] instructions [Hardware event] ref-cycles [Hardware event] stalled-cycles-backend OR idle-cycles-backend [Hardware event] stalled-cycles-frontend OR idle-cycles-frontend [Hardware event] mem:<addr>[/len][:access] [Hardware breakpoint]
I have set sysctl -w kernel.perf_event_paranoid=0. The first error that I encountered is that perf record [...] is not working, when I try to read the report I get the error: “The perf.data data has no samples!”
The second error that I encounter is perf is not counting some events, most importantly for me the cache-references / cache-misses events, as can be seen in the following result:
# perf stat -e cycles,instructions,cache-misses,branches,branch-misses sleep 10
Performance counter stats for 'sleep 10':
4996191 cycles (59.06%)
1521949 instructions # 0.30 insn per cycle
<not counted> cache-misses (0.00%)
<not counted> branches (0.00%)
<not counted> branch-misses (0.00%)
10.005342635 seconds time elapsed
0.005443000 seconds user
0.000000000 seconds sys
Am I doing something wrong? Also I accept suggestions if there is a better way to profile the cache accesses of an algorithm. I think it is worth noting that I am fairly new to risc-v development.
