Modem 5g T99W175 (5930e) and BPI-R4, how?
Hello, trying to use T99W175 on R4, unfortunately cannot do lots of progress, not so much information is available or dispersed. The only thing I was able to do is to see device as Wireless Controller. Modem manager does not show any modem. On Debian tried to use fwupd, but despite this vid should be updated by fwupd, fwupdmgr does not show any devices. Device came to me from aliexpress- do not have any windows device with the same slot to check if firmware can be updated there. For the time being I am checking everything without sim card. Any ideas?
lspci -n
0003:00:00.0 0604: 14c3:7988 (rev 01)
0003:01:00.0 0d40: 105b:e0b0
lspci -v
0003:01:00.0 Wireless controller [0d40]: Foxconn International, Inc. Device e0b0
        Subsystem: Foxconn International, Inc. Device e0b0
        Flags: fast devsel, IRQ 113
        Memory at 20200000 (64-bit, non-prefetchable) [size=4K]
        Memory at 20201000 (64-bit, non-prefetchable) [size=4K]
        Capabilities: [40] Power Management version 3
        Capabilities: [50] MSI: Enable+ Count=8/32 Maskable+ 64bit+
        Capabilities: [70] Express Endpoint, MSI 00
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [148] Secondary PCI Express
        Capabilities: [168] Physical Layer 16.0 GT/s <?>
        Capabilities: [18c] Lane Margining at the Receiver <?>
        Capabilities: [19c] Transaction Processing Hints
        Capabilities: [228] Latency Tolerance Reporting
        Capabilities: [230] L1 PM Substates
        Capabilities: [240] Data Link Feature <?>
        Kernel driver in use: mhi-pci-generic
ModemManager
ModemManager[10257]: <info>  ModemManager (version 1.20.4) starting in system bus...
ModemManager[10257]: <info>  [wwan2mbim0/mbim] MBIM device is not QMI capable
ModemManager[10257]: <info>  [device /sys/devices/platform/soc/11280000.pcie/pci0003:00/0003:00:00.0/0003:01:00.0] creating modem with plugin 'foxconn' and '4' ports
ModemManager[10257]: <info>  [base-manager] modem for device '/sys/devices/platform/soc/11280000.pcie/pci0003:00/0003:00:00.0/0003:01:00.0' successfully created
ModemManager[10257]: <info>  [base-manager] couldn't check support for device '/sys/devices/platform/soc/15020000.switch': not supported by any plugin
ModemManager[10257]: <info>  [base-manager] couldn't check support for device '/sys/devices/platform/soc/15100000.ethernet': not supported by any plugin
ModemManager[10257]: <info>  [modem0/wwan2mbim0/mbim] MBIM device is QMI capable
ModemManager[10257]: <info>  [modem0] QMI-based capability and mode switching support enabled
ModemManager[10257]: <error> mm_filter_supported_modes: assertion 'all_item.allowed != MM_MODEM_MODE_NONE' failed
(ModemManager:10257): GLib-GIO-CRITICAL **: 20:29:30.530: g_task_return_error: assertion 'error != NULL' failed
It’s possible you may be able to benefit from the process I’ve used to get a Quectel RM510Q-GL working well - shared instructions in two separate posts, with the steps most relevant for the device drivers + enabling the luci interface aspects for configuring the modem being:
# extra packages to include - Quectel RM510Q-GL:
printf '
CONFIG_PACKAGE_libevdev=y
CONFIG_PACKAGE_libatomic1=y
CONFIG_PACKAGE_libusb-1.0-0=y
CONFIG_PACKAGE_libudev-zero=y
CONFIG_PACKAGE_usbids=y
CONFIG_PACKAGE_usbutils=y
' >> .config
printf '
CONFIG_PACKAGE_uqmi=y
CONFIG_PACKAGE_picocom=y
CONFIG_PACKAGE_luci-proto-qmi=y
CONFIG_PACKAGE_kmod-usb-net-qmi-wwan=y
CONFIG_PACKAGE_kmod-usb-serial-option=y
' >> .config
Rather than a full from-source build, those packages can also be pulled/installed via opkg - have you already checked for existing packages related to firmware/drivers for Qualcomm in the opkg repository?
and of course, if it hasn’t crossed your path, the openwrt docs surrounding this:
https://openwrt.org/docs/guide-user/network/wan/wwan/ltedongle
Well, it is not easy. Do not understand half of the stuff here. :stuck_out_tongue: Anyway most of the modules in kernel are installed. Modem is also responding to qmicli/uqmi under /dev/wwan0mbim0 (openwrt), but cannot start and not visible in modemmanager.
Hello, I have such a card T99W175.F0.0.0.5.7.GC.004 078, I activated it and it is visible in the modem manager, i set it as wwan0 in interfaces but it’s driving me crazy that i can’t enable slot 1 with carrier enabled card. I could not use picocom or minicom to set a command to activate the card.
root@OpenWrt:/# mmcli -m 0
  General  |                    path: /org/freedesktop/ModemManager1/Modem/0
           |               device id: 80b1e6a67b07e43acbde23c1cxxxxxxxxxxxxxx
  Hardware |            manufacturer: foxconn
           |                   model: DELL Snapdragon X55
           |       firmware revision: T99W175.F0.0.0.5.7.GC.004 078
           |          carrier config: GCF
           | carrier config revision: 0A000804
           |            h/w revision: DELL Snapdragon X55
           |               supported: gsm-umts, lte, 5gnr
           |                 current: gsm-umts, lte, 5gnr
           |            equipment id: 3558191100xxxxx
  System   |                  device: /sys/devices/platform/soc/11280000.pcie/pci0003:00/0003:00:00.0/0003:01:00.0
           |                 physdev: /sys/devices/platform/soc/11280000.pcie/pci0003:00/0003:00:00.0/0003:01:00.0
           |                 drivers: mhi-pci-generic
           |                  plugin: foxconn
           |            primary port: wwan0mbim0
           |                   ports: wwan0 (net), wwan0at0 (at), wwan0mbim0 (mbim),
           |                          wwan0qcdm0 (ignored)
  Status   |                   state: failed
           |           failed reason: sim-missing
           |             power state: on
  Modes    |               supported: allowed: 3g; preferred: none
           |                          allowed: 4g; preferred: none
           |                          allowed: 3g, 4g; preferred: 4g
           |                          allowed: 3g, 4g; preferred: 3g
           |                          allowed: 5g; preferred: none
           |                          allowed: 4g, 5g; preferred: 5g
           |                          allowed: 4g, 5g; preferred: 4g
           |                          allowed: 3g, 5g; preferred: 5g
           |                          allowed: 3g, 5g; preferred: 3g
           |                          allowed: 3g, 4g, 5g; preferred: 5g
           |                          allowed: 3g, 4g, 5g; preferred: 4g
           |                          allowed: 3g, 4g, 5g; preferred: 3g
           |                 current: allowed: 3g, 4g, 5g; preferred: 4g
  Bands    |               supported: utran-1, utran-3, utran-4, utran-6, utran-5, utran-8,
           |                          utran-9, utran-2, eutran-1, eutran-2, eutran-3, eutran-4, eutran-5,
           |                          eutran-7, eutran-8, eutran-12, eutran-13, eutran-14, eutran-17,
           |                          eutran-18, eutran-19, eutran-20, eutran-25, eutran-26, eutran-28,
           |                          eutran-29, eutran-30, eutran-32, eutran-34, eutran-38, eutran-39,
           |                          eutran-40, eutran-41, eutran-42, eutran-46, eutran-48, eutran-66,
           |                          eutran-71, utran-19
           |                 current: utran-1, utran-4, utran-6, utran-5, utran-8, utran-9,
           |                          utran-2, eutran-1, eutran-2, eutran-3, eutran-4, eutran-5, eutran-7,
           |                          eutran-8, eutran-12, eutran-13, eutran-14, eutran-17, eutran-18,
           |                          eutran-19, eutran-20, eutran-25, eutran-26, eutran-28, eutran-29,
           |                          eutran-30, eutran-32, eutran-34, eutran-38, eutran-39, eutran-40,
           |                          eutran-41, eutran-42, eutran-46, eutran-48, eutran-66, utran-19
  IP       |               supported: ipv4, ipv6, ipv4v6
  3GPP     |                    imei: 3558191100xxxxx
  SIM      |          sim slot paths: slot 1: /org/freedesktop/ModemManager1/SIM/0
           |                          slot 2: none (active)
root@OpenWrt:/# ifstatus wwan0
        "up": false,
        "pending": false,
        "available": true,
        "autostart": false,
        "dynamic": false,
        "proto": "modemmanager",
        "data": {
        "errors": [
                        "subsystem": "modemmanager",
                        "code": "MM_FAILED_REASON_SIM_MISSING"
Hey @spgi,
faced similar issues with a Fibocom FM-350GL … and took me ages to activate the eSim.
Please have a look here:
To have the fcc-unlock scripts working you need some additional packages that are not auto-installed by modemmananger (reminds me to raise a change request in modem-manager repo documentation or install scripts):
  • at
  • xxd
