MT7623 overcloking, voltages, powerconsumption, governors
It seems to clk_set_rate() spawns two times subfunctions and dosn’t indicate failure but actual Mhz’s dosn’t change:
[   34.043407] cpufreq: notification 0 of frequency transition to 1400000 kHz
[   34.043441] cpufreqdrv: set_target oldwas: hz:1300000000 vproc:1150000
[   34.043452] cpufreqdrv: set_target newis: hz:1400000000 vproc:1149000
[   34.043455] cpufreqdrv: set_target targetVis: 1149000
[   34.043458] cpufreqdrv: set_target skipped vprocset because target_vproc:1149000
[   34.043476] cpufreqdrv: clk_set_parent return: 0
[   34.043480] clk: clk_set_rate asked: 1400000000
[   34.043484] clk: asked clk_core_set_rate_nolock 1400000000
[   34.043492] clk: round_new_rate: 1399999390
[   34.043499] clk: clk_pm_runtime returned: 0
[   34.043503] clk: asked clk_change_rate, oldrate 1300000000
[   34.043536] clk: asked clk_change_rate, oldrate 1300000000
[   34.043539] clk: clk_change_rate ends
[   34.043541] clk: clk_change_rate ends
[   34.043544] clk: changed rate to 1400000000
[   34.043549] cpufreqdrv: clk_set_rate 1400000000 return: 0
[   34.043556] cpufreqdrv: clk_set_parent return: 0
[   34.043559] cpufreqdrv: set_vproc: 1149000
[   34.043564] cpufreqdrv: finished function
[   34.043567] cpufreq: notification 1 of frequency transition to 1400000 kHz
clk.c seems to be broken. It is writed style “I’ll keep my job”, so difficult to debug. Look:
[   33.223086] cpufreq: notification 0 of frequency transition to 1400000 kHz
[   33.223121] cpufreqdrv: set_target oldwas: hz:1300000000 vproc:1150000
[   33.223131] cpufreqdrv: set_target newis: hz:1400000000 vproc:1150000
[   33.223134] cpufreqdrv: set_target targetVis: 1150000
[   33.223138] cpufreqdrv: set_target skipped vprocset because target_vproc:1150000
[   33.223140] clk: asked clk_set_parent
[   33.223143] clk: asked clk_core_set_parent_nolock
[   33.223148] clk: clk_core_set_parent_nolock p_rate: 1092000000
[   33.223152] clk: clk_core_set_parent_nolock speculate_rates ret: 0
[   33.223166] clk: clk_core_set_parent_nolock set_parent ret: 0
[   33.223169] clk: clk_core_set_parent_nolock ends
[   33.223172] clk: clk_set_parent clk_core_set_parent_nolock ret: 0
[   33.223176] cpufreqdrv: clk_set_parent return: 0
[   33.223179] clk: clk_set_rate asked: 1400000000
[   33.223183] clk: asked clk_core_set_rate_nolock 1400000000
[   33.223191] clk: round_new_rate: 1399999390
[   33.223198] clk: clk_pm_runtime returned: 0
[   33.223203] clk: asked clk_change_rate, oldrate 1300000000
[   33.223206] clk: clk_change_rate, new_parent bestrate 26000000
[   33.223238] clk: asked clk_change_rate, oldrate 1300000000
[   33.223241] clk: clk_change_rate, cur_parent bestrate 1300000000
[   33.223244] clk: clk_change_rate ends
[   33.223247] clk: clk_change_rate ends
[   33.223250] clk: changed rate to 1400000000
[   33.223254] cpufreqdrv: clk_set_rate 1400000000 return: 0
[   33.223257] clk: asked clk_set_parent
[   33.223259] clk: asked clk_core_set_parent_nolock
[   33.223262] clk: clk_core_set_parent_nolock p_rate: 1300000000
[   33.223266] clk: clk_core_set_parent_nolock speculate_rates ret: 0
[   33.223271] clk: clk_core_set_parent_nolock set_parent ret: 0
[   33.223273] clk: clk_core_set_parent_nolock ends
[   33.223275] clk: clk_set_parent clk_core_set_parent_nolock ret: 0
[   33.223278] cpufreqdrv: clk_set_parent return: 0
[   33.223280] cpufreqdrv: finished function
[   33.223284] cpufreq: notification 1 of frequency transition to 1400000 kHz
How about this, is it ok??
[   17.444317] [drm:mtk_drm_crtc_atomic_enable] mtk_crtc_ddp_hw_init
[   17.444332] [drm:mtk_drm_crtc_atomic_enable] mtk_crtc_ddp_clk_enable
[   17.444343] [drm:mtk_drm_crtc_atomic_enable] mediatek_ddp_ddp_path_setup
[   17.444414] clk: clk_set_rate asked: 864000000
[   17.444417] clk: asked clk_core_set_rate_nolock 864000000
[   17.444426] clk: round_new_rate: 863999329
[   17.444441] clk: clk_pm_runtime returned: 0
[   17.444445] clk: asked clk_change_rate, oldrate 148499848
[   17.444448] clk: clk_change_rate, new_parent bestrate 26000000
[   17.444478] clk: asked clk_change_rate, oldrate 148499848
[   17.444480] clk: clk_change_rate, cur_parent bestrate 863999329
[   17.444483] clk: asked clk_change_rate, oldrate 0
[   17.444485] clk: clk_change_rate, cur_parent bestrate 863999329
[   17.444504] clk: asked clk_change_rate, oldrate 0
[   17.444506] clk: clk_change_rate, cur_parent bestrate 0
[   17.444508] clk: asked clk_change_rate, oldrate 0
[   17.444510] clk: clk_change_rate, cur_parent bestrate 0
[   17.444512] clk: asked clk_change_rate, oldrate 0
[   17.444514] clk: clk_change_rate, cur_parent bestrate 0
[   17.444516] clk: clk_change_rate ends
[   17.444517] clk: clk_change_rate ends
[   17.444519] clk: clk_change_rate ends
[   17.444521] clk: asked clk_change_rate, oldrate 0
[   17.444523] clk: clk_change_rate, cur_parent bestrate 0
[   17.444524] clk: clk_change_rate ends
[   17.444526] clk: asked clk_change_rate, oldrate 0
[   17.444528] clk: clk_change_rate, cur_parent bestrate 0
[   17.444530] clk: clk_change_rate ends
[   17.444531] clk: clk_change_rate ends
[   17.444533] clk: clk_change_rate ends
[   17.444535] clk: asked clk_change_rate, oldrate 148499848
[   17.444537] clk: clk_change_rate, new_parent bestrate 863999329
[   17.444540] clk: asked clk_change_rate, oldrate 148499848
[   17.444542] clk: clk_change_rate, cur_parent bestrate 863999329
[   17.444544] clk: asked clk_change_rate, oldrate 148499848
[   17.444546] clk: clk_change_rate, cur_parent bestrate 863999329
[   17.444548] clk: clk_change_rate ends
[   17.444550] clk: asked clk_change_rate, oldrate 148499848
[   17.444552] clk: clk_change_rate, cur_parent bestrate 863999329
[   17.444554] clk: clk_change_rate ends
[   17.444555] clk: clk_change_rate ends
[   17.444557] clk: asked clk_change_rate, oldrate 148499848
[   17.444560] clk: clk_change_rate, cur_parent bestrate 863999329
[   17.444562] clk: asked clk_change_rate, oldrate 148499848
[   17.444564] clk: clk_change_rate, cur_parent bestrate 863999329
[   17.444566] clk: clk_change_rate ends
[   17.444568] clk: asked clk_change_rate, oldrate 148499848
[   17.444570] clk: clk_change_rate, cur_parent bestrate 863999329
[   17.444572] clk: clk_change_rate ends
[   17.444573] clk: clk_change_rate ends
[   17.444575] clk: clk_change_rate ends
[   17.444577] clk: asked clk_change_rate, oldrate 74249924
[   17.444579] clk: clk_change_rate, cur_parent bestrate 863999329
[   17.444581] clk: asked clk_change_rate, oldrate 74249924
[   17.444583] clk: clk_change_rate, cur_parent bestrate 431999664
[   17.444586] clk: asked clk_change_rate, oldrate 74249924
[   17.444588] clk: clk_change_rate, cur_parent bestrate 431999664
[   17.444589] clk: clk_change_rate ends
[   17.444591] clk: clk_change_rate ends
[   17.444592] clk: clk_change_rate ends
[   17.444594] clk: asked clk_change_rate, oldrate 37124962
[   17.444597] clk: clk_change_rate, cur_parent bestrate 863999329
[   17.444598] clk: clk_change_rate ends
[   17.444600] clk: clk_change_rate ends
[   17.444602] clk: changed rate to 864000000
[   17.444605] clk: clk_set_rate asked: 107999916
[   17.444607] clk: asked clk_core_set_rate_nolock 107999916
[   17.444635] clk: round_new_rate: 107999817
[   17.444644] clk: clk_pm_runtime returned: 0
[   17.444647] clk: asked clk_change_rate, oldrate 863999329
[   17.444649] clk: clk_change_rate, new_parent bestrate 26000000
[   17.444676] clk: asked clk_change_rate, oldrate 863999329
[   17.444679] clk: clk_change_rate, cur_parent bestrate 107999817
[   17.444681] clk: asked clk_change_rate, oldrate 0
[   17.444683] clk: clk_change_rate, cur_parent bestrate 107999817
[   17.444701] clk: asked clk_change_rate, oldrate 0
[   17.444703] clk: clk_change_rate, cur_parent bestrate 0
[   17.444705] clk: asked clk_change_rate, oldrate 0
[   17.444707] clk: clk_change_rate, cur_parent bestrate 0
[   17.444709] clk: asked clk_change_rate, oldrate 0
[   17.444711] clk: clk_change_rate, cur_parent bestrate 0
[   17.444712] clk: clk_change_rate ends
[   17.444714] clk: clk_change_rate ends
[   17.444715] clk: clk_change_rate ends
[   17.444717] clk: asked clk_change_rate, oldrate 0
[   17.444719] clk: clk_change_rate, cur_parent bestrate 0
[   17.444721] clk: clk_change_rate ends
[   17.444723] clk: asked clk_change_rate, oldrate 0
[   17.444724] clk: clk_change_rate, cur_parent bestrate 0
[   17.444726] clk: clk_change_rate ends
[   17.444728] clk: clk_change_rate ends
[   17.444729] clk: clk_change_rate ends
[   17.444731] clk: asked clk_change_rate, oldrate 863999329
[   17.444733] clk: clk_change_rate, new_parent bestrate 107999817
[   17.444736] clk: asked clk_change_rate, oldrate 863999329
[   17.444738] clk: clk_change_rate, new_parent bestrate 107999817
[   17.444740] clk: asked clk_change_rate, oldrate 863999329
[   17.444742] clk: clk_change_rate, cur_parent bestrate 107999817
[   17.444744] clk: clk_change_rate ends
[   17.444746] clk: asked clk_change_rate, oldrate 863999329
[   17.444748] clk: clk_change_rate, new_parent bestrate 107999817
[   17.444750] clk: clk_change_rate ends
[   17.444751] clk: clk_change_rate ends
[   17.444754] clk: asked clk_change_rate, oldrate 863999329
[   17.444756] clk: clk_change_rate, cur_parent bestrate 107999817
[   17.444758] clk: asked clk_change_rate, oldrate 863999329
[   17.444760] clk: clk_change_rate, cur_parent bestrate 107999817
[   17.444762] clk: clk_change_rate ends
[   17.444764] clk: asked clk_change_rate, oldrate 863999329
[   17.444766] clk: clk_change_rate, cur_parent bestrate 107999817
[   17.444767] clk: clk_change_rate ends
[   17.444769] clk: clk_change_rate ends
[   17.444770] clk: clk_change_rate ends
[   17.444772] clk: asked clk_change_rate, oldrate 431999664
[   17.444775] clk: clk_change_rate, cur_parent bestrate 107999817
[   17.444777] clk: asked clk_change_rate, oldrate 431999664
[   17.444779] clk: clk_change_rate, cur_parent bestrate 53999908
[   17.444781] clk: asked clk_change_rate, oldrate 431999664
[   17.444783] clk: clk_change_rate, cur_parent bestrate 53999908
[   17.444785] clk: clk_change_rate ends
[   17.444786] clk: clk_change_rate ends
[   17.444788] clk: clk_change_rate ends
[   17.444790] clk: asked clk_change_rate, oldrate 215999832
[   17.444792] clk: clk_change_rate, cur_parent bestrate 107999817
[   17.444794] clk: clk_change_rate ends
[   17.444796] clk: clk_change_rate ends
[   17.444798] clk: changed rate to 107999916
[   17.448864] clk: clk_set_rate asked: 108000000
[   17.448867] clk: asked clk_core_set_rate_nolock 108000000
[   17.448880] clk: round_new_rate: 108000000
[   17.448891] clk: clk_pm_runtime returned: 0
[   17.448895] clk: asked clk_change_rate, oldrate 107999817
[   17.448897] clk: clk_change_rate, new_parent bestrate 26000000
[   17.448925] clk: asked clk_change_rate, oldrate 107999817
[   17.448927] clk: clk_change_rate, new_parent bestrate 107999917
[   17.448930] clk: asked clk_change_rate, oldrate 0
[   17.448932] clk: clk_change_rate, new_parent bestrate 107999917
[   17.448950] clk: asked clk_change_rate, oldrate 0
[   17.448953] clk: clk_change_rate, new_parent bestrate 108000000
[   17.448955] clk: asked clk_change_rate, oldrate 0
[   17.448957] clk: clk_change_rate, new_parent bestrate 108000000
[   17.448959] clk: asked clk_change_rate, oldrate 0
[   17.448961] clk: clk_change_rate, new_parent bestrate 108000000
[   17.448963] clk: clk_change_rate ends
[   17.448964] clk: clk_change_rate ends
[   17.448966] clk: clk_change_rate ends
[   17.448968] clk: asked clk_change_rate, oldrate 0
[   17.448970] clk: clk_change_rate, cur_parent bestrate 108000000
[   17.448971] clk: clk_change_rate ends
[   17.448973] clk: asked clk_change_rate, oldrate 0
[   17.448975] clk: clk_change_rate, cur_parent bestrate 108000000
[   17.448977] clk: clk_change_rate ends
[   17.448979] clk: clk_change_rate ends
[   17.448980] clk: clk_change_rate ends
[   17.448982] clk: asked clk_change_rate, oldrate 107999817
[   17.448984] clk: clk_change_rate, cur_parent bestrate 107999917
[   17.448987] clk: asked clk_change_rate, oldrate 107999817
[   17.448989] clk: clk_change_rate, cur_parent bestrate 107999917
[   17.448991] clk: asked clk_change_rate, oldrate 107999817
[   17.448993] clk: clk_change_rate, cur_parent bestrate 107999917
[   17.448995] clk: clk_change_rate ends
[   17.448997] clk: asked clk_change_rate, oldrate 107999817
[   17.448999] clk: clk_change_rate, cur_parent bestrate 107999917
[   17.449001] clk: clk_change_rate ends
[   17.449002] clk: clk_change_rate ends
[   17.449004] clk: asked clk_change_rate, oldrate 107999817
[   17.449007] clk: clk_change_rate, cur_parent bestrate 107999917
[   17.449009] clk: asked clk_change_rate, oldrate 107999817
[   17.449011] clk: clk_change_rate, cur_parent bestrate 107999917
[   17.449012] clk: clk_change_rate ends
[   17.449015] clk: asked clk_change_rate, oldrate 107999817
[   17.449017] clk: clk_change_rate, cur_parent bestrate 107999917
[   17.449018] clk: clk_change_rate ends
[   17.449020] clk: clk_change_rate ends
[   17.449021] clk: clk_change_rate ends
[   17.449023] clk: asked clk_change_rate, oldrate 53999908
[   17.449026] clk: clk_change_rate, cur_parent bestrate 107999917
[   17.449028] clk: asked clk_change_rate, oldrate 53999908
[   17.449030] clk: clk_change_rate, cur_parent bestrate 53999958
[   17.449032] clk: asked clk_change_rate, oldrate 53999908
[   17.449034] clk: clk_change_rate, cur_parent bestrate 53999958
[   17.449036] clk: clk_change_rate ends
[   17.449037] clk: clk_change_rate ends
[   17.449039] clk: clk_change_rate ends
[   17.449041] clk: asked clk_change_rate, oldrate 26999954
[   17.449043] clk: clk_change_rate, cur_parent bestrate 107999917
[   17.449045] clk: clk_change_rate ends
[   17.449046] clk: clk_change_rate ends
[   17.449048] clk: changed rate to 108000000
Hello,I tryed to figure out diffrent clocks board use and found there is hardware implemented two frequencymeters. So write some shellcode to use them to check clocks. There is approx 100 clocks but only some are used. Calibration constant may need fix better. Currently it is taken from 564Mhz clock. And running enviroment tests are not done. Version 0.01
mt7623-frq-meter.sh (9.3 KB)
It is little slow to run so output can direct to file and use that file to grep active Mhz like:
grep -B1 Mhz …/fq-data.txt | grep -v ready |grep -B1 Mhz
My board seems to have 41 active clocks (hdmi off)
Comments?
I guess we need info from bpi/mtk for this…
My frequencymeter implementation is functional. You can test it if are brave enough :wink:
And second tool reg2grep is almost finished to version 0.001. I had put to database only mt7623 clock datas, but it can/should be extend… Live machine value check is in todo. Sample:
./reg2grep.sh faxi_ck
____________________________________________________________________________
0x10000004 RW	 	DCM_CFG 	AXI Bus Clock DCM Control Register
   bit:     7	 	dcm_enable  	Enables hf_faxi_ck DCM
	    1: Enable DCM
   bit:   4:0	 	dcm_full_fsel	Selects hf_faxi_ck DCM clock
        1xxxx: 	hd_faxi_ck = hf_faxi_ck
        01xxx: 	hd_faxi_ck = hf_faxi_ck/2
        001xx: 	hd_faxi_ck = hf_faxi_ck/4
        0001x: 	hd_faxi_ck = hf_faxi_ck/8
        00001: 	hd_faxi_ck =hf_faxi_ck/16
        00000: 	hd_faxi_ck = hf_faxi_ck/32
0x10000040 RW	 	CLK_CFG_0 	Function Clock Selection Register 0
   bit:     7	 	pdn_axi     	Turns off hf_faxi_ck
	    1: Enable clock-off
0x10000104 RW	 	CLK_CFG_9 	Function clock selection register 9
   bit: 21:16	 	ckgen_clk_sel	Selects f_fckgen_ck clock mux (not glitch free)
           01: 	hf_faxi_ck
           02: 	hd_faxi_ck
./reg2grep.sh faxi_ck  5.00s user 4.50s system 245% cpu 3.866 total
Edit added live machine data grab:
1  bit:     7	 	dcm_enable  	Enables hf_faxi_ck DCM
            1: 	Enable DCM
MEM:        0=0
1  bit:   4:0	 	dcm_full_fsel	Selects hf_faxi_ck DCM clock
MEM:    00000=0
1  bit:     7	 	pdn_axi     	Turns off hf_faxi_ck
            1: 	Enable clock-off
MEM:        0=0
1  bit:     4	 	clk_axi_inv 	Inverts hf_faxi_ck clock phase
            1: 	Enable phase inversion
MEM:        0=0
1  bit:   2:0	 	clk_axi_sel 	Selects hf_faxi_ck clock mux
            0: 	clk26m
            1: 	syspll1_d2
            2: 	syspll_d5
            3: 	syspll1_d4
            4: 	univpll_d5
            5: 	univpll2_d2
            6: 	dmpll_ck
            7: 	dmpll_d2
MEM:      001=1
2  bit: 21:16	 	ckgen_clk_sel	Selects f_fckgen_ck clock mux (not glitch free)
           01: 	hf_faxi_ck
           02: 	hd_faxi_ck
MEM:      000=0
Hmm, intresting:
01: hf_faxi_ck
CKGEN_FMETER clk: 1 result Mhz: 271.70
02: hd_faxi_ck
CKGEN_FMETER clk: 2 result Mhz: 271.70
MEM:    00000=0
Mhz’s should differ 1/32, it is in its bootsettings 00000. Need to dig why dosn’t affect
Find also udocumented register about ckgen, maybe posible to get more clocks to ckgen meter??
0x1000030C RW	 	MBIST_CFG_1 	Debug monitor selection register 1
1  bit:   6:4	 	ckgen_byte_sel	Selects TOPCKGEN debugging monitor
            0: 	undocumented
MEM:      000=0 --> 0: undocumented
And this also:
0x10000108 RW	 	CLK_CFG_10 	Debug monitor clock selection register
   bit: 19:16	 	clk_ckmon3_sel	Selects f_fckmon3_ck clock mux (not glitch free)
           12: 	AD_MAIN_H156M_CK
MEM:     0000=0 -->
   bit:  11:8	 	clk_ckmon2_sel	Selects f_fckmon2_ck clock mux (not glitch free)
MEM:     0000=0 -->
   bit:   3:0	 	clk_ckmon1_sel	Selects f_fckmon1_ck clock mux (not glitch free)
MEM:     0000=0 -->
Have currently not much time…and don’t want to overclock my r2 :slight_smile:
When find time then test… Frequencymeter dosn’t O’C machine. It measures&displays various clock’s on board. It is only information tool.
I’ll O’C my machine when figure out how it should done correctly, then debug how kernel set it and fix kernel to do what I want… FIrst information then deeds…
I didn’t get how to use it:
bpi-r2-gentoo ~/tests # ./mt7623-frq-meter.sh
please implement all needed tests and then clean returnvalue to 0
enviroment tests failed, can't continue
Is it (will it be) available for public?
It is in alpha state so look sources and change 1 to 0 when you are happy. But there are not any tests implemented yet and it is root program… So be carefull. Find also that some high clocks have divider block 256 so result should multiply 256. And there is poorly documented registers. It may be posible that more registers need tweak at it give more clocks. I don’t know yet enough.
reg2grep public yes posible but there is some issues about its database. It maybe illegal in some country’s because source is property of Mediatek (manual). In my country it is not illegal write down Mediatek data but some others it may be.
O’C seems to be bunch of undocumented registers and I don’t know yet what they are and how they should be set… I’ll probing board iobase but scripts run slowly. May take some days to complete small area. Kernel sources are not very helpfull.
It seems device do some software frequency hopping or I have not found correct registers at all. There is sample from one “slowly” changing registerset at 98mhz. Nice puzzle isnt it?
	FD70	F970	F970	F970	3000	0003	0030	0300	0080	002D
	F96A	FD70	F970	FD70	3000	0003	0030	0300	0080	002D
	F970	F970	FD70	F970	3000	0003	0030	0003	0080	002D
	FD70	FD70	FD68	F970	0030	0300	0180	0003	0080	002D
	FD70	F970	FD70	F970	0003	0030	0300	3000	0080	002D
	F970	FD70	F970	F970	3000	0003	0030	0300	35A2	002D
	FD70	F970	FD70	F972	0030	0003	0030	3000	15D2	002D
	FD70	F970	FD70	F970	3000	0300	0300	3000	0080	012C
	FD70	FD70	FD70	F970	0300	3000	0003	3000	0080	002D
	F970	F970	F970	F970	0300	3000	0003	0030	0080	002D
	F970	FD70	FD70	FD70	0003	0030	0300	3000	0080	002D
	F972	F970	F970	F970	0300	3000	0003	0030	0080	002D
	F970	FD70	FD73	FD6B	3000	0003	0030	0300	2129	002D
	F970	FD70	FD70	FD70	0030	3000	0300	3000	0080	002D
	FD70	FD70	F970	FD70	3000	0003	0030	0300	0080	002D
	F970	FD72	F970	FD70	0300	3000	0003	0030	0080	002D
	F970	F960	FD6B	F970	0003	0030	0300	3000	0080	002D
	F970	F970	F970	F970	3000	0003	0030	0300	0080	002D
	FD70	FD70	F970	FD70	0030	0300	3000	0003	0080	012C
	F970	FD70	F970	F970	0030	0300	3000	0300	0080	002D
	FD70	F970	F972	F970	0300	3000	0003	0030	0080	0088
	FD70	F970	F970	F970	0003	0030	0300	3000	0080	002D
	F970	F970	FD70	F970	0300	3000	0003	0030	0080	002D
	FD70	F970	FD70	F970	0003	3000	3000	0003	0080	002D
	FD70	FD70	F970	FD70	0003	0030	0300	3000	0080	002D
	F970	FD70	F970	F970	0003	0030	0300	3000	0080	002D
	F970	FD70	FD70	F970	3000	0003	0030	0300	0080	002D
	F970	FD70	F970	F970	0030	0300	0030	0030	0080	002D
I just got 2Ghz at 1.3v:
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq
2000000
cat /sys/class/thermal/thermal_zone0/temp
50603
and during compile kernel:
56348
armpll div:1 pcw:1260307
Any howtos/benchmarks? :slightly_smiling_face:
What bencmark utility you recommend to emerge?
95% is to do correct .dtsi. There may be some timing broblem. I got it working to adding printk’s to many places. There is also 2Ghz limitter in sources. It is posible to modify too but I have not done yet…
Direct howto is maybe something that Mediatek dosn’t like here?
simplest are:
  • 7z b
  • openssl speed -evp aes-256-cbc
They are likely anredy in your system. Any others - i need to google it too :slight_smile:
I suppose - no explicit prohibition here, while it’s a result of yours research and not stolen. But i think a warning like “doing it on your risk” is a mandatory.
7z was masked, i7z dosn’t compile… But:
echo userspace > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo 1300000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed
7-Zip [32] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21
p7zip Version 16.02 (locale=en_GB.utf8,Utf16=on,HugeFiles=on,32 bits,4 CPUs LE)
LE
CPU Freq:  1287  1287  1288  1288  1288  1287  1288  1288  1288
RAM size:    2009 MB,  # CPU hardware threads:   4
RAM usage:    882 MB,  # Benchmark threads:      4
                       Compressing  |                  Decompressing
Dict     Speed Usage    R/U Rating  |      Speed Usage    R/U Rating
         KiB/s     %   MIPS   MIPS  |      KiB/s     %   MIPS   MIPS
22:       1736   315    537   1689  |      51877   399   1109   4426
23:       1705   320    543   1738  |      50648   398   1102   4382
24:       1690   328    554   1817  |      49548   399   1089   4350
25:       1667   336    566   1904  |      47124   397   1056   4194
Avr:             325    550   1787  |              398   1089   4338
Tot:             362    820   3063
7z b  304.16s user 7.76s system 326% cpu 1:35.67 total
echo 2000000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed
LE
CPU Freq:  1286  1288  1288  1284  1288  1288  1287  1288  1288
22:       1737   315    537   1690  |      51509   397   1107   4395
23:       1712   321    543   1745  |      50717   398   1101   4388
24:       1682   328    552   1809  |      49442   398   1090   4340
25:       1669   336    567   1906  |      47134   397   1057   4195
Avr:             325    550   1787  |              398   1089   4330
Tot:             361    819   3058
7z b  304.08s user 7.84s system 325% cpu 1:35.71 total
So it dosn’t work. Back to sources…
This is highest functional what I have found. Such register won’t allow write higher values if divider is 2.
                writel(0x800CA000, pll->pcw_addr); // 1313Mhz
                writel(0x800FE000, pll->pcw_addr); // 1651Mhz dosn't func
LE
CPU Freq:  1299  1301  1301  1301  1297  1297  1301  1301  1301
22:       1733   312    540   1687  |      52295   399   1119   4462
23:       1702   319    544   1735  |      51327   400   1112   4441
24:       1692   328    555   1820  |      49996   400   1099   4389
25:       1684   338    570   1924  |      47619   396   1070   4238
Avr:             324    552   1791  |              398   1100   4382
Tot:             361    826   3087
7z b  302.35s user 7.80s system 326% cpu 1:35.02 total
1313Mhz is doable to adding it to .dtsi.
Maybe need help from Mediatek. So @Ryder.Lee can you tell addresses for A2D_ACCouple_PLL and A2D_PLL and what bits should modify to change post divider from 2 to 1 ? So calculation 26Mhz * 127 / divider(=2) =1651Mhz change with divider=1 to 26Mhz * multiplier = CPU Mhz’s
Hello, is there any progress behind the overclocking of the 7623?
I have not heared about overclocking yet, but if you have performance issues maybe you should check thermal config…mainline is wrong (throttles down cpu in idle too)
https://forum.banana-pi.org/t/bpi-r64-only-10-cpu-speed-at-already-48-degrees-celcius-speed-not-increasing-anymore/12262/40
thanks for ur sharing. I just wanna have a try for overclock.
