trying to understand how to enable the mt7996 fwlog. being new to this platform want to confirm a few things namely that the fwlog only shows on phy0! and how to read the fwlog_data file?
here are the steps
enable the logs for the phy2
echo 1 >/sys/kernel/debug/ieee80211/phy2/mt76/fw_debug_bin
echo 1 >/sys/kernel/debug/ieee80211/phy2/mt76/fw_debug_wm
echo 1 >/sys/kernel/debug/ieee80211/phy2/mt76/fw_debug_wa
ls -ltr phy2/mt76 shows no fwlog_data
-r-------- 1 root root 0 Sep 28 11:02 xmit-queues
-r-------- 1 root root 0 Sep 28 11:02 tx_stats
-r--r--r-- 1 root root 0 Sep 28 11:02 twt_stats
-rw------- 1 root root 0 Sep 28 11:02 sys_recovery
-r--r--r-- 1 root root 0 Sep 28 11:02 rx-queues
-rw------- 1 root root 0 Sep 28 11:02 rf_regval
-rw------- 1 root root 0 Sep 28 11:02 regval
-rw------- 1 root root 0 Sep 28 11:02 regidx
-rw------- 1 root root 0 Sep 28 11:02 napi_threaded
-rw------- 1 root root 0 Sep 28 11:02 led_pin
-rw------- 1 root root 0 Sep 28 11:02 led_active_low
-rw------- 1 root root 0 Sep 28 11:02 implicit_txbf
-r-------- 1 root root 0 Sep 28 11:02 hw-queues
-r-------- 1 root root 0 Sep 28 11:02 fw_util_wa
-r-------- 1 root root 0 Sep 28 11:02 eeprom
-rw------- 1 root root 0 Sep 28 11:14 fw_debug_wm
-rw------- 1 root root 0 Sep 28 11:14 fw_debug_bin
however
ls -ltr phy0/mt76 shows the fwlog_data
root@bananapi4:/sys/kernel/debug/ieee80211# ls -ltr phy0/mt76
-rw------- 1 root root 0 Sep 28 11:02 fw_debug_wm
-rw------- 1 root root 0 Sep 28 11:02 fw_debug_wa
-rw------- 1 root root 0 Sep 28 11:02 fw_debug_bin
-r-------- 1 root root 467129 Sep 28 11:14 fwlog_data
I believe this is a bug but wanted to confirm on other mt76 platforms if one enables the fw log it shows a fwlog_data files for each phy that has been enabled.
how to read the fwlog_data file ? I know there’s mt76_test but cant get it to work … any process to have the outputs send to syslog ?
last question
anyone knows what this means ?
kern.info kernel: [ 1135.530533] ieee80211 phy0: WA: Invalid baDirection
this message only shows if I enable the fwlogs (in this case for phy2). thank you
