Hi! Recently i’ve tried on Raspbian and Armbian kernal 5.17.5. Initial setup without any problem. When I do the system reboot, the operating system comes with this messages:
mmc fail to send stop cmd
** fs_devread read error - block
Failed to load '/boot/Image'
Failed to mount ext2 filesystem...
Can't set block device
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
## Loading init Ramdisk from Legacy Image at 13000000 ...
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 12434602 Bytes = 11.9 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SCRIPT FAILED: continuing...
** No partition table - mmc 0 **
Couldn't find partition mmc 0:1
Scanning disk [email protected]...
Can I know what’s the problem? Appreciate if you can let me know the solution. Thanks
