This card can make BPI-R:grinning:64/R3 to have AX3000 dualband/AX7800 tri-band support and we can find upstream driver after kernel 5.18.
Anyone have any experience using this card on BPI-R64?
I guess on r64 we will fall into the current limit again like for mt7619. I recently got such card can try if it is recognized on my r64.
For r3 i need adapter for ngff as minipcie slot is usb only
I read here V1.1 was upgraded:
But I guess it is not enough, needs at least 3A. Guess only option for me is to bypass the current limiter. The main 3.3V supply has a current limiting function also.
Is there any chance this card gets fried by the extra 5V that is on the pcie connector?
Anyway it is available on backorder, so I guess it is out of stock.
On the 1.1 schematic i do not find the boosted power adjustment.
Got my AsiaRF MT7916.
Using 6.0 kernel (in BPI-R2 PRO) I got next results:
An impressive uplink speed (client >> ap):
(base) ➜ ~ iperf3 -c 10.0.1.1
Connecting to host 10.0.1.1, port 5201
[ 5] local 10.0.1.26 port 42722 connected to 10.0.1.1 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 73.6 MBytes 617 Mbits/sec 0 2.67 MBytes
[ 5] 1.00-2.00 sec 66.2 MBytes 556 Mbits/sec 0 3.89 MBytes
[ 5] 2.00-3.00 sec 75.0 MBytes 629 Mbits/sec 0 3.89 MBytes
[ 5] 3.00-4.00 sec 97.5 MBytes 818 Mbits/sec 0 3.89 MBytes
[ 5] 4.00-5.00 sec 101 MBytes 849 Mbits/sec 0 3.89 MBytes
[ 5] 5.00-6.00 sec 98.8 MBytes 829 Mbits/sec 0 3.89 MBytes
[ 5] 6.00-7.00 sec 100 MBytes 839 Mbits/sec 0 3.89 MBytes
[ 5] 7.00-8.00 sec 96.2 MBytes 808 Mbits/sec 0 3.89 MBytes
[ 5] 8.00-9.00 sec 81.2 MBytes 682 Mbits/sec 0 3.89 MBytes
[ 5] 9.00-10.00 sec 87.5 MBytes 734 Mbits/sec 0 3.89 MBytes
[ 5] 0.00-10.00 sec 877 MBytes 736 Mbits/sec 0 sender
[ 5] 0.00-10.01 sec 877 MBytes 735 Mbits/sec receiver
iperf Done.
And not very impressive
downlink speed (ap >> client):
(base) ➜ ~ iperf3 -c 10.0.1.1 -R
Reverse mode, remote host 10.0.1.1 is sending
[ 5] local 10.0.1.26 port 43122 connected to 10.0.1.1 port 5201
[ 5] 0.00-1.00 sec 18.7 MBytes 157 Mbits/sec
[ 5] 1.00-2.00 sec 19.7 MBytes 165 Mbits/sec
[ 5] 2.00-3.00 sec 20.2 MBytes 169 Mbits/sec
[ 5] 3.00-4.00 sec 20.0 MBytes 168 Mbits/sec
[ 5] 4.00-5.00 sec 18.9 MBytes 158 Mbits/sec
[ 5] 5.00-6.00 sec 18.9 MBytes 159 Mbits/sec
[ 5] 6.00-7.00 sec 18.8 MBytes 157 Mbits/sec
[ 5] 7.00-8.00 sec 20.2 MBytes 170 Mbits/sec
[ 5] 8.00-9.00 sec 19.5 MBytes 164 Mbits/sec
[ 5] 9.00-10.00 sec 17.4 MBytes 146 Mbits/sec
[ 5] 0.00-10.00 sec 204 MBytes 171 Mbits/sec 0 sender
[ 5] 0.00-10.00 sec 192 MBytes 161 Mbits/sec receiver
iperf Done.
Likely not yet a mature driver with not all hw features implemented:
Unlike mt7915 driver (for 5.10+ kernels) this one has no problems with client2client communication or dbdc reboot issue. like here
P.S. the card is configured for 5GHz VHT160 ax mode
P.P.S 2.4 GHz both upload and download speeds are: ~80+/-5 Mbps.
UPD:
Test in 0.5m distance (previous ~5m distance):
uplink:
[ 5] local 10.0.1.26 port 38048 connected to 10.0.1.1 port 5201
[ 5] 0.00-1.00 sec 130 MBytes 1.09 Gbits/sec 0 3.43 MBytes
[ 5] 1.00-2.00 sec 156 MBytes 1.31 Gbits/sec 0 3.86 MBytes
[ 5] 2.00-3.00 sec 158 MBytes 1.32 Gbits/sec 0 3.86 MBytes
[ 5] 3.00-4.00 sec 144 MBytes 1.21 Gbits/sec 0 3.86 MBytes
[ 5] 4.00-5.00 sec 125 MBytes 1.05 Gbits/sec 0 3.86 MBytes
[ 5] 5.00-6.00 sec 136 MBytes 1.14 Gbits/sec 0 3.86 MBytes
[ 5] 6.00-7.00 sec 151 MBytes 1.27 Gbits/sec 0 3.86 MBytes
[ 5] 7.00-8.00 sec 152 MBytes 1.28 Gbits/sec 0 3.86 MBytes
[ 5] 8.00-9.00 sec 152 MBytes 1.28 Gbits/sec 0 4.12 MBytes
[ 5] 9.00-10.00 sec 154 MBytes 1.29 Gbits/sec 0 4.12 MBytes
[ 5] 0.00-10.00 sec 1.42 GBytes 1.22 Gbits/sec 0 sender
[ 5] 0.00-10.01 sec 1.42 GBytes 1.22 Gbits/sec receiver
iperf Done.
downlink:
[ 5] local 10.0.1.26 port 53034 connected to 10.0.1.1 port 5201
[ 5] 0.00-1.00 sec 17.9 MBytes 150 Mbits/sec
[ 5] 1.00-2.00 sec 18.5 MBytes 156 Mbits/sec
[ 5] 2.00-3.00 sec 18.0 MBytes 151 Mbits/sec
[ 5] 3.00-4.00 sec 18.2 MBytes 153 Mbits/sec
[ 5] 4.00-5.00 sec 18.3 MBytes 154 Mbits/sec
[ 5] 5.00-6.00 sec 19.9 MBytes 167 Mbits/sec
[ 5] 6.00-7.00 sec 20.3 MBytes 170 Mbits/sec
[ 5] 7.00-8.00 sec 20.9 MBytes 175 Mbits/sec
[ 5] 8.00-9.00 sec 19.7 MBytes 165 Mbits/sec
[ 5] 9.00-10.00 sec 19.1 MBytes 161 Mbits/sec
[ 5] 0.00-10.00 sec 202 MBytes 170 Mbits/sec 0 sender
[ 5] 0.00-10.00 sec 191 MBytes 160 Mbits/sec receiver
iperf Done.
This looks like tx limitation or antenna connection broken.
Do You mean not in the driver? Any ideas on how to check it? (mt7615: ~550 Mbps in both directions on the same SoC/OS)
Visually looks OK, but if so doesn’t it should affect both directions?
You can view rx/tx levels with iw tool. And you can compare with other card. If levels are similar this is not the rootcause (e.g eeprom setting).
Strange is that downlink (ap > client) gets smaller on shorter distance. Any conflicting ap from other people?
Have you tested other card in r2pro to make sure limitation is not on r2pro?
need to do some research on iw
It’s pretty much the same around 165Mbps from any device - and yes I have other APs from my neighbors but the selected channel is relatively free.
Previous was the mt7615, which showed 500-600 Mbps in both directions.
I found this using iwconfig:
bpi-r2pro ~ # iwconfig wlx000a5207f58d
wlx000a5207f58d IEEE 802.11 Mode:Master Tx-Power=23 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
Iw dev/list shows the maximum allowed Tx-power. You can increase it with
iw dev wlan0 set txpower fixed 20
I thought there was a way to get the actual tx-power,but Found only iwconfig examples on quick search (and of course rx-power).
iw dev <ifname> station dump
You could also try to disable power_save
bpi-r2pro ~ # iw dev wlx000a5207f58d set txpower fixed 20
command failed: Operation not supported (-95)
bpi-r2pro ~ # iw dev wlx000a5207f58d station dump
Station e0:cc:f8:84:c6:bc (on wlx000a5207f58d)
inactive time: 1216 ms
rx bytes: 42105
rx packets: 411
tx bytes: 48755
tx packets: 232
tx retries: 0
tx failed: 0
rx drop misc: 0
signal: -48 [-61, -48] dBm
signal avg: -47 [-60, -47] dBm
tx bitrate: 720.6 MBit/s 80MHz HE-MCS 7 HE-NSS 2 HE-GI 0 HE-DCM 0
tx duration: 2641756 us
rx bitrate: 6.0 MBit/s
rx duration: 134587 us
airtime weight: 256
authorized: yes
authenticated: yes
associated: yes
preamble: long
WMM/WME: yes
MFP: no
TDLS peer: no
DTIM period: 2
beacon interval:100
short slot time:yes
connected time: 478 seconds
associated at [boottime]: 3479.226s
associated at: 1665903046551 ms
current time: 1665903525165 ms
Also, I have 5 bars of signal strength for my current config.
I can do the same for mt7615 to compare results.
Client-side:
(base) ➜ ~ iw dev wlp5s0 station dump
Station 00:0a:52:07:f5:8d (on wlp5s0)
inactive time: 0 ms
rx bytes: 3576949
rx packets: 37834
tx bytes: 374838927
tx packets: 6430
tx retries: 767
tx failed: 0
beacon loss: 0
beacon rx: 171
rx drop misc: 13
signal: -50 [-56, -50] dBm
signal avg: -54 dBm
beacon signal avg: -51 dBm
tx bitrate: 1088.7 MBit/s 160MHz HE-MCS 5 HE-NSS 2 HE-GI 1 HE-DCM 0
tx duration: 0 us
rx bitrate: 1729.6 MBit/s 160MHz HE-MCS 8 HE-NSS 2 HE-GI 0 HE-DCM 0
rx duration: 0 us
authorized: yes
authenticated: yes
associated: yes
preamble: long
WMM/WME: yes
MFP: no
TDLS peer: no
DTIM period: 2
beacon interval:100
short slot time:yes
connected time: 19 seconds
associated at [boottime]: 93009.923s
associated at: 1665878789283 ms
current time: 1665878807682 ms
On r2pro you have 80Mhz bandwidth
And on client 160
That does not map together. HE-MCS and HE-GI are different…maybe there is a mode not supported by both
Strange is rx on r2pro with 6 mbit/s
My current r2pro bw:
tx bitrate: 1729.6 MBit/s 160MHz HE-MCS 8 HE-NSS 2 HE-GI 0 HE-DCM 0
tx duration: 11690255 us
rx duration: 2338735 us
Looks like it depends on the current wifi load.
P.S. The AP may change the channel by itself w/o any configuration in hostapd:
e.g. it has changed from ch100+_VTH160 to ch36+_VHT160 (which is more bury for most of the time)
