Hello,
I’m using a GLC-SX-MMD module in the sfp2 cage of a BPI-R3 running the latest OpenWrt 24.10.2 build. The issue is that I have to restart the sfp2 interface after boot; otherwise the link doesn’t work. TX is active, but no RX is received. My switch shows the same—TX appears fine, but there’s no RX. As soon as I run ip link set sfp2 down && ip link set sfp2 up on the BPI, the interface starts working. Doing this on the switch has no effect.
Here are some details about my system:
root@GW:~# ethtool sfp2
Settings for sfp2:
Supported ports: [ FIBRE ]
Supported link modes: 1000baseX/Full
Advertised link modes: 1000baseX/Full
Speed: 1000Mb/s
Duplex: Full
Auto-negotiation: off
Port: FIBRE
PHYAD: 0
Transceiver: internal
Supports Wake-on: d
Wake-on: d
Link detected: yes
root@GW:~# ethtool -m sfp2
Identifier : 0x03 (SFP)
Connector : 0x07 (LC)
Transceiver codes : 0x00 0x00 0x00 0x01 0x00 0x00 0x00 0x00 0x00
Transceiver type : Ethernet: 1000BASE-SX
Encoding : 0x01 (8B/10B)
BR, Nominal : 1300MBd
Length (SMF,km) : 0km
Length (SMF) : 0m
Length (50um) : 550m
Length (62.5um) : 270m
Length (Copper) : 0m
Length (OM3) : 0m
Laser wavelength : 850nm
Vendor name : OEM
Vendor OUI : 00:90:65
Vendor PN : GLC-SX-MMD _
Vendor rev : _e
Option values : 0x00 0x12
Option : RX_LOS implemented
BR margin, max : 0%
BR margin, min : 0%
Vendor SN : CSGE2O90093
Date code : 240927
Optical diagnostics support : Yes
Laser bias current : 7.230 mA
Laser output power : 0.3428 mW / -4.65 dBm
Receiver signal average optical power : 0.3361 mW / -4.74 dBm
Module temperature : 45.96 degrees C / 114.73 degrees F
Module voltage : 3.3359 V
Alarm/warning flags implemented : No
